View Poll Results: Which lens should I rent for rolling shots? | |||
70-200mm f2.8G AF-S VR |
5 | 38.46% |
80-200mm f2.8D ED AF |
0 | 0% |
18-200mm f3.5-5.6 DX AF VR |
8 | 61.54% |
Voters: 13. You may not vote on this poll |
03-21-2009, 02:55 AM | #1 |
![]() ![]() 398
Rep 2,526
I will be attending and photographing a car meet soon, and was wondering which lens I should rent. I will be shooting rolling shots, hand-held out of a window, as well as a car show where all of the cars are parked closely together, and there's not much room to compose by feet.
I use a Nikon, and have come up with the following lenses I could choose from: 1. 70-200mm f2.8G AF-S VR 2. 80-200mm f2.8D ED AF 3. 18-200mm f3.5-5.6 DX AF VR The only reason I would go with the 80-200mm is because. supposedly, it focuses faster than the 70-200mm, but then again it lacks the VR of the 70-200mm which will definitely help when I'm shooting from a moving car. I considered the 18-200mm to minimize lens changing, but I'm afraid of the higher F-stops might not produce the bokeh I want, and deliver the speeds. But like the 80-200mm, its focusing is supposedly fast. I will not be using a tripod or window-mount with these lenses. IMO, I don't think the 18-200mm will be needed. Changing lenses is a hassle but I don't mind it. I already have a 17-55mm f/2.8 that I can switch if needed. But the main problem lies in the f/2.8 telephotos. If I go with the 80-200mm, I'll be able to focus fast enough on a speeding car and "Capture the moment", but may end up with a blurry photo without the VR, but if I go with the 70-200mm, I'm afraid that I'll get an out-of-focus picture, but with very sharp details. Based on your experiences, which is the better lens for my task? ![]() |
03-21-2009, 03:10 AM | #2 |
Bootleggin' 'n Gunrunnin'
155
Rep 2,372
I haven't heard that the 70-200 VR is slower than the 80-200 for focusing, more like the opposite if the 80-200 you rent is not the AF-S version (and likely it isn't.) The AF-S 80-200 was only made from '99 to '04. The currently produced 80-200 is AF-D, which means no focusing motor in the lens (done by the body.) I'm guessing you are renting at Glazer's? The don't list their 80-200 as an "AF-S", just "AF."
I think the 70-200 VR will smoke the 80-200 in focusing speed because of AF-S. But for rolling shots, I'm not sure that 70mm is going to be wide enough. Don't forget the crop factor, so that 70mm is really equivalent to 105mm on the D300. I'm guessing you are going to be too close to the subject car for 105mm to give you any FOV. Your 17-55 will probably work better for that. *Note - I have not used either lens, but this lens will be my next purchase (70-200 VR or 80-200 AF-S), so I've been doing a ton of research on them. ANILE8 shoots with a 70-200 VR for some of his sports shots, and I don't remember him complaining about focusing speed. One final thought: Glazer's is cheap to rent from! Might as well get the 70-200 and the 18-200 to play around with. It's only $30 a day. If your event happens to be on a weekend, pick up on Friday, return on Monday is just one day's rental fee! Sweet!
Scott
2024 G01 X3 M40i, Brooklyn Grey Metallic /// 2015 F15 X5 35i, Space Gray Metallic, 99K miles /// 2013 F30 320xi, Mojave Metallic, 112k miles 2019 Ford F450 STX, Oxford White 2013 Ducati Multistrada Touring S, Red |
03-21-2009, 03:42 AM | #3 | |
![]() ![]() 398
Rep 2,526
![]() ![]() ![]() ![]() I didn't know that, thanks! I happen to have two events over the weekend, one on Saturday and one on Sunday. Awesome! Like you mentioned, 70mm may not be wide-enough for rolling... I guess I'll have to switch lenses, then. |
03-29-2009, 12:57 AM | #4 |
![]() 50
Rep 209
I'd go with the 18-200. If you're shooting during the day you should be fine. TWiTCHY is right about 70 mm not being wide enough for rolling shots. If you do rolling shots with 70 mm or greater, the car you're in will need to be a few lanes away in order to get the full car. 18 -24 mm may work well for shooting in the next lane or even 2 lanes over.
03-29-2009, 01:17 AM | #5 |
![]() 670
Rep 24,685
Drives: '04 330i ZHP
since I don't speak Nikon... go for whatever is the sharpest and fastest lens there... the 80mm sounds about right. Remember if you're shooting moving cars you'll be up at 1/125th or higher so if VR means image stabilizer then don't bother cuz you won't need it most likely.
03-29-2009, 01:22 AM | #6 | |
![]() ![]() 398
Rep 2,526
03-29-2009, 01:37 AM | #7 | |
![]() 670
Rep 24,685
besides... some closer up shots of the cars would look cool... you can have a lot more of an aggressive style of pix by filling the frame up completely and having parts spill over the edge of the photos instead of a shit ton of pics just being all wide angle rolling shots (gosh never seen those before ![]() |
03-29-2009, 02:00 AM | #8 |
![]() 670
Rep 24,685
instead of seeing rolling shots like this all day long...
![]() you can mix it up a little with stuff like this... |
03-29-2009, 02:21 AM | #9 |
aka 1013MM
![]() 1359
Rep 9,545
I own the 18-200mm and 80-200mm although the 80-200 is sharper and faster its really not wide enough.. the 18-200mm will do fine with some post processing.
03-31-2009, 07:15 PM | #10 |
![]() 18
Rep 36
UdubBadger those two shots you posted were both rig shots, done rolling at 5mph and with a camera mount, not shot car to car with a long lens.
Phiberglass he's talking about Nikon lenses not Canon lol so I don't know why you wasted a post saying that. and for the OP, I don't know why you would really want a long lens... or consider shitty lenses like the 18-200mm when you already have a 17-55mm 2.8... everything I have shot car to car is within that same range of the lens you already have... I would never imagine shooting anything car to car past 50mm really... The only time I use my 70-200 2.8VR is when I am shooting at the race track. 24-70mm F2.8 on D700 (so same as 17-55mm 2.8 on Dx) ![]() 50mm F1.8 on D300, I found it a huge pain in the ass trying to shoot even at 50mm on a Dx body. Extremely hard to lean out far enough to get shots like this, especially in a car with stiff suspension and when going around bends. ![]() 18-70mm on D300, perfect range once again. ![]() I assure you, your 17-55mm 2.8 will be perfect for shooting car to car stuff, if anything I'd maybe rent a wider angle lens to mix it up and for the show and shine when you don't have the space you need. 70-200 is just too pointless for shooting cars unless it's a stationary actual shoot or at the race track.
Nikon D700 / Nikon D300 / Nikon P6000 / Nikon 10.5mm F2.8 / Nikon 14mm F2.8 / Nikon 20mm F2.8 / Nikon 24-70mm F2.8 / Nikon 50mm F1.4G / Nikon 70-200mm F2.8VR / Nikon SB80DX x 2 / Nikon SB28 x 2 / Nikon SB800 x 2 / Nikon SB900 x 2 / Pocketwizard Plus II Transceiver x 7
My Photos: http://www.flickr.com/mikeboldt |
03-31-2009, 09:35 PM | #12 |
EUROPROJEKTZ
![]() 191
Rep 7,958
Drives: backwards
to do rolling shots don't go with a telephoto. bad idea. got with a wide angle for most of your automobile shots.
03-31-2009, 09:35 PM | #13 |
EUROPROJEKTZ
![]() 191
Rep 7,958
Drives: backwards
03-31-2009, 09:52 PM | #15 |
![]() ![]() 398
Rep 2,526
Wow thanks for all the feedback! I did find myself using the 17-55mm lens when I was doing the rolling shots. Most of them came out very blurry since the 17-55mm has no vibration reduction, and I was using a slow shutter speed like 1/40 and 1/80 to blur the background. I got away with a few, but most of them just didn't work out well.
03-31-2009, 11:59 PM | #16 | |
Aberry is a scammer
![]() 595
Rep 5,507
Drives: SGM E92 335i, AM E90 335i
04-01-2009, 04:19 AM | #18 |
![]() 18
Rep 36
Eh it could be better. I wish the car was further towards the center of frame.
I did a big canvas 20 x 30" print of that shot for the driver's girlfriend, looked KILLER. That was just hand held. Exposure length is everything I guess. Takes some experimenting. That was my first day ever shooting car to car stuff. Another One: ![]()
04-05-2009, 07:29 AM | #20 |
![]() ![]() ![]() ![]() ![]() 1596
Rep 29,217
Yeah, awesome rolling shots Mike.
![]() F10 520d M-Sport Alpine White | HRE P43SC 20x9+20x11 | Michelin PSS 255/35+295/30 | KW V3 Coilover | M5 Front Sway Bar + M550d Rear Sway Bar | 3DDesign Front Lip | BMW M Performance CF Spoiler | BMW M Performance Diffuser | BMW M Performance Black Grills | BMW M Performance Pedals | |
04-05-2009, 09:11 AM | #21 |
![]() ![]() ![]() 3530
Rep 6,627
Twitchy, If you end up buying either the 80-200 or 70-200, search through live.com for the cashback. They have 13% off right now for buy it now and you can get 200 bucks off either of those lenses (anything helps with how expensive they are) I was able to get back 193 bucks for my 14-24 wide angle last week. Great deal for the pro lenses to use the cashback. Anyway, fyi... |
04-05-2009, 12:11 PM | #22 | |
155
Rep 2,372
Scott
