BMW 3-Series (E90 E92) Forum
Complete N55 tuning
09-10-2010, 07:01 PM | #1 |
1748
Rep 17,960
Drives: A Lot
Garage List 2018 Ducati Panigal ... [0.00]
2016 Mazda CX5 [0.00] 2017 Aprilia Tuono ... [0.00] 2019 BMW M2 Competi ... [0.00] 2015 BMW M5 Competi ... [10.00] 2016 Ducati XDiavel S [0.00] 2016 AMG GT S [0.00] 2011 Ferrari 458 It ... [0.00] 2017 Charger Hellcat [0.00] 2015 KTM Super Duke ... [0.00] 2016 KTM RC390 [0.00] |
Complete N55 tuning
Hi guys,
We finally finished porting over v4 to the n55. This is not a "entry level" tune. I don't know what that is. Kinda like an "entry level" jockstrap. You either know how to protect your goods and you do so. Or you don't and cross your fingers. So all the usual goods are functional: Timing control, Autotuning, Command Center, wastegate compensation, full diagnostics, code reading/clearing, in-dash gauges for boost/meth/afr, etc,. A few things we've learned about the n55: 1) On pump gas, expect 340-350whp/370-380lbt-ft TUNE ONLY at 14-15psi peak. This is in line with tune only n54 engines. But unlike the n54, don't expect there to be another 100whp waiting to burst out with full mods and race gas/meth. The turbo won't support it by the looks of it. Judging by wastegate DC logs, I'd guess that the most we'd see after adding full mods and race gas is in the 380-390whp range. But i'd love to be wrong 2) A 340whp n55 with 7DCT feels about as fast as a 380whp n55 with 6AT/MT. The engine is always in the right gear and doesn't lose an ounce of steam between gears. Truly exceptional. Shifting manually results in zero throttle closure and aboslutely no loss of boost between gears. The only time you see a boost drop/throttle closure is when you let the transmissions shift itself at 7000rpm (see log below) 3) The new n55 DME has completely different knock control logic than the n54 DME. Namely, you can actually get the engine to knock audibly if you just raise boost and don't retard timing through the tune. So sloppy boost-only tuning will not work. And when the engine knocks, you can certainly hear it! So play with boost controllers at your own risk. 4) The n55 is more responsive than the n54, all things equal. Especially in the midrange where it will easily light up the tires in a 2nd gear roll on. Pretty amazing. There is less turbo so the reduction in lag is understandable. But the smoothness of the engine during these boost transitions is incredible. There really is something to Valvetronic. 5) Unlike other Valvetronic engines, there is a throttle body. But unlike in conventional engines, it works very differently. Don't be surprised to see the throttle blade fully open at idle once your car warms up. Pretty neat seeing it work the way it does to reduce pump loss/improve VE during different driving conditions. During the tuning process, I displayed CAN throttle blade angle on my oil temp gauge just to learn how the throttle blade worked in a traditionally throttle-bladeless Valvetronic engine. 6) The MAF sensor is different. Not only does it Frequency based, it also reads inverse. So low airflow reads high freq and high airflow reads low freq. The MAF plays a big role in the engine tuning. Lot bigger than I initially expected. 7) The ignition timing tables are different. In general, the n55 runs 2-3 degrees less ignition advance than the n55. I'd guess that most of that has to do with the better cylinder filling the Valvetronic engine provides. More info to be posted early next week. This includes some tasty dyno results, pricing and availability. Cheers shiv Last edited by OpenFlash; 09-10-2010 at 07:22 PM.. |
09-10-2010, 07:06 PM | #3 |
30
Rep 1,748
I don't understand that statement? Everything he's developed up till now has been all about the N54... He's not abandoning the N54, but he is providing a long awaited product for the those of us who have made the change over to the N55...
I highly doubt you have to worry about him forgetting about the N54...
BMW X5 35i: Boopie Exhaust & Intercooler, K&N Drop in Filter, JB3 (3+ psi) 2013 Dodge Challenger R/T: CAI, Catch Can, Custom Exhaust, Headers, 87MM Throttle Body, Diablo Custom 93 OCT Tune |
09-10-2010, 07:56 PM | #6 |
16
Rep 420
Drives: 2011 e90 335 ix, 08 335i e92 6
oooh im loving this!! my G37 i had the cobb accessport and made 3whp at 7700rpm lol....
so im guessing there will be only one tune? not 3 stages??? |
09-10-2010, 08:01 PM | #8 |
125
Rep 3,004
09-10-2010, 08:02 PM | #9 | |
1748
Rep 17,960
Drives: A Lot
And don't worry, both the n55 and n54 will be developed in parallel. They use the same exact Procede unit with only minor changes to the firmware Shiv |
09-10-2010, 08:06 PM | #10 |
16
Rep 420
ya i had to shed my hair gel and ass hair lol....
thanks shiv!!! cant wait to get final everything on this and for the damn car to get in !!!!!! |
09-10-2010, 08:13 PM | #11 |
D.D.S.
31
Rep 460
+100000000000 for using the same PROcede unit...i can swap to new car later in a couple years
Current: Jeep GC Overland Hemi 4x4
TOTALED: 2012 AW X5d with Sport+Prem, (Heartbroken how she left me) RETIRED: 2009 SG e92 M-Sport( I will miss you....) |
09-10-2010, 08:19 PM | #12 | |
52
Rep 428
I have a meth kit here and read to go on it soon |
09-10-2010, 09:14 PM | #13 |
1748
Rep 17,960
Drives: A Lot
BTW, here's one of the earlier dyno graphs from a couple weeks ago before we had control of the throttle blade:
Stock vs Stock with Procede. 91oct. No other mods. Since then, we've made some major improvements (full throttle blade control, improved PID logic, better ignition mapping, etc,.) Basically to the point where we feel it is ready for customers. Going back to the dyno this week for some final numbers. Should be even better Cheers shiv |
09-10-2010, 09:39 PM | #14 | |
30
Rep 1,748
How do you develop a specific tune for the 8 speed, if majority of the n55's are running 6 or 7 speed tranny's. Not asking for a release of trade secrets, just curious how you plan to develop a specific tune for a vehicle such as mine...
09-11-2010, 04:30 PM | #15 |
87
Rep 302
Drives: 2022 X3MC BSM/SO
Sweet! I can't wait to buy one of these!
09-11-2010, 04:34 PM | #16 | |
1748
Rep 17,960
Drives: A Lot
09-11-2010, 06:52 PM | #17 |
325
Rep 2,663
Drives: BMW 335xi Sedan; BMW M3 ZCP
Are the x5 and 535 the only one that share the 8 speed at?
335xi Sedan 6AT | Weather(70-85°F) | N54 Tune Comparison Chart || N54 Turbo Upgrade Comparison Chart
-PROcede Rev. 2.5 ~ v5 (3/17 maps) / JB4 (8/21 maps) / COBB (Stg2+FMIC LT Aggressive maps) †Procede Map2(UT 45 - IGN 40) Aggression Target 2.0 | 0-60 in 4.0sec || †Cobb E30 LT (35% Ethanol/65% 93 Octane) | 0-60 in 3.9sec AR Design Catless DP | BMS DCI + OCC | ETS 5 FMIC | Alpina B3 Trans Flash |235/265 19" Michelin PSS |
09-11-2010, 07:37 PM | #18 |
30
Rep 1,748
I believe so... Odd if you ask me, that those are the only two that share that tranny... But whatever floats BMW's boat...
09-11-2010, 09:35 PM | #19 | |
15
Rep 506
09-12-2010, 01:40 AM | #21 |
Rollin
Rep 66
For those are pros in this tune game. Is it advantageous to have a p3 gauge installed before the tune or does V2 have everything I'll need for diagnosis? Since P3 is not PnP for the N55 I'm hesitant to tap my manifold for it.
09-12-2010, 09:07 AM | #22 |
314
Rep 3,262
There is such a big dip in torque on the stock N55 until 4500RPM that I find it hard to believe it feels better than the N54.
