09-12-2006, 01:58 PM | #1 |
Got Seoul?
118
Rep 2,862
Drives: 2012 535i MSport
Need Computer Guru Help!
My Sony 80GB hard drive is near full and slowing me down. I have removed most of the junk software installed but not much else I can do. I have a D: drive that has 40GB of space left but applications are needed on C: drive so cannot move things over. Besides replacing the internal hard drive what external hard drive is out there that is user friendly and actuall works! I have looked at Maxtor but read bad reviews. I looked at Western Digital, Seagate, Sony Giga Vault. Need some good advice! Thanks!
Can you say Alooooha?
[SIGPIC][/SIGPIC] |
09-12-2006, 02:30 PM | #2 | |
title not available
Rep 21
Swap out your D drive
Robert
09-12-2006, 02:46 PM | #3 |
hmmmmmmmm
18
Rep 570
You can make the D: drive the slave and put all your miscellaneous files in there. If you want an external drive, you can make your D: drive into a external drive by buying a drive enclosure.
09-12-2006, 05:27 PM | #4 |
586
Rep 7,519
Drives: 2009 E90 335i MT
Defrag!
2009 E90 335i Montego Blue · Black Leather · Burl Walnut · 6MT · US Spec
SatNav • ZPP • ZCW • 6FL • TPMS • iDrive • PDC • HWS • Xenons • BMW Assist • Power Rear Sunshade • Logic 7 European Taillights • Rear Foglamp • OEM Alarm • PicoTray • DataToys XM-DVR • Multi-view Processor Quaife ATB LSD • Short Shift Knob • Hartge Anti-Roll Bars • AP Racing Front Brakes • 19" Style 269 |
09-12-2006, 05:57 PM | #5 |
375
Rep 5,842
Drives: 2006 325xi
Defrag, also dont forget Adaware,
You can always find a copy of Partition magic and but all the drives together... take all the free space from D and move it to C. as long as no Apps are installed on the D: drive. Try some forums for HijackThis, its a good tool One last thing, remove excess stuff from the msconfig ( if you dont know how to use it though then DONT) |
09-13-2006, 12:02 AM | #6 |
missing two turbos.
616
Rep 4,859
Drives: fast around corners.
Defrag works well if you haven't done so in past few months, especially after alot of installing/uninstalling softwares.
I had same problem as you before. I only had 80GB C:drive that came with the computer. I then bought a Western Digital 120GB external hard drive thinking that is enough. Wrong. then, I bought myself another 300GB Maxtor internal hard drive. Now even that is filling up, im thinking of replacing the 120GB external hard drive with 300GB one. by the way, the Western Digital external hard drive has been FLAWLESS. Though it does perform a bit slower than built in hard drive, since its using 2.0 USB and all, but its good enough for a back-up drive. Plug-n-play is great. I would highly recommand them. Organize your drives(if you start adding them) for your use. For me, C: drive 80GB internal = mainly for Windows XP operating system, anything that needs "installation" is here. D: drive 300GB internal = anything from Mp3s, pictures, cars, school work, etc. E: drive 120GB external = mainly movies.
06 AW E90 330i ZPP/ZSP/Step/Expired Warranty : Prior Design Front : ACS Rear : ACS Roof : BlackLines : Simota Intake : Carbon Fiber Interior Trim : : MTEC V3 : 24% Charcoal : V1 Hardwired : Solaris Invisibulbs/LED interior : |
09-13-2006, 02:06 AM | #7 |
misadventurer
60
Rep 708
maybe you should delete some of the pictures of the models that you post here. J/K
i remember you telling me you've got lots of resources. lol. for now try deleting all of your cookies and histories and empty your recycle bin and run clean up disk and defrag. if you havent tried these. it might help a little bit for now till you get a new disk or something.
325i I SP
09-13-2006, 04:47 AM | #8 |
16
Rep 24
www.newegg.com
Fast shipping great service. I built my current computer from parts I ordered from there site. A lot of people review the products they buy from there, so be sure you read what they have to say. SOME OF THE BEST PRICES TOO!!!.
330i Sport/Dakota Leather
Black ACS body kit on order ACS pedals and 30% Tint |
09-13-2006, 05:14 AM | #9 | |
292
Rep 9,218
Also ... have you really got a separate hard drive for D:\ and C:\ - from what you write it sounds like this is just a partition set up to help you keep your documents separate from the OS - this is common practice for a company laptop for example. First off there is no reason why some applications can't be installed to the D:\ drive and run from there. The easiest option to increase space is a hot swappable external (usb 2) disc drive. I have a 320gig toshiba one I bought from PC world, which I use as a back up for all photo's, mp3's and movies. My c:\ drive is 260gigs and it's nearly full, so I plan to buy an additional 260gig internal drive to slot in next to it. If you have a laptop this is less straightforward, so an external drive would be the way - but with a PC if you don't mind opening the case up fitting an internal SATA drive is easy. If your drive is running slow it may well be because it needs defragging or because you have lot's of crap clogging things up. So de-frag and adaware are a good idea. It's also a good idea to install something like autorun and switch off everything that you DON'T want to open automatically on re-boot. That will speed up you boot time markedly. You could also look at banging in a bit more memory (it you only have 256mb / 512mb and have added a lot of stuff, that may be why the PC is running slow. I also put my PC into hibernate most of the time. You can do this by holding down shift whilst the turn off / restart window is displayed - one of the options should turn to hibernate - which is an excellent time saver. |
09-13-2006, 11:09 AM | #10 |
misadventurer
60
Rep 708
hmmmm... sometimes i use a vaio laptop with a partition. it used to annoy me a lot when the C:/ fills up because i forgot to change the directory when installing an application.
TO ASIANN: have you tried reinstalling some of your applications into drive D:/?
325i I SP
09-13-2006, 01:20 PM | #11 |
Got Seoul?
118
Rep 2,862
Thanks for all the info. Yes I have done defrag when needed. This is a PC. I have 1 GB memory. Cleared the cache cookies and history. The D: has like 50GB and me and the wife split the 30GB on the C:. I think partition magic might be a good option or maybe just have to get a larger internal hard drive. I'm in the middle of moving so will have to wait until next week to actually do something. I have tried to move things over to D: drive as much as I can. Can I move some of the OS files over there?
[SIGPIC][/SIGPIC] |
09-13-2006, 01:22 PM | #12 | |
Got Seoul?
118
Rep 2,862
[SIGPIC][/SIGPIC] |
09-13-2006, 01:22 PM | #13 | |
Got Seoul?
118
Rep 2,862
[SIGPIC][/SIGPIC] |
09-13-2006, 01:26 PM | #14 | |
Got Seoul?
118
Rep 2,862
[SIGPIC][/SIGPIC] |
09-13-2006, 01:29 PM | #15 | |
Got Seoul?
118
Rep 2,862
[SIGPIC][/SIGPIC] |
09-13-2006, 01:35 PM | #16 |
587
Rep 6,563
make sure you empty your recycle bin also, do you have XP or 2000? go into the temp folder and delete all files with extension .tmp. Many of the .tmp are little but whose know, you might have a gigantic .tmp file. What ever you do, do not physicall move any OS files or you will be sorry.
If you are not familiar with partitioning or add extension on an existing partition, be very careful. Sometime you might accidentally delete a partition (if it is C, you will be very sorry). I never heard a program having to be install on c drive. Only thing that is needed on C drive is OS, other programs, MS Office or Adobe Photoshop can be installed on D drive. |
09-13-2006, 03:04 PM | #17 |
586
Rep 7,519
Before you do much more, have you made a current backup? This is very important if you're tampering with the partitions. If you get a larger hard drive you might consider getting two and an external case. Put the second drive into the case and use it as a sequential backup.
09-13-2006, 03:12 PM | #18 | ||
586
Rep 7,519
So much for Bill Gates' "640KB of memory is enough for anybody."
09-13-2006, 11:52 PM | #20 | |
Got Seoul?
118
Rep 2,862
[SIGPIC][/SIGPIC] |
09-13-2006, 11:53 PM | #21 | |
Got Seoul?
118
Rep 2,862
[SIGPIC][/SIGPIC] |
09-14-2006, 01:21 PM | #22 | |
586
Rep 7,519
