BMW 3-Series (E90 E92) Forum
Alarm beep on lock/unlock
07-07-2011, 10:54 AM | #1 |
32
Rep 133
Drives: BMW E90 LCI 323i
I can successfully code the Alarm beep on lock/unlock on my 2009 E90 LCI, but this doesn't work on my friend who has the same car as me.
Are these the right codes? The excel says 2009 model is not supported but I can get it works on mine... Alarm beep on unlock DWAI QUIT_AKUST_ENTSCH Alarm beep on lock DWAI QUIT_AKUST_SCHAERF
Performance: K&N High Flow Air Filter | AA Tune Stage 2 | SuperSprint Quad Exhaust
Handling: KW V2 | AP Racing 5200 4 Pots Front Calipers with 330mm J-Hook Drilled Disc | Matt Black 19" Advan RZ-DF Cosmetic: Gloss Black Roof | Gloss Black Front Grilles | M3 Style Trunk Spoiler | Performance Front | M-Tech Rear Bumper | M-Tech Steering Wheel |
07-07-2011, 10:58 AM | #2 |
32
Rep 133
When I change both to "aktiv", lock beep is on but unlock beep is off...
07-07-2011, 12:43 PM | #3 |
62
Rep 1,452
Did you reset the modules by processing the car or processing individual modules w/ a blank .MAN file when you first installed your and your friend's alarm?
07-07-2011, 11:06 PM | #5 | |
32
Rep 133
Can I do the reset now? I had coded the fold mirror and digital speedometer on his car. Hopefully I didn't mess it up..
11-03-2011, 02:21 PM | #6 |
35
Rep 271
I was thinking about this this morning, but perhaps from a different angle. My car with alarm beeps when I lock it that one time. But as I'm walking away and my slight OCD kicks in, sometimes I'll grab the fob and hit the lock button again (just to make sure I actually locked it and wasn't thinking about some other time)... I don't hear or see anything, unless I'm standing right up next to the car, in which case I can hear the door lock actuators cycling. Is there a way for the alarm to beep every time I press the lock button, or for the lights to flash a certain way or something?
11-04-2011, 12:13 AM | #7 | |
Rep 2
Gx |
11-04-2011, 02:34 AM | #8 |
No 55mph
1623
Rep 8,479
My retrofitted alarm on E92 beeps upon lock & unlock, lights also flash on lock, & welcome lights come on upon unlock.
I added the alarm to my VO though (which is really the correct way to do it) all the alarm functions, panic, etc. were automatically enabled after VO update. Yes, you can go into iDrive or use your stalk to control if & when the beeps sound and/or light flash - but all these features were already ON once I updated my VO.
F32 435ix//MGM//M Sport-Prem-Tech-Driver Assist-Lighting-Cold Weather-Dyn Handling Pkgs//M4 Black Lthr Int w/M4 Alum Blade Trim//HK w/Bavsound Stg3//763M//M4 Euro LCI Tails//M4 Mirrors w/CF Covers//AWCarbon CF F/R Spoilers-Side Splitters-Diffuser 6WB/ID6 HU+HUD/IND M4 Alcantara Armrest//PURE S2 Turbo//AA FMIC+DP//ER CP+TIC//3.5bar TMAP/TS DV//AWE Tuning Exh w/Blk Tips//Turner MS CF Intake//BM3 Cary Jordan Tune//MPerf Diff//PrecRW Ignition Kit
11-04-2011, 11:58 AM | #9 | ||
302
Rep 4,444
I also do the folded mirror trick lol |
03-06-2012, 09:37 PM | #10 |
39
Rep 709
Drives: '07 335i (E93)
Hey folks, I did a quick search and didn't find the exact answer I need:
I have a 2007 E93, no alarm system. It is completely stock, and does not beep at all when I lock or unlock it. The dealer just gave me a 2012 loaner car and it does beep on lock/unlock. I had this on my old 1997 528i, and really miss it. Can a 2007 be coded to beep on lock/unlock, even though it does not have an alarm? Is an alarm required to get the beep or does the car have beep capability that can be accessed through coding? Thanks in advance for your help!
Alpine White/Coral Red/Gray Poplar Convertible Sport/Prem/Step/Comfort/Nav/Sirius
MHD Stage 1 Flash, M-Factory Helical LSD By the way people: USE YOUR F&*#ING TURN SIGNALS! Pass the word. |
03-06-2012, 09:44 PM | #11 |
I <3 My E93
181
Rep 3,259
so my 2008 bmw 335i covertible is prewired for the factory alarm, since i have the red clown nose on the rear view mirror. so i ordered the oem factory convertible alarm system from tischer bmw. i went to my local dealership and they said since i installed a LCI IDRIVE Controller(this is the idrive controller found on '11 bmw's) that my alarm cannont be coded to work. meaning no BEEP noise when unlocking or locking....... but when i lock my car my clown nose does blink but i just dont have no BEEP sound at all.....
they said i need to install the old IDRIVE controller in order for my oem alarm to work..is this true? or could a shop other then the bmw dealership code it to beep when locking and unlocking?
Bagged and Wrapped E93 335i
03-06-2012, 10:13 PM | #12 | |
39
Rep 709
How much was the alarm system from Tischer?
03-06-2012, 10:17 PM | #13 |
I <3 My E93
181
Rep 3,259
i believe so, as long as you have the red clown nose i believe your car is prewired then...
its $155 +shipping http://www.trademotion.com/partlocat...047&startrow=1
05-23-2012, 06:54 PM | #15 |
302
Rep 4,444
No after Mid 2009 you are not prewired regardless or red clown nose.
Hold your trunk button on your keys for 3-4 seconds, if it doesn't trigger the alarm you don't have it. |
05-23-2012, 09:43 PM | #16 | |
12
Rep 129
05-24-2012, 01:11 PM | #17 |
302
Rep 4,444
Unless you install an aftermarket solution or can source a Euro Retrofit kit that is rumored to exist for non-prewired cars (US dealers won't know about it or be able to order).
07-07-2012, 08:55 PM | #18 |
9
Rep 122
Drives: It's got 4 wheels
Hey guys... I had my alarm coded by one of the SoCal vendors and noticed I have no control over the alarm in iDrive or on the Stalk... did the vendor not do something, or did I not ask for something specific?
07-12-2012, 12:48 AM | #19 |
24
Rep 318
Without mine being prewired, does anyone have suggestions on getting my 335d to beep.
iDrive control would be nice, but as long as I don't need a second FOB ad can just hear a beep when I hit lock and unlock, I don't even need a real alarm. |
07-12-2012, 12:53 AM | #20 |
62
Rep 487
Drives: 2011 e90 sport pkg ALL BLACK
dont u need that module in you car to do this? i have a lci 2011 e90 will this code work on mine?
07-12-2012, 12:59 AM | #21 | ||
302
Rep 4,444
Who did your coding? Quote:
Yes you have to have the alarm hardware installed. |
