10-30-2006, 07:06 PM | #1 |
20
Rep 489
Computer Guru's, I need help!
I keep getting a message from my computer telling me that I have low disc space. I want to buy an external hard drive to put my music and pictures on. Could I just completely move my Itunes to this hard drive? Would I be able to access my Itunes whenever I wanted? If I move all my music onto an external hard drive will I still be able to update my Ipod when I need to?
I know this post may not be too clear, please ask if you need clarification, thanks! |
10-30-2006, 07:10 PM | #2 |
24
Rep 972
Drives: people mad
Yes
__________________________________________________ __________________
2006 BMW 325i, Jet Black, 6MT, ZSP, Black Leather, Aluminum, Power Seats, Logic 7 |
10-30-2006, 07:46 PM | #5 |
***** noob
1439
Rep 10,477
get external HDs or Burn it on DVD....whichever fits you
2006 325xi (Sold)
10-31-2006, 12:47 PM | #6 |
590
Rep 7,519
Drives: 2009 E90 335i MT
Once you've moved the music and photos from your internal hard drive you can then delete them. Then do a complete backup of everything that's left. Afterwards, run defrag.
2009 E90 335i Montego Blue · Black Leather · Burl Walnut · 6MT · US Spec
SatNav • ZPP • ZCW • 6FL • TPMS • iDrive • PDC • HWS • Xenons • BMW Assist • Power Rear Sunshade • Logic 7 European Taillights • Rear Foglamp • OEM Alarm • PicoTray • DataToys XM-DVR • Multi-view Processor Quaife ATB LSD • Short Shift Knob • Hartge Anti-Roll Bars • AP Racing Front Brakes • 19" Style 269 |
10-31-2006, 07:59 PM | #7 |
378
Rep 5,842
Drives: 2006 325xi
NOOOOOO!!!!!!!!!!!!!!!!!!!!!!
ok, just joking. ya its fine to do |
10-31-2006, 08:08 PM | #8 |
19
Rep 34
Often it's much cheaper to buy an Internal HD and External HD case then it is to buy an external drive.
I used an old Maxtor 120 I had and bought an External Case for $15 from NewEgg.
I r oph topicness.
11-01-2006, 08:31 AM | #9 |
378
Rep 5,842
Drives: 2006 325xi
Good point, do you have a laptop or desktop, if you have a desktop just get an extra internal drive, you can get something like a 60gb for close to nothing
11-01-2006, 09:16 AM | #10 |
Rep 112
I got this setup and it works great and is small so it won't take up a lot of desk space as well as easy to travel with.
2.5 External Enclosure $24 http://www.newegg.com/Product/Produc...82E16817145135 100gb laptop hard drive $91 http://www.newegg.com/Product/Produc...82E16822145116 This works great as it is powered by the USB 2.0 cable that is connected to your computer so it is truly portable (USB 1.0 requires a power supply or the use of 2 USB ports). |
11-01-2006, 10:11 AM | #11 |
24
Rep 972
Drives: people mad
Firewire baby is the way to go
11-01-2006, 11:42 AM | #12 | |
20
Rep 489
11-01-2006, 03:25 PM | #13 |
Rep 112
Yea, You just take the hard drive and attach it to the board (really it is very simple, you just plug it in and it will only go one way) Then you place the board with the hard drive connected into the case (it just slides in and again it only goes one way) and screw the case closed and poof your done.
11-01-2006, 03:44 PM | #14 |
19
Rep 34
Using a 2.5" HD is nice because it is powered by the cable. a 3.5" HD needs a power source (AKA wall plug for an external case) but you can get easily 3-4x as much space on a 3.5 for the price compared to a 2.5".
Example: A 300-400gb internal 3.5" drive runs around $100-120. Meanwhile a 2.5" laptop drive will only get you around 100gb for $100. For both external cases run around $20-$30. If you have the easy capabilities to use the 3.5" that has to be plugged into the wall, it's the easy choice.
I r oph topicness.
11-01-2006, 03:45 PM | #15 |
19
Rep 34
I could take mine apart and show you some pics really quick on how you install it so you can make sure it is something that would would be comfortable doing (I know people that HATE touching electronics.)
I r oph topicness.
11-01-2006, 04:33 PM | #16 |
20
Rep 489
thanks guys, i am the least technically inclined person there is. gmcwv where can i get one of these 300-400 gb drives for such a good price? Im basically looking for the most space for the best deal. I would like to spend at most 130-150.
11-01-2006, 04:58 PM | #17 |
19
Rep 34
You won't be able to find a 2.5" HD with that much space for that price.
The 3.5" drives can be found around that price. http://www.newegg.com/Product/Produc...SubCategory=14 And the External Enclosure: http://www.newegg.com/Product/Produc...82E16817180004 $147.98 + Shipping and you got yourself 400gb on tap, easily accessed from any computer with a USB port. I agree FireWire is better, but there is always the time that I wanted to bring my HD to a friends house to transfer files and he didn't have a firewire port. So I switched to USB2.0.
I r oph topicness.
11-01-2006, 04:59 PM | #18 |
19
Rep 34
The pictures of the enclosure show exactly how easy it is to put together. Connect the two cables (One power, one data. And they only fit one way so you can't get anything confused), use the four screws to mount to HD inside the case, and put the two pieces of the case back together. Then plug it in and turn it on!
I r oph topicness.
11-02-2006, 12:51 PM | #20 |
20
Rep 489
http://www.newegg.com/Product/Produc...82E16817994036
http://www.newegg.com/Product/Produc...82E16822144701 will this combo work, seems like a great deal. Also, will I need to buy any more accessories, like a usb cable, to fun this setup? |
11-02-2006, 02:46 PM | #21 |
Rep 112
The ICY Dock appears that it goes inside a PC tower. Here is the link from the manufacture site http://www.icydock.com/product/mb337.htm So I don't think this is going to work for what you want.
If you follow this link anything that shows up here ought to work for you as an enclosure for a 3.5in drive http://www.newegg.com/Product/Produc...k=&srchInDesc= If that link doesn't work for some reason let me know and I will help you nav through neweggs site to find what you need. (newegg is not the only place to get these items....just easier to show you what you need, and the prices are really great too). CriagG is right that if you rather have a bigger drive that 3.5in is better than the 2.5in and that I would too stay away from firewire. Even though firewire is faster not everyone has a firewire port, and at least if people don't have a usb 2.0 they at least have a 1.1, it will still transfer just not as fast. Plus you also want to look for a drive that runs at about 7200RPM though 5400RPM is not shabby just one of those faster is better things, and that just means how fast the drive can spin. |
11-02-2006, 05:23 PM | #22 | |
20
Rep 489
