BMW 3-Series (E90 E92) Forum
N55 Update #2!
07-15-2010, 06:19 AM | #1 |
Joint Chiefs of Staff
4925
Rep 116,006
N55 Update #2!
Got some more sneak-peak photos to share with you guys!
The first is the N55 control box and fully PnP harness. It's setup for an OEM look and super easy install! Start to finish you're looking at around 15 minutes to install or remove it. The harness is fully modular so as later stages are released in the future you'll just snap any extra connectors needed in to the harness. Second is a N55 beta log. The Stage1 tuning among other things features adjustable boost and in this log its set to +3psi over stock. Which is the default Stage1 level. Mike . |
07-15-2010, 08:07 AM | #3 |
159
Rep 5,689
Cool
Legal Disclaimer: Anything I or anyone else says about my vehicle on this website(1addicts.com or any affiliated or nonaffiliated sites), pertaining to modifications, is only to gain acceptance from my/our peers, and does not actually represent anything actually existing on my car, and thus, cannot be held against me in any issues, i.e. warranty claims, that may arise.
07-15-2010, 09:00 AM | #8 |
161
Rep 7,377
maybe they cant read rpm yet, basically a jbplus setup.
07 335i AT - MOTIV 750 - MHD E85 BMS flash - BMS PI - JB4G5 - Okada Coils - NGK 5992 Plugs - Helix IC - Snow Stg. 3 - Stett CP - Custom midpipes with 100 HJS Cats - Bastuck Quad - PSS10 - QUAIFE LSD - BMS OCC - Forge DVs - AR OC - ALCON BBK - M3 Chassi - Dinan CP - Velocity M rear Toe arms - Advan RZ-DF - LUX H8 - Level 10 AT upgrade
07-15-2010, 09:13 AM | #9 |
314
Rep 3,262
Looks very professional ! I can only imagine what a fight is now between the two piggyback tuners to lure the first N55 customers
07-15-2010, 09:24 AM | #10 |
442
Rep 18,331
If I had a N55, I would wait till both parties comes out with their tunes and not jump the gun and buy the first thing that comes out....
07-15-2010, 11:15 AM | #11 |
4925
Rep 116,006
LOL yes, the RPM and TPS plots have been hijacked for other channels. I wonder if the crack detective team can guess what RPM actually represents?
Mike |
07-15-2010, 11:25 AM | #14 |
159
Rep 5,689
Any dyno?
07-15-2010, 11:35 AM | #15 | |
184
Rep 2,842
Last time over on N54tech I was the first to guess right and didn't get a prize at all. |
07-15-2010, 12:20 PM | #17 |
324
Rep 2,663
Drives: BMW 335xi Sedan; BMW M3 ZCP
Nice Progress..
Is the green line ignition timing? Which one one those connects to the CANbus? Why didn't Terry make the N55 JB3 board the same as the N54 JB3 board? They look almost alike. I know Shiv has mentioned keeping the same N54 Procede and just changing the harness which makes it easier on us consumers which are likely to upgrade to a new engine. From Terry "Here is a shot of the N55 Stage 1 board (below) and the JB3 board above. They are based on the same 8-bit 18F2431 processor but with a slightly different implementation. Because of these differences the N54 JB3 and N55 JB3 Stage 1 will not be interchangeable..."
335xi Sedan 6AT | Weather(70-85°F) | N54 Tune Comparison Chart || N54 Turbo Upgrade Comparison Chart
-PROcede Rev. 2.5 ~ v5 (3/17 maps) / JB4 (8/21 maps) / COBB (Stg2+FMIC LT Aggressive maps) †Procede Map2(UT 45 - IGN 40) Aggression Target 2.0 | 0-60 in 4.0sec || †Cobb E30 LT (35% Ethanol/65% 93 Octane) | 0-60 in 3.9sec AR Design Catless DP | BMS DCI + OCC | ETS 5 FMIC | Alpina B3 Trans Flash |235/265 19" Michelin PSS Last edited by AltecBX; 07-15-2010 at 12:26 PM.. |
07-15-2010, 12:45 PM | #18 | |
4925
Rep 116,006
For the "RPM" plot I'll give a hint. The signal is coming from one of the plugs on the wiring harness. Mike |
07-15-2010, 01:11 PM | #19 |
146
Rep 1,922
Drives: E90 335i, E70 X5
so stage 1 is running roughly ~13psi peak?
-eric
E90 335i TiAg *STOCK* see my garage for mod list.. E70 X5 SGM *try to stay stock* :/ |
07-15-2010, 02:00 PM | #20 |
198
Rep 2,485
Would I assume that the N55 box doesn't go in the ECU compartment then?
Just thinking 24 months ahead
2006 E90 330i (retired)
2009 E90 335i (retired) 2012 E70 X5 50i M Sport (retired) 2016 F10 535i M Sport |
07-15-2010, 02:08 PM | #21 |
1043
Rep 3,622
07-15-2010, 03:21 PM | #22 | |
4925
Rep 116,006
Mike |
