07-10-2009, 06:34 AM | #1 |
40
Rep 433
Your beloved radar detector is becoming useless!
There is a disturbing trend underway which could very well make ALL radar detectors so annoying to use, many will unplug them.
The culprit is these radar-based cruise control and blind spot systems! Where I live, it seems every high end car is equipped with them and they use K band radar, just like the cops. They are also low powered and narrow beam so they tend to not trigger the detector until you've moved into their beam and then they momentarily peg the meter. A pegged meter usually means going to max braking for me, now I coast and evaluate the situation. It's a shame the manufacturers didn't take this into consideration when they implemented these systems. Maybe they can be convinced to use a non-police radar band? |
07-10-2009, 10:27 AM | #5 |
190
Rep 1,105
Yeah...I think radar detectors where on their way out anyway. Isn't laser becoming more prevelant? Laser detectors mostly just tell you when you're about to get a ticket.
Maybe we need some sort of radar/laser jammer that skirts the FCC rules. |
07-10-2009, 10:52 AM | #7 |
13
Rep 508
The three times in my life I've been lasered, I've gotten away because I've been going too fast for the cop to get down from his hiding spot, into his car, and pull me over. K is crap. The wonderful state of Maine has installed K band radar drones on every electronic signboard in the state, but its no secret 90% of cops use Ka unless you're in the boonies.
E90 328i Space Gray/Chestnut ZMP 2MF ZP2 ZV2 ZCV ZCW-washers HK SAT 3rd Pedal ED 2011.10.10 E90 325xi BSM/Terra ZSP ZPP ZCW Adaptive Xenons SAT 3rd pedal Gone E53 X5 3.0i Black Sapphire/Truffle ZPP ZCW ZRC Xenon Nav |
07-10-2009, 10:59 AM | #8 | |
42
Rep 867
There is now way to get around the FCC concerning radar jamming. Laser (904nm) is not under the FCC, its regulated by the FDA. Lidar jamming therefore is regulated at a State level.
Not only will it kill you it will hurt the whole time while you're dying.
http://www.stevesnovasite.com/ http://www.jalopyjournal.com/forum/ http://www.garagejournal.com/ |
07-10-2009, 11:10 AM | #9 |
981
Rep 15,816
you can get a whole radar jamming/police system installed for like 3k
but then it's really illegal lol cops use more Ka here and when Laser, I just go the other way, look behind me, and hope for the best but that's only when I'm speeding. otherwise, i try to be about speed limit level |
07-10-2009, 11:16 AM | #10 |
42
Rep 867
I dont believe any of these new radar based systems utilize (or will) the same frequency spectrum as police radar. So unless the radar detector is not very efficient at filtering there shouldnt be too much of an issue.
EDIT: There are some short range systems that operate in the K band. http://www.web2carz.com/257/knowledg...t-chicago-show However it looks like these most of these systems operate well above police radar. http://www.thefreelibrary.com/TRW+To......-a059702592 http://www.automotivedesignline.com/...leArticle=true http://findarticles.com/p/articles/m...1/ai_53179685/ http://www.copradar.com/preview/xappA/xappA.html Those few that do operate in the K band seem to use a modulated signal ( http://www.adaptive-cruise-control.c...1200574784.pdf ) and/or sit in a very narrow band ( www.smartmicro.de/A_24GHz_ACC_Radar_Sensor.pdf ) that a good detector should be able to filter out. If not, it should mean a change to the firmware to selectively filter these out of alerts.
http://www.stevesnovasite.com/ http://www.jalopyjournal.com/forum/ http://www.garagejournal.com/ Last edited by HighVoltage; 07-10-2009 at 11:37 AM.. |
07-10-2009, 11:18 AM | #11 |
133
Rep 778
Yeah. Adaptive Cruise Control, Mercedes' radar cruise control, and Lexus' radar cruise control are slowly becoming mainstream
Radar detectors will become really annoying in some years time. |
07-10-2009, 11:25 AM | #12 |
Rep 318
Drives: 08 E92 335xi
you can't use laser in adverse weather conditions... radar will be around for a long time to come
07-10-2009, 01:25 PM | #16 | |
13
Rep 508
Infinitis pulse their laser, so it will give a second on, a second off of laser. When the next "on" cycle comes on, I flash the manhattan pride symbol out my sunroof. (2 fingers down, 1 up, 2 down)
07-10-2009, 03:21 PM | #18 |
155
Rep 2,882
Drives: 991/RR Sport AB
every time i get a laser alert on my V1 I slam on my brakes, find the Infiniti, and then speed back up again
2014 Range Rover Sport Autobiography
2012.5 991 C2S 1978 Corvette |
07-10-2009, 03:23 PM | #19 |
Cunning Linguist
157
Rep 2,219
i don't know about this one.
Bottles are for babies, Real men get blown.
07-10-2009, 03:23 PM | #20 |
Cunning Linguist
157
Rep 2,219
me too.
07-10-2009, 03:26 PM | #21 |
69
Rep 534
Just found this excerpt from the manual:
Laser False Alarms 1. Red neon, from stores and occasionally from brake lights of other cars (example: Chevy TrailBlazer, GMC Envoy, Olds Bravada and Buick Rainier), can imitate the characteristics of speed laser. Solution: Move away from source. 2. The electrical systems of some cars generate electromagnetic interferences, triggering laser alerts. How to test: Try V1 in a different car. Possible solution: Try relocating detector within the interfering car; also, your dealer may have a factory fix. 3. Adaptive cruise control systems using laser may cause laser alerts. Solution: Switch to normal cruise control. |
07-10-2009, 03:31 PM | #22 | |
Cunning Linguist
157
Rep 2,219
