      01-27-2010, 06:49 AM   #1
Dec540
Australia
139
679
Drives: G80 M3
To L or not to L?
Hey guys,
I'm going to be purchasing a brand new 50D in the near future but can't decide what lens i should get. I'm tossing up between the EF-S 17-55 f2.8 or the 24-70mm L series f2.8. I have read reviews of both and they both sound like awesome lenses.
Pros of the 17-55mm : Its $400 cheaper, its wider (i like doing close ups etc. so the extra 7mm will most likely make a difference.
Cons : It can not be used with a full frame sensor so when i upgrade to a 5D in 18months or so i will have to get a new lens. Apparently the L's are weather sealed but the 17-55 is not.
Any other pros/cons? Any recommendations? I've been thinking I'm best off buying a lens for the camera I'm buying now and not the one i may buy in the future
      01-27-2010, 08:13 AM   #2
radiantm3
Apex Everything!
radiantm3's Avatar
1007
4,378
Drives: 2007 Honda S2000, 2017 GT350
2011 E92 M3  [9.35]
2014 BMW i3  [10.00]
EF-S is designed for a crop camera so comparing a EF-S @ 17mm and EF @ 24mm is a bigger difference than you think. It's not just a 7mm difference on a crop camera.
L lenses are (generally) going to be sharper, provide a much better image quality, bokeh, and better colors. After you own an L lens, you won't want to buy anything else. That could be a con. :P
However, if you need something wider, then you might not have much choice. I bought the EF-S 10-22mm back when I had a crop. I was in the same scenario as you (only I wanted an ultra-wide). I wanted to get the L ultra-wide, but knew it wouldn't be wide enough on a crop camera. So I just went with the EF-S. Used it for a year and sold it when I moved to full frame. Lenses hold their value fairly well as long as you take care of them.
Another option for you is possibly going with the 16-35mm/2.8 L? That could be wide enough for your needs on a crop for now and will be a must-have lens once you go full frame.
2011 E92 M3(Sold). 2007 Honda S2000 (Track Car). 2016 Cayman GT4 (Sold). 2017 Shelby GT350 (AKA Crowd Killer).
My pet project: https://stickershift.com
      01-27-2010, 09:16 AM   #3
Derek Zoolander
97
1,873
Drives: 09 E90 M-Sport
L if you can afford it.
      01-27-2010, 09:27 AM   #4
888
I'm takin' the day off.
888's Avatar
South Africa
111
339
Drives: M
as per radiantm3,
go for what is best for your needs now. if you get the 17-55 you will be able to sell both. If cash is tight consider a secondhand 40D. 18 months is a long time in the photography world. the 17-55 is basically an L just without the red ring.
If I were to agree with you we would both be wrong.
      01-27-2010, 11:14 AM   #5
remmib
remmib's Avatar
Norway
1586
29,215
Drives: 2013 F10 520d M-Sport
If you're only going for one lens, go with the 17-55, because the 24-70 is not wide enough on a crop body, so you need a second wide lens like the 10-22.
      01-27-2010, 11:19 AM   #6
vachss
56
816
Drives: Z4 Coupe
The 17-55/2.8 is widely regarded as the best zoom lens in the EF-S system. While its build quality isn't up to L standards its optical quality certainly is. The EF-S system isn't going anywhere, and if you go full frame you'll find it easy enough to sell the 17-55.
My advice would be to find one used for about $800-850. When/if you need to sell it you'll be able to turn it around with minimal loss.
      01-27-2010, 11:20 AM   #7
E92NV
12
283
Drives: E92 alpine white
I would get the 24-70. I had the 17-40 and I just sold it bc i needed more reach instead of the wideness.
wtb: tial bov w charge pipe, Injen intake
      01-27-2010, 01:05 PM   #8
ichiban
ichiban's Avatar
102
2,012
Drives: 08 135i
I'd say if your planning on going to FF in 18 months, i'd still say you should pick up the 17-55 2.8 IS because of the 3 stop IS, it's a very sharp lens and a lot of pro photogs keep a crop body with them just so they can use this lens. I think during the 18 months, the 17-55 is a better focal range for you to develop your photographic eye and reflexes which i think is more important than gear. And besides, the 17-55 2.8 IS keeps it's value very well and there doesn't seem to be a successor in line unlike the 24-70 L which is due for mark II.
IMO, buy a used 17-55 2.8 IS, and sell it to fund for a 24-70L when you go FF.
      01-27-2010, 01:05 PM   #9
PNF
PNF's Avatar
Taiwan
175
2,355
Drives: 15' YMB F80 M3
umm.. 17-55mm f2.8 is just as sharp as the 24-70L. 17-55mm also has IS, while 24-70L does not. It makes a difference if you do a lot of indoor shooting or your hand isnt exactly steady.
The only real downside of 17-55mm is, IMO, it is not FF capable and it is not L. Weather-sealed or not, that doesnt really make a big difference unless you shoot in extreme conditions often (say in desert most of the time, in extreme cold or hot weather, etc).
24-70mm is not even close to wide enough if you use that as your only lens and walk around lens.
OR get this
16-35L MKII. its wide enough, its a L, its sharp.
In Summary, 17-55mm IS USM is certainly built like a L and performs like a L.
PS. You're getting a 50D? I might be considering selling mine. (in excellent condition and still have all original box/manual/everything). Have used this for about 9 months now.
PM me if you're interested.
2015 F80 Fully loaded (minus the CCB) YMB M3 / Individual Amaro Brown
BBS | KW | Vorsteiner | IND | Akrapovic | BMW CF Performance Interior | Brembo | Eibach
2008 E92 335i (sold)
      01-27-2010, 01:06 PM   #10
PNF
PNF's Avatar
Taiwan
175
2,355
+1
      01-27-2010, 01:06 PM   #11
bosstones
1249
1,600
Drives: o_0
+1. I have a crop cam and ended up with 2 lens in both those focal ranges. I started off with the 24-70 and needed something wider. Love the 10-22, though.
Depends on what you tend to shoot, though (obviously). I only take occassional telephoto/zoom shots so I just suffer without. 90+% of my pix are close or require something wide so I'm a little biased...
      01-27-2010, 10:32 PM   #12
Dr_Jones
75
1,027
Drives:
Originally Posted by 888 View Post
as per radiantm3,
i want something fast in this range. What a horrible hobby.
I went the second hand 40D route. great camera...probably too much for my hands. but i would say 'give a 50d a hard look' as i think the prices are better than when i purchased courtesy of 7d and you may be able to get another stop of useable ISO.
17-55 FTMFW
Just like Indiana...I love my whip
      01-28-2010, 05:07 AM   #13
ichiban
ichiban's Avatar
102
2,012
Drives: 08 135i
As a matter of fact, I have a LN 50D for 850 and it comes with canon grip, extra battery and has every that came with it brand new except for the box. I do have the box for the battery grip tho. Let me know if your interested. I can take some pictures as well.
      01-28-2010, 06:32 AM   #14
Dec540
Australia
139
679
Drives: G80 M3
Thanks guys, some very valid points. I think i will be going for the 17-55 as its got the IS and because it has a much for usable focal range for my style of photography.
PNF - I have just purchased wheels for my car so it looks like it will be at least another month until i have some spare cash for a camera. That and being in Australia i figure i'm better off buying one over here so i have the warranty etc.
