PLEASE HELP SUPPORT E90POST BY DOING YOUR TIRERACK SHOPPING FROM THIS BANNER, THANKS! |
BMW 3-Series (E90 E92) Forum
Smoother w/ non-runflat's
Wheels and Tires forum Sponsored by The Tire Rack
Please help to directly support e90post by doing your tirerack shopping from the above link. For every sale made through the link, e90post gets sponsor support to keep the site alive. Disclaimer |
07-22-2005, 12:19 PM | #1 |
28
Rep 182
How much smoother w/ non-runflat's??
Could I assume that if my e90 was equiped with non-RF that if would be a smoother ride?
Or is the difference not that noticeable. Last edited by BMRu4ia; 07-22-2005 at 12:53 PM.. |
07-22-2005, 04:12 PM | #2 | |
44
Rep 722
But being that the suspension in the E90 is apparently tuned with run-flats in mind, it's hard to say what a lighter wheel/tire combo would do. I know that the ride on the E90 with run-flats is much better than it is in the Mini and the 5 series with run-flats. Conventional wisdom is that less unsprung weight will definitely help the ride. |
07-22-2005, 04:27 PM | #3 |
102
Rep 614
I would believe it would be reasonable to assume that if you have two E90s (one with and one without RFT), the non-RFT shod car would ride better than the RFT car. As far as being noticeable, it would really depend how sensitive you are. The E90 non-sport rides very well, and I don't really sense a sense of harshness when going over sharp bumps and railroad tracks.
07-22-2005, 09:24 PM | #4 | |
Rep 5
07-22-2005, 11:56 PM | #5 | |
19
Rep 368
| 2006 325i | Jet Black | Black ette | 6spd manual| Nav | Xenon | Burl | Chrome Tips | 545 sport wheels | Blacklines|
|DOB 6/2/05|Delivered 7/14/05 | |
07-23-2005, 01:04 AM | #6 |
Powered By 36DD
341
Rep 7,369
I can guranteed one thing...the non-RF tires are a lot cheaper!
07-24-2005, 08:42 AM | #7 | |
14
Rep 284
Also, altho I don't have specific experience with using non-runflats on this car, on paper the non-runflats must ride more comfortablly / less harsh than the runflats because the runflats have a much much stiffer sidewall. |
07-24-2005, 09:25 AM | #8 |
Moderator
618
Rep 10,858
Pondermatic provides the data (thanks!): 27 lbs. runflat vs. 24 lbs regular, i.e., 3 lbs. difference. That is within the range of variation of regular tires. 3 lbs. will not affect ride quality in most circumstances. Unsprung weight is important for handling over rough surfaces, that is, situations in which the wheel assembly is moving up and down. The lighter the wheel assembly, the easier it is to control the movement, it has less momentum. This is especially important for off-road motorcycles, desert racing, rallye cars and the like. It is not as big a deal for luxury cars on the street. I guarantee Cadillacs have more unsprung weight than an E90. It is the sidewall stiffness, as Pondermatic states, that is the relevant variable affecting ride quality, i.e., the extent to which we can 'feel' bumps. If you want a smoother ride, get higher aspect tires (e.g., switch to a 60 series) that are designed for ride quality. The tradoff is that the tire will 'bend' more during sideways loads, hence will not corner as well. I prefer the go-kart feel. When we are down to 30 aspect ratio tires, the difference btw a regular and a non-flat is almost imperceptible. At this point we need to assess which tire performs. Anyone know of any good runflat comparison tests yet?
07-24-2005, 02:01 PM | #9 |
Rep 56
Run Flat Tires
Can you order Michelin Pilot Sport tires at the same time you order your car ? -- Or is it at crap shoot. ? Plan to order a 330 I.
Thanks, Donnie |
07-24-2005, 04:12 PM | #10 | |
102
Rep 614
