E90Post
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Mechanical Maintenance: Break-in / Oil & Fluids / Servicing / Warranty > Programming your own Car & Key Memory
Reply
      10-07-2005, 07:28 PM   #1
sarafil
sarafil's Avatar
101
429
Drives: 20 X5 M50i
We picked up our 325xi today, and one of the coolest features is the ability to program your own Car & Key Memory settings. Having owned an E46 and an X3 where the dealer was the only one that could change the Car & Key Memory settings, this makes things ALOT easier. Also, if we change our mind about something, it's an easy 1-minute fix versus taking a trip to the dealer and begging them not to charge us to reprogram.
You can control all the features right from the OBC stalk on the steering column. Our car is a non-Nav car, I wonder if you can do this stuff through the Nav like you can on an E60.
I believe that this is a September software-update change, but I could be mistaken.
Anyone else have a chance to play around with this a bit?
Otherwise, our car is great thus far, and I'll try my best to get some pics once it finally stops raining up here.
2020 X5 M50i Alpine White / Coffee Merino Leather
2020 M550i Carbon Black / Canberra Beige Leather
      10-07-2005, 08:03 PM   #2
LEDZEP
LEDZEP's Avatar
419
12,276
Drives: 2009 E70 & 2011 F25
Our 325xiT should be in our posession by mid next week or so... I have been waiting for the software update for the E90, but no word yet. Anxious to try it out! What specific things can you program?
I think it is bad luck to be superstitious
      10-07-2005, 10:44 PM   #3
benoitch
benoitch's Avatar
19
959
Drives: E90 330i
I can say that in my case, a pre-sept prod with sept update, I cannot change the settings usually only the dealer can do (for example, drive away auto-lock). Bummer. You'll probably have better chance than me since yours is a sept prod.
E90 SG,SP, Manual,PP,Terra
http://www.benoitchampagne.com
      10-08-2005, 10:58 AM   #4
sarafil
sarafil's Avatar
101
429
Drives: 20 X5 M50i
I'll grab some pics later... I can program just about everything that the dealer used to have to program...
-auto lock when car in motion or if car is not opened after unlocking
-seat memory when opening door or unlocking
-daytime running lights
-visual confirmation when locking/unlocking
-pathway lighting ("follow me home") and adjustments of how long the lights stay on
      10-08-2005, 11:23 AM   #5
afocoryw20
afocoryw20's Avatar
12
456
Drives: X3 + 325xi
2006 325XI  [0.00]
2005 X3  [0.00]
1990 Mercedes Benz ...  [0.00]
sarafil said......"You can control all the features right from the OBC stalk on the steering column. Our car is a non-Nav car, I wonder if you can do this stuff through the Nav like you can on an E60."
Yes.....you can program all of these features with the I-Drive. It's a great feature. Now I don't have to rely on the dealer
      10-08-2005, 07:03 PM   #6
sarafil
sarafil's Avatar
101
429
Drives: 20 X5 M50i
Here are a few shots of what you can do in the car. I'm sorry if a few aren't totally clear.
There are more. It's a great system and very easy to use and change once you figure out what the symbols mean.
      10-08-2005, 08:28 PM   #7
Barry626
23
724
Drives: Coming: 2012 135i
sarafil
How do u get the key & check mark to appear?
I have iDrive & Nav. does it make a difference?
I can get all settings in my iDrive with exception of DRL.
      10-08-2005, 08:33 PM   #8
sarafil
sarafil's Avatar
101
429
Drives: 20 X5 M50i
Originally Posted by Barry626
sarafil
Put key in the slot and press the start button (don't have to start the engine), then cycle through the options on the display using the up/down button on the turn signal lever (not the button on the end of the stalk, but the one on the middle of the stalk that you can push up/down with your thumb). You'll see two options that say "SET"... one is for unit adjustment, the other is for Car & Key Memory.
I'm not sure how I get the key and the check mark to come up... I think that appeared when I put the key in the slot to tell me the key was recognized.
      10-08-2005, 08:49 PM   #9
StewtheBassman
201
6,381
Drives: 2011 X5d 421,000kms
This is so cool! About time, eh???
      10-08-2005, 09:00 PM   #10
cosmoxi
19
105
Drives: '21 M550
For those that recently took delivery; Did the CA have you fill out a programming sheet before you took delivery? For key memeory, DRL, etc..I think I did this for my E46.
      10-08-2005, 09:02 PM   #11
Barry626
23
724
I see u have 325xi, maybe this only works for new cars being released.
Sure doesn't work on my 330i tryed everything & no way to set it.
      10-08-2005, 09:04 PM   #12
sarafil
sarafil's Avatar
101
429
Drives: 20 X5 M50i
When I gave the car to the service advisor when it came in for a PDI, I told him the settings I wanted set (but didn't fill out a form). When the car was done, they were all ok except for the auto-lock not being active on one of the keys. I brought the car back into the shop for them to program that feature, and that's when the tech showed me that I could change them on my own.
It's really quick, and it's something that your Client Advisor should be able to configure with you in a few minutes during the vehicle presentation at delivery.
      10-08-2005, 09:05 PM   #13
sarafil
sarafil's Avatar
101
429
Drives: 20 X5 M50i
Have you had the September software update performed yet?
      10-08-2005, 09:13 PM   #14
Barry626
23
724
Yes couple weeks ago infact had to leave car over night.
To my knowledge not a single thing new from the update?
      10-08-2005, 09:14 PM   #15
sarafil
sarafil's Avatar
101
429
Drives: 20 X5 M50i
I wonder if they'll ever be able to make this update to your car or if they can't do it.
      10-16-2005, 05:19 PM   #16
lux.sh
missing two turbos.
lux.sh's Avatar
581
4,859
Drives: fast around corners.
whoa. My car doesn't have this either! oh man. that be a neat feature
if you can do that in the car. I need to go ask my dealership.
06 AW E90 330i ZPP/ZSP/Step/Expired Warranty
: Prior Design Front : ACS Rear : ACS Roof : BlackLines : Simota Intake : Carbon Fiber Interior Trim :
: MTEC V3 : 24% Charcoal : V1 Hardwired : Solaris Invisibulbs/LED interior :
      10-16-2005, 05:25 PM   #17
LEDZEP
LEDZEP's Avatar
419
12,276
We now have our 325xiT and all of these programmable functions are there. I spent a few minutes yesterday programming our preferences and it was a snap. I think those of us with older (seems a damn shame to even have to say 'older') E90 are being screwed though.
      10-16-2005, 05:26 PM   #18
lux.sh
missing two turbos.
lux.sh's Avatar
581
4,859
LEDZEP, so the new 325 you've received has those features, but
your E90 doesn't huh?
AH THAT BITES!!!!! DAMN IT.
      10-16-2005, 05:29 PM   #19
LEDZEP
LEDZEP's Avatar
419
12,276
Yep. I have an appointment scheduled for the software update for the E90, but according to the service guy, I still won't have those options. It will only enable their ability to program it for me.
It's not like I'm going to be changing my mind about these settings, but I still feel that BMW is screwing us. We should get a full retro-fit, even if that means a hardware upgrade.
      10-16-2005, 11:38 PM   #20
northerncalguy
Throw your hands in the air, if you's a true playa.
northerncalguy's Avatar
79
436
Drives: 2006 325i, 2014 435i
2006 325i  [0.00]
I just took delivery and it looks like I've got a August Production car without the ability to self-program DRL, autolock and car & key memory. LEDZEP keep us posted on what happens after your software update. I am going to push for a September software update as well.
What did you say to your dealer? I read somewhere that you have to be experiencing an issue with your car before they'll update the software.
      10-28-2005, 04:32 PM   #21
SCA
SCA's Avatar
565
3,742
Drives: Multiple BMWs
So...sounds like this is a Sept production on.
      12-29-2005, 02:35 PM   #22
SCA
SCA's Avatar
565
3,742
So this is fairly easy to find in the menu? I'll be adjusting the settings soon.
Reply
e90post
