10-08-2009, 12:36 PM | #1 |
10344
Rep 14,457
Runners: Advice/thoughts please.
I do the gym thing four days a week and have started hitting the tread mill at the end.
I have never been a "runner" and am experiencing pain in my shins. It gets to the point after only about a quarter of a mile that I need to slow down to a fast walk or cut it off. Wearing good Asics running shoes. My buddy is even older than I am and he is next to me going at it like the wind. Of course this can't happen. Am I poop out of luck or do I need to just get through the pain until my shines figure out what is up? I am not tired by any means. Just pain. I want to be able to start going on night runs etc. Going for a bite. Hopefully when I get back someone will have told me to try this or that. Thanks!
Crazy Diamond
10-08-2009, 12:49 PM | #2 |
I'm kind of a bitch
400
Rep 895
You probably have shin splints. They typically occur when you switch surfaces that you run on. I used to get them when I would switch from field hockey season to basketball season.
Try (and this sounds silly) getting on your back and bending your knees and just drawing the alphabet in the air with your toes. You should probably stay off of them for a week or so and then try. If you push it too much, they can actually turn into a stress fracture. Also ice and you can try taping them, but I don't feel that works really well. Good luck!
E93: Montego/Cream <---- E46 (Coupe): JB/Black <---- E30 (Cabrio): Alpine White/Black
10-08-2009, 01:22 PM | #4 |
559
Rep 18,123
Your shoes may not be right for you. Are they worn out? Try going to a Road Runner Sports and see if they can see what type of shoe suits you the best depending on your natural gait/running style/etc..
http://www.dickssportinggoods.com/in...egoryId=222919 This might not be the cure-all but it might help. At stores like Road Runner sports they have treadmills and video cameras that capture the way to run for free.
Current: 2010 Alpine White 335D LCI l 19" BBS LMs l KW V2 Coilovers l BMW Performance Grilles l MSport Front/Rear l Karbonwerke Trunk l F1 Pinnacle Tint 35% Former: E92 Space Grey 335i Latest pics |
10-08-2009, 01:22 PM | #5 |
66
Rep 1,352
My 2 cents
Sounds like shin splints. The common factor in shin splints usually (not always) is overprontation of the lower extremities (a falling in toward the center line of the body) caused by glutes that don't work due to weak deep abdominal wall musculature. The glutes decelerate pronation so when they don't work (or function) you get overpronation of the lower extremities resulting in an overpronation injury such as shin splints. Because I cannot assess you this may or may not be the case, but it should offer a start point.
I would not run with pain as the body will naturally try to avoid the pain resulting in dysfunctional motor engrams or movement patterns thereby creating compensation and more dysfunction. Pain is the body's signal that something is wrong. Don't ignore it. Some people simply are not stable enough to run and must prepare the body to due so. The rule is stability before mobility or injury will result at some time. Possibles as to why your shin splints occur - weak "core" overpronation muscle imbalance/postural issues weak anterior (front) of lower leg weak calves, tight calves poor movement mechanics/running form improper footwear/arch support weak posterior (back side of the body) Rehabilitation - improve core stabilization - weak core = unstable pelvis = unstable hip, knee, ankle, glutes that don't function, and overpronation assess posture and correct imbalances (seek professional help in this matter if possible) assess gait/running mechanics assess footwear stretch/foam roll - hips, IT band, hamstrings, quads, calves, hip flexors (psoas), back; improve ankle mobility and stability strengthen the anterior tibialis (front, lower leg) strengthen entire posterior chain (calves, hamstrings, glutes, back) - weak posterior = compensation improve strength, stability, and flexibility at the hips to minimize compensation |
10-08-2009, 01:33 PM | #6 |
10344
Rep 14,457
Thanks people.
^ This one flared off a slight AADD attack. I made through it though. I am strong, if you will, but have never ran much. I had lunch with a nurse friend, very athletic, and she said try the elliptical machine for awhile. I'll give that a shot and try again in a week or so to see if I have gained some strength in them ol' shins. By know means do I have grapefruit calves or tree trunk thighs. Hopefully after some work my legs will be better suited to run. When it's leg day at the gym I cringe, if that tells you anything. Shoes are nearly new and fit like a glove BTW.
Crazy Diamond
10-08-2009, 01:41 PM | #7 |
91
Rep 2,323
i have shin splints...they friggin suck.....they wont go away and I haven't done any strenuous activity in the last two weeks.
"You will get there, but it is up to you and you alone. It is what you are willing to do, and how you are willing to get there. You must be relentless, you must be tireless, you must pursue at all costs, so that you are ready, when the time is right." -Dad
10-08-2009, 01:42 PM | #8 |
559
Rep 18,123
Fit isn't everything Gonzo.
10-08-2009, 03:44 PM | #9 |
Rep 7
Another thing that you can do to help with shin splints, as per suggestion of my cross country coach:
Lay stomach down on your bed with your feet hanging off the edge of the mattress. Then curl your feet up to push into the mattress. After about a week or two, it should get better. Worked for me and a few others on the team. Good Luck. |
10-08-2009, 03:50 PM | #10 |
Rep 81
eat bananas... i've heard the potassium in them helps.
i used to get shin splints from too much running/basketball when i was younger, but i started eating a banana a day back when i was in college and have continued until now, and don't get shin splints anymore. |
10-08-2009, 04:48 PM | #11 | |
152
Rep 1,173
10-08-2009, 04:55 PM | #12 | |
559
Rep 18,123
I suggest the OP actually read the link I posted as there are different model ASICS for different body types/movements: for ex: (taken from roadrunnner) Stability (81) Stability Plus (35) Performance Stability (16) Neutral (82) Neutral Plus (23) Performance Neutral (14) Motion Control (9) Motion Control Plus (10)
10-09-2009, 09:36 AM | #13 |
10344
Rep 14,457
^ I was not blowing you off. I just got back to this thread.
I may give this "fit" thing a whirl and see what they conclude. Tried the elliptical machine after working back and shoulders and they started to sting on it too.
Crazy Diamond
10-09-2009, 10:45 AM | #14 |
14
Rep 465
When I run on a treadmill I also get some pain in my shins, I do a stretch that helps them that you may want to try. I bend at the knees like I am squatting and go all the way down till your ass hits your ankles, stay in that position and lift your toes to the sky, that seems to give me a very good stretch.
"Barzini is dead. So is Phillip Tattallgia. Moe Green. Slacci. Cuneo. Today I settled all family business so don't tell me that you're innocent. Admit what you did"
