      09-29-2010, 03:03 PM   #1
Year's_End
Year's_End's Avatar
1250
12,446
Drives: 2020 Shelby GT350
Post Full Info on Lamborghini Sesto Elemento Concept
What's special about it?
Lamborghini has made an early pitch for the star of the Paris Motor Show with its astonishing-looking Sesto Elemento concept car.
Besides its breathtaking exterior design, though, the carbon-based Sesto Elemento carries a far deeper meaning and will mark a turning point in supercar history, says Lamborghini, by ending the power wars and starting a power-to-weight war.
Incorrectly assumed by many to be the replacement for the Murcielago LP640, the Sesto Elemento boasts an eye-popping 3.8 pounds-per-horsepower weight-to-power ratio — which puts it in the superbike class rather than the supercar class.
With a version of the Gallardo's V10 power plant pumping out 570 horsepower, Lamborghini claims the concept will sprint to 62 mph in just 2.5 seconds. That's because almost everything in the Sesto Elemento is made from carbon fiber (hence the name, Italian for sixth element, which is where carbon sits on the periodic table).
The key to all this performance — and a top speed well in excess of 200 mph — is a curb weight of 2,200 pounds (999 kg), though Lamborghini President Stephan Winkelmann hinted cheerfully that this is a "conservative" weight and that it may hit the scales even lighter than that.
"The power-to-weight will soon become the biggest thing for the supercar market, not the top speed or the power. That's why its engine and gearbox and the tires are not made from carbon fiber, but almost everything else is," says Winkelmann.
Not only does it run a carbon-fiber monocoque chassis "tub," but it also has its entire body, its front crash structure, the suspension and even the exhaust made from carbon, too. Even the wheel rims are carbon fiber. The whole front end of the bodywork has been molded as one single piece of carbon fiber, called a Cofango (which combines the Italian words for "hood" and "fender panels") and the entire rear bodywork is made the same way. Both pieces can be lifted off the car easily by one person.
There are no seat frames to add weight and flexibility. Instead, the seat base is shaped directly into the carbon tub and Lamborghini has added just cushioning and a backrest (made, naturally, of carbon fiber). To get comfortable, the driver now electrically adjusts the pedals and the steering column.
Instead of a traditional alloy bracing beam inside the dashboard, the Sesto Elemento runs a thin carbon framework and the doors are made from just two pieces of carbon fiber — an inner and an outer skin — and nothing else.
In fact, the only significant metallic parts in the midengine Sesto Elemento, besides the engine, six-speed paddle-shift gearbox and driveline, are the aluminum rear subframe and the steering rack.
While achieving an absurd power-to-weight ratio was Lambo's guiding principle here, Lamborghini's technical director, Maurizio Reggiani insisted the Sesto Elemento's handling would be like nothing on the market today.
"With less weight, it will change direction in a way that you won't believe unless you drive it. There will be no play in the suspension, no flexing, no inaccuracy at all. You ask it to do it and that's exactly what it will do, down to the width of a hair," Reggiani insisted.
The concept's shape takes clear elements from the limited-edition Murcielago-based Reventon supercar, but makes even more of a feature of its deep front end, complete with a double-lipped spoiler.
It's designed so that its front intakes draw in cooling air, then redirect it to the radiators and the brakes, where it then exits either through huge triangular vents in the hood or behind the front wheels.
The heavily crafted front end is in stark contrast to the rear, where there is virtually no overhang and, besides a diffuser, a bumper and a thin taillamp/spoiler piece, the entire rear of the engine bay has been left open.
The V10 draws its air from two intakes in the roof, and there are 10 cutouts in the polycarbonate engine cover — one for each cylinder — and two more bodywork holes for the radical exhaust system to exit. This is a first, because it's made of a carbon-ceramic powder in resin that is extremely heat-resistant and has never been seen in the car industry before.
While Winkelmann acknowledges that the Sesto Elemento is a long way from being a production car, the rest of the Lambo line will follow its carbon-intensive lead. Winkelmann hinted that not only will the Murcielago replacement use a carbon-fiber chassis, similar in concept and production to the one underneath the Sesto Elemento, but the Gallardo replacement in two to three years could be a carbon-based life form as well.
Lamborghini now has two carbon-fiber laboratories: one at its home base in Sant'Agata, Italy and one outside Seattle in conjunction with Boeing and the University of Washington. It also has a new carbon-fiber factory geared up to build the Murcielago replacement, and its first pilot build car ran down the production line more than a month ago.
Inside Line says:
We're not sure that unveiling a car with 570 hp can ever be considered opting out of the power war, but we wholeheartedly endorse the rightness of lightness. — James Edwards, Contributor
Past: '15 Mustang GT|401A|PP|6MT
Current: '20 Shelby GT350|6MT
      09-29-2010, 03:09 PM   #2
Garduna
Garduna's Avatar
167
4,013
Drives: Sedona 1er|Yellow S3|NardoTTRS
It reminds me a bit of how I felt when the reventon was first shown
      09-29-2010, 03:15 PM   #3
M-Maika
M-Maika's Avatar
Portugal
11
365
Drives: M3 E92 AW
2008 BMW M3 E92  [10.00]
Outstanding.
I just know that this is going to be very expensive and very rare to see.
M3 E92 M-DKG and all the options available.
Forum BMW Portugal: http://www.forumbmwportugal.com
      09-29-2010, 03:24 PM   #4
TunedM2C
TunedM2C's Avatar
852
4,190
Drives: 2016 LBB M2
Looks like there's a Gallardo under there.
      09-29-2010, 04:51 PM   #5
kyleb350
kyleb350's Avatar
420
4,709
Drives: '21 X3MC
2200 lbs wtf. That's gonna be a screamer
      09-29-2010, 04:52 PM   #6
sb335is
96
736
Drives: fast
sup batman
      09-29-2010, 05:31 PM   #7
hks786
United Kingdom
2306
5,364
Drives: *
+1
I see it already since it is V10 yet lighter and better on fuel economy. This leads the way for development of a new Gallardo.
As a design, it's not impressive except the features and quality of materials. It has too many unconnected surfaces and busy design. However, from an engineering point of view it is AMAZING.
      09-29-2010, 09:37 PM   #8
TunedM2C
TunedM2C's Avatar
852
4,190
Drives: 2016 LBB M2
From the Paris reveal.
      09-30-2010, 12:23 AM   #9
graider
graider's Avatar
35
2,406
Drives: py/kiwi e46 m3
look like a toy somehow. don't feel it yet, the spec is amazing though.
      09-30-2010, 01:02 AM   #10
TK-421
Registered Sex Offender
624
4,757
Drives: E46 M3 | 1JZ S13
The holes over the engine bay looks flat out retarded - reminds me of the baby toy where you put the shape in the corresponding hole. Other than that it's pretty sick, especially the specs.
Stop putting stuff like painted reflectors and premium package in your signature. You're embarrassing.
      09-30-2010, 01:37 AM   #11
Garduna
Garduna's Avatar
167
4,013
Engineering can stay or keep on getting better but that exterior look needs to be tweaked I think
      09-30-2010, 02:41 AM   #12
Los Angeles
Steve Forte Rio
155
2,392
Drives: 08' 328i
Cool specs.
Ugly car.
      09-30-2010, 02:59 AM   #13
akak1997
akak1997's Avatar
73
1,159
Drives: BMW 135 @ 135mph
2008 135i  [0.00]
Video
http://video-player.edmunds.com/serv...d=621136389001
      09-30-2010, 04:27 AM   #14
ponch_ki
ponch_ki's Avatar
60
297
Drives: cars
dont like how it looks like... wth are those red accents on the front and on the gas caps? looks like a squeezed up reventon...
2008 AW E92 M3 (sold ) Amuse Ericsson Exhaust, Amuse Trunk, Vorsteiner Lip, BMW Performance Seats, AA SSK, AA Pulley, Gruppe-M Intake, BBS 19" LMs, AP Racing BBK
1994 BMW E36 M3 Euro (Track Car)
      09-30-2010, 10:20 AM   #15
Boost Gomez
Boost Gomez's Avatar
54
2,359
Drives: C63 AMG
2007 BMW 335i  [0.00]
The engineering is amazing, but I'm not a fan at all of the Hot Wheels design and cheese grater engine bay cover.
      09-30-2010, 10:47 AM   #16
KingOfJericho
KingOfJericho's Avatar
2459
7,341
Drives: Yes
2010 135i Coupe  [5.26]
I actually really like everything about this concept. Lotus figured out a long long time ago that you can make a competitive sports car without having it weigh as much as a Phantom. The Murcielago was a cannon of a car while Lotus was making sniper rifles. It's great to see a car company like Lambo shifting to this type of car as well. I welcome a tossable beast whose strong points you can actually utilize over a useless top-speed bragging-rights-mobile.
The views and opinions expressed in this post are those of the author and do not necessarily reflect the official policy or position of Bimmerpost.
2018 Jeep Grand Cherokee High Altitude Hemi | 2010 S4 Sold | 2010 BMW 135i Retired | 2006 Lotus Exige Sold
      09-30-2010, 01:14 PM   #17
scalbert
scalbert's Avatar
159
5,776
Drives: '13 S4, '15 Q7
I find it looks like Lockheed Martin aided in the design. Perhaps radar guns are useless against this.
      09-30-2010, 01:36 PM   #18
MediaArtist
There is No Substitute
MediaArtist's Avatar
79
1,186
Drives: Audi A6, 997 GT3 RS, E90 335i
Like.
'13 Audi A6
'07 Porsche GT3 RS
'08 BMW E90 335i
      09-30-2010, 08:54 PM   #19
bavarian19
bavarian19's Avatar
558
18,849
Drives: Car
      09-30-2010, 11:31 PM   #20
Memphis1
Memphis1's Avatar
97
1,838
Drives: Z4 SDrive 35i
it looks like a lancia stratos with a body kit
      10-01-2010, 01:45 PM   #21
ianbiz
Back in a BMW
ianbiz's Avatar
211
5,208
Drives: 2015 335i Msport
why dont they just call it a Gallardo Sesto? They arent fooling anyone.
Ian
      10-01-2010, 10:14 PM   #22
pmeloche
pmeloche's Avatar
24
1,604
Drives: 2013 F25 X3 xDrive35i
Sesto Elemento is inaccurate. The periodic table has only one element since Chuck Norris recognizes only the element of surprise.
Patrice
2013 F25 X3 xDrive35i Vermillion Red
