2010 2011 BMW 5 Series Forum F10 Will 18 inch 42mm offset wheels fit my 550i Xdrive (sports pack) |
06-24-2011, 02:51 PM | #1 |
12
Rep 490
Drives: 335i
^^I was wondering if it would fit, I have some from my x5's Winter setup.
Thanks |
06-24-2011, 10:03 PM | #2 |
10
Rep 59
You'll need some more info before being able to determine fit.
Centre bore size. For the F10, it's 72.6mm. I've heard that the SUV's have a centre bore of 74.1mm. You'll need to confirm this. If this is the case, you can always use a hubcentric adapter ring to make it fit. On the offset, it'll depend on the width of the rim. As a reference, the 18x8 rims on an F10 have an offset of 30mm. Here's a link to a wheel offset calculator. You can use to see if the new rims will work. Just use your stocks as reference. http://www.1010tires.com/wheeloffsetcalculator.asp |
