Thread Tools
      08-26-2025, 05:15 PM   #1
analogue
analogue's Avatar
937
526
Drives: 1M, iX
BMW G60 Service Bulletin List
Here you will find all of the service bulletins BMW has submitted to NHTSA for the i5/5 seried (G60). Bulletins usually take several weeks to appear in the NHTSA database after they are published internally in BMWTIS.
This thread will be updated with recent bulletins after they land at NHTSA and a reference is published here: https://itsanalogue.github.io/bmw-tsb/G60.html. You can find all of this information on the NHTSA website if you know where to look, but this is a consolidated list and should help search engines find and index the SIB PDFs faster.
ToddRGuy5845.50
dfc888677.50
3sp17.50
      08-26-2025, 05:15 PM   #2
analogue
analogue's Avatar
937
526
Drives: 1M, iX
Recent Bulletins
SIB 32 03 26 (2026-04-23)
BMW 530I 2024,2025
(plus 2 other models)
STEERING
“Groaning” noise from the EPS when the steering wheel is at the end stops.
MC-11031564-0001.pdf
SIB 61 06 26 (2026-04-22)
BMW I5 2024
(plus 3 other models)
ELECTRICAL SYSTEM
Charging sessions cannot be started or they are interrupted while using a Level 2 AC high-power charging station, or with a Level 3 DC charging station. Charging may start normally but can interrupt after some time. Level 2 (240 V) Flex Charger and Wall box may also be affected. The red or white LED is displayed on the high-voltage charging socket; however, no associated fault codes are stored.
MC-11031568-0001.pdf
SIB 12 05 26 (2026-04-10)
BMW 530I 2024
(plus 1 other model)
ELECTRICAL SYSTEM
A “knocking” sound from the fuel tank area can be heard in the passenger area. Occurrence information below. 1. The noise occurs when the engine is at idle 2. The noise occurs sporadically 3. The noise disappears when the fuel filler cap is opened 4. The noise also disappears when the tank ventilation valve is disconnected There is no relevant fault saved in the fault memory.
MC-11031571-0001.pdf
SIB 61 03 24 (2026-04-09)
BMW I5 2024
BMW I5 EDRIVE40 2026
(plus 13 other models)
ELECTRICAL SYSTEM
Gen 5 BEV/PHEV vehicles may set the Combined Charging Unit (CCU) in programming abort due to no communication to the HV charge socket electronics.
MC-11031576-0001.pdf
SIB 61 05 26 (2026-03-20)
BMW 530I 2025
VISIBILITY/WIPER
Customers might report that washer fluid is leaking from the lower reservoir area, especially around thewasher fluid pumps.
MC-11030307-0001.pdf
SIB 12 03 26 (2026-03-19)
BMW 530I 2024,2025,2026
ELECTRICAL SYSTEM, ENGINE, UNKNOWN OR OTHER
PROGRAM CONTROL UNITS (OBD)
MC-11030305-0001.pdf
SIB 51 22 24 (2026-03-18)
BMW 530I 2024,2025
(plus 10 other models)
STRUCTURE: BODY, UNKNOWN OR OTHER
On the main door seal, detachment behaviorcan be detected at the sealing joint . Over time, the seal gradually and increasinglydetaches which can cause it to- Dangle Become visible to the customer Prevent the door from closing properly
MC-11030306-0001.pdf
SIB 65 08 26 (2026-03-16)
BMW 530I XDRIVE 2025
(plus 11 other models)
ELECTRICAL SYSTEM
After the software update to version …25-07-5XX, existing activation points for the “Automate My Habits”function no longer work.
MC-11030312-0001.pdf
SIB 12 05 23 (2026-03-06)
BMW I5 2024
ELECTRICAL SYSTEM, POWER TRAIN
The customer states there is a Drivetrain Malfunction message displayed in the instrument cluster. In addition, the following fault memory entries are saved in the CCU (Combined Charging Unit) 0317F2 - High-voltage system, insulation fault detected: when switch contactors are closed. 0317F1 - High-voltage system, insulation resistance below warning threshold: when switch contactors are closed. The fault memory entries (isolation faults) can occur both individually and in combination and must be traced back to the eDrive motor based on the ISTA test procedure. If ISTA test procedure lists possible cause of fault as; A metal chip is found behind the brush module (between the brush module and the end shield of the electrical machine). Repair required. Refer to service solution no. 20000794435083 in Aftersales Information Research (AIR). Follow information in the Procedure section below.
MC-11030059-0001.pdf
SIB 61 03 26 (2026-03-05)
BMW 550E XDRIVE 2025
(plus 4 other models)
ELECTRICAL SYSTEM
Several complaints are possible: Vehicle does not start Gear cannot be engaged Various Check Control Messages Malfunction indicator lamp (MIL) on Several Check Control messages are possible: “It is possible to continue driving. High-voltage system.” “You can continue driving. Drivetrain.” “Restart not possible. Drivetrain fault.” “Call Roadside Assistance. Drivetrain failure.” “Information: Total error of vehicle.” The following fault memory entries are stored in the CCU: D796D9 - Message (- 0x91) not up-to-date, receiver CCU, transmitter EME D796DC - No message (- 0x91), receiver CCU, transmitter EME D796D8 - No message (- 0x91), receiver CCU, transmitter EME Other fault codes below may be stored in the EGS BA09B8 – Inverter, Voltage Sensor, 5V HV AUX: Out of range or open connection detected BA0A45 – ECU internal: Internal error of the synchronous serial data bus. Additional fault memory entries are possible. Similar fault memory entries indicating a missing EMEmessage (Traction E-Machine Electronic) can also be stored in other control units.
MC-11030054-0001.pdf
SIB 61 19 25 (2026-03-04)
(plus 6 other models)
ELECTRICAL SYSTEM
The malfunction indicator lamp (MIL) is triggered by the erroneous fault code 031BFC- AC charging,charging electronics 2, internal fault: No internal capacitor discharge stored in the CCU. However, AC charging is operating as designed without a charging concern or issue. Affected PHEV vehicles have the CCU-03 (7.4 kW / 11 kW) with I-levels from …24-07-500 to …25-11-5xx.
MC-11030053-0001.pdf
SIB 61 23 25 (2026-03-04)
ELECTRICAL SYSTEM
The malfunction indicator lamp (MIL) is triggered and 0318E2 AC charging, charging electronics 1,component protection: Overload current on AC side fault may be stored during AC charging Level 1(120 VAC). Note: Despite the fault memory entry (and the malfunction indicator lamp), the AC charging process willcontinue operating as designed and there is no related drivability complaint. Affected PHEV (plug-in hybrid electric vehicle) vehicles with CCU-03 (7.4 kW combined charging unit).
MC-11030051-0001.pdf
SIB 61 22 25 (2026-03-03)
(plus 5 other models)
ELECTRICAL SYSTEM
Malfunction indicator lamp (MIL) is triggered by the erroneous fault code(s) BA0023 - Control unit: internalfault (software group fault) In addition, the BA0008 - CCU, internal coolant temperature sensor:Signal implausible faults may be stored in the CCU memory. However, AC charging is still operating as designed, without any related drivability complaints. Affected PHEV vehicles have the CCU-03 (7.4 kW / 11 kW) with I-levels from 24-07-500 to 25-11-5xx.
MC-11030052-0001.pdf
SIB 17 01 24 (2026-02-25)
BMW I5 2024,2025
BMW I5 EDRIVE40 2024
ENGINE, ENGINE AND ENGINE COOLING
There is coolant leaking from under the car Low heater output Possible Check Control message “Drive, you can continue driving” (ID49) Possible fault codes stored in these BEV vehicles: 224163 – Electric auxiliary heater for the high-voltage battery unit: Undervoltage or internal communication fault 8049AA - Coolant level sensor, expansion tank: Coolant level low or short circuit to ground or line disconnection 80124F – Electric auxiliary heater: Communication in electric auxiliary heater faulty 224F60 - Coolant level sensor, expansion tank: Coolant level low or short circuit to ground or line disconnection 224111 - Cooling system for power electronics: Coolant loss detected 224107 - Cooling system for high-voltage battery unit, component protection: Detection of coolant loss
MC-11029046-0001.pdf
SIB 61 01 26 (2026-02-20)
BMW 530I 2025
(plus 9 other models)
ELECTRICAL SYSTEM
During vehicle start-up the Secure Element (SE) of the BCP may fail causing communication errors. TheCheck Control message “Drive carefully. Driving stabilisation.” will appear. In addition, the fault memoryentries below will be stored within 40 seconds of each other. ACSM: 02010A - Coding: Coding data not qualified VIP: 02390A - VIP control unit: Coding data not released, signature IB: 02290A - DSC control unit: Coding data not released, signature HKFM: 020D0A - HKFM: Coding data are not qualified
MC-11029070-0001.pdf
RECALL 26V096000 (2026-02-19)
Affecting 58713 total vehicles built between 2024-06-18 and 2025-04-09
BMW 550E XDRIVE 2025,2026
BMW I5 EDRIVE40 2024,2025,2026
BMW I5 M60 XDRIVE 2024,2025
BMW I5 XDRIVE40 2025,2026
ELECTRICAL SYSTEM: WIRING
BMW of North America, LLC (BMW) is recalling certain 2025 M5 Sportswagon, 2025-2026 M5, 2024-2025 750e xDrive, 2025-2026 550e xDrive, 2023-2025 I7, 2023-2025 7 Series, 2024-2026 i5, and 5 Series vehicles. The electrical wiring harness for the air conditioning system may become damaged during replacement of the cabin air filter.
RCRIT-26V096-5013.pdf
RCRIT-26V096-1695.pdf
RCRIT-26V096-5504.pdf
RCRIT-26V096-2065.pdf
SIB 65 27 25 (2026-02-11)
BMW 530I 2025,2026
(plus 14 other models)
ELECTRICAL SYSTEM
The vehicle may experience various operational issues with the infotainment system such as: Resets of the head unit Delayed start-up of the head unit (longer than 30 seconds) Failed start-up of the head unit Sporadic or permanent problems with navigation Sporadic or permanent Bluetooth connection problems Sporadic or permanent audio problems Sporadic or permanent speech / IPA (international phonetic alphabet) problems Missing displays, radio stations, camera images or applications
MC-11028927-0001.pdf
SIB 51 14 24 (2026-02-09)
BMW 530I 2024,2026
STRUCTURE: BODY
The hood is difficult to close, or may not close
MC-11028924-0001.pdf
In-Vehicle-InApp-Comm (2026-02-05)
BMW 530I 2024,2025
STRUCTURE: BODY
The water drain hose of the slide/tilt sunroof must be checked and, if necessary, re-attached. If the front left water drain hose is not connected, water can enter the footwell via the A-pillar and the carpet on the driver's side can soak up the water that has entered.
MC-11029005-0001.pdf
RECALL 26V056000 (2026-02-02)
Affecting 87394 total vehicles built between 2020-12-14 and 2022-12-14
BMW 530I 2024
(plus 7 other models)
ELECTRICAL SYSTEM: STARTER ASSEMBLY
BMW of North America, LLC (BMW) is recalling certain 2021-2023 Toyota Supra, 2022-2023 2 Series Coupe, 2021-2024 5 Series (xDrive), 2021-2022 Z4, 2022-2024 4 Series (Gran Coupe), 2021-2024 4 Series (Convertible and xDrive Convertible), 2021-2023 4 Series (Coupe), 2021-2024 3 Series, 2021-2023 X4, 2021-2024 X3 vehicles. Please see the recall report for a complete list of all models. The engine starter may overheat and catch fire due to wear on an internal component.
RCRIT-26V056-2459.pdf
SIB 52 07 25 (2026-01-28)
BMW 530I 2025
STRUCTURE: BODY
The decorative trims on the head restraints of the driver’s seat and front passenger seat cause groaning noises on any route, at any temperature, even in a slightly reclined position.
MC-11027994-0001.pdf
InVehicle-InApp-Comm (2026-01-22)
BMW 530I 2025
SERVICE BRAKES
Service Action: Left Side EMF (Parking Brake Actuator)
MC-11028276-0001.pdf
SIB 51 19 24 (2026-01-22)
BMW 530I 2024,2025
VISIBILITY/WIPER
There is a matte “veil” or milky stain on theexterior mirror glass.
MC-11027991-0001.pdf
SIB 16 02 25 (2026-01-17)
BMW 530I 2024
FUEL/PROPULSION SYSTEM
The assembly cover on the left side of the fuel tank may not have been properly plastic welded. Thiscould lead to a smell of fuel after refueling or service engine soon light (MIL) for an evaporative leakin the fuel system.
MC-11027759-0001.pdf
SIB 65 20 25 (2026-01-15)
BMW 530I 2025
(plus 12 other models)
ELECTRICAL SYSTEM
After replacing the Multifunctional Display (MFD), the Central Information Display (CID) is black. Thebacklight of the CID is illuminated, and touch function does register an audible sound.
MC-11027777-0001.pdf
SIB 51 19 25 (2026-01-09)
BMW 530I 2025
STRUCTURE: BODY
When driving vehicle over rough roads, a rattle sound emanates from the left footwell panel.
MC-11027768-0001.pdf
SIB 61 24 25 (2026-01-03)
BMW 530I 2025
ELECTRICAL SYSTEM
A limited number of 48 (V) volt vehicle batteries may have been damaged during the manufacturing process;this could lead to a premature battery failure. The 48 V battery may fail, triggering a corresponding Check Control message.
MC-11027774-0001.pdf
SIB 54 06 25 (2026-01-03)
BMW 530I 2024,2025
BMW I5 2024,2025
STRUCTURE: BODY
Through quality checks, it has been detected that the front left water drain hose for the slide/tilt sunroof isnot connected.
MC-11027770-0001.pdf
SIB 64 09 25 (2025-12-22)
BMW I5 2024,2025
ELECTRICAL SYSTEM
A faulty electric auxiliary heater may have been installed in the certain vehicles. This could result in thefailure of the electric auxiliary heater, utilized for the vehicle interior.
MC-11026956-0001.pdf
SIB 11 10 25 (2025-12-12)
BMW 530I 2025
ENGINE
Coolant is leaking from the oil filter housing.
MC-11026946-0001.pdf
SIB 65 28 25 (2025-12-10)
BMW 530I 2026
ELECTRICAL SYSTEM
The vehicle may experience various operational issues with the Multifunction Display such as: Intermittent black screen Permanent black screen Intermittent head unit functions not displayed (i.e., Navigation screen only is black)
MC-11026964-0001.pdf
SIB 16 01 24 (2025-11-12)
BMW 530I 2025
ELECTRICAL SYSTEM, FUEL SYSTEM, GASOLINE
RSU availability. The engine cranks but will not start.
MC-11025670-0001.pdf
SIB 12 11 25 (2025-11-12)
BMW 530I 2024,2025
One or both of the following faults stored in the DME: 034AA5 - Mixture control bank 1, lambda regulation, mixture too lean 034AA8 - Mixture control bank 1, lambda adaptation, mixture too rich And additionally with the faults above, these affected vehicles may have one or more of the followingirregular combustion-related faults also stored: 033812 033813 033814 033815 033816 033817 033818 033819
MC-11025668-0001.pdf
SIB 63 10 25 (2025-11-10)
BMW 530I 2024,2025
BMW I5 2024,2025
EXTERIOR LIGHTING
RSU availability. The ambient lighting color cannot be saved permanently. The personalized color of the ambient lighting resets after the vehicle has gone to sleep.
MC-11025685-0001.pdf
SIB 61 20 25 (2025-10-21)
BMW I5 2025
ELECTRICAL SYSTEM
RSU availability. It is possible the State of Health (SoH) of the high-voltage (HV) battery is displayed incorrectly to the customer. The value is continuously displayed as 100% regardless of the actual ageing of the HV battery.
MC-11024714-0001.pdf
SIB 65 25 25 (2025-10-10)
BMW 530I 2025
(plus 8 other models)
ELECTRICAL SYSTEM
After the software update to I-level version …25-07-530, the Alexa app may disappear from the App Menu in the head unit (HU-H5).
MC-11024727-0001.pdf
SIB 84 06 25 (2025-10-03)
BMW 530I 2024,2025
(plus 18 other models)
ELECTRICAL SYSTEM
In some situations, an emergency call may be triggered in the vehicle without either the customer pressing the SOS Call button, or an airbag deployment event. In some cases, the customer may not even be inside the vehicle.
MC-11024211-0001.pdf
SIB 51 03 25 (2025-10-02)
BMW 530I 2024
STRUCTURE: BODY
The front and/or rear doors only close if increased force is exerted, or with increased closing speed.
MC-11024206-0001.pdf
SIB 34 08 25 (2025-09-18)
BMW 530I 2024,2025
ELECTRICAL SYSTEM
Starting from I-level …24-07-500, it is possible that the Automatic Hold function is not automatically storedfor the next journey. The function must be activated again by the driver at the beginning of every trip. After asoftware update to 25-03-500 and higher, this occurs more frequently.
MC-11024205-0001.pdf
SIB 32 08 25 (2025-09-03)
BMW 530I 2024,2025
STEERING
When the steering column is adjusted inwards towards the instrument cluster, the noise may occur near thelimit position.
MC-11023248-0001.pdf
SIB 65 19 25 (2025-08-26)
BMW 530I 2025
ELECTRICAL SYSTEM
Central Information Display (CID) in the vehicle is black or only displays “BMW”. The head unit (HU-H5) is not responding in ISTA. Additionally, the Receiver Audio Module (RAM), Instrument Cluster (KOMBI) and Telematic Module 4 (TCB4) may not be responding in ISTA.
MC-11022856-0001.pdf
SIB 34 11 25 (2025-08-22)
BMW 530I 2025
BMW I5 2025
SERVICE BRAKES
The parking brake actuator has not been wound correctly so that it cannot be applied or released. Check Control message “Parking brake failed. When parking, secure the vehicle against rolling away. Mustbe checked by the Service Partner.” The vehicle is still held by the unaffected side and the transmission lock.
MC-11022100-0001.pdf
SIB 41 04 24 (2025-08-20)
BMW 530I 2025
STRUCTURE: BODY
A groaning sound from the front of the vehicle while driving can be heard, particularly while cornering. The groaning sound can be heard in the A-pillar/instrument panel area.
MC-11022859-0001.pdf
SIB 51 11 25 (2025-08-20)
BMW 530I 2025
STRUCTURE: BODY
When pulling on the hood (highlighted inorange in the top photo) release lever (highlighted in orange in the bottomphoto; driver’s footwell shown ) , there is a noticeable lack of cable tension; and the hood will not unlock.
MC-11022105-0001.pdf
SIB 51 03 24 (2025-08-20)
BMW 530I 2025
STRUCTURE: BODY
While opening any of the doors, a groaning sound is heard from the door brake. Doors open and close stiffly.
MC-11022103-0001.pdf
SIB 63 10 23 (2025-08-19)
BMW 530I 2024,2025
EXTERIOR LIGHTING, EXTERIOR LIGHTING: TAIL LIGHTS, VISIBILITY/WIPER
Condensation is present in the inner surface in one or both (inner and/or outer) taillamps.
MC-11022112-0001.pdf
SIB 64 04 25 (2025-07-30)
BMW 530I 2025
ELECTRICAL SYSTEM, STRUCTURE: BODY
After performing a cabin air filter replacement maintenance service task, or after a similar repair thatrequired the removal and installation of the filter’s housing cover; the following air flap and/or air temperaturesensor faults are stored in the BCP: 80114D - Stepper motor: Unexpected error in Driving Cycle 801168 - Temperature sensor ventilation left or ventilation: short to ground 80116A - Temperature sensor ventilation right: short to ground 80116B - Temperature sensor ventilation right: short to plus or open circuit 80116C - Temperature sensor footwell left or footwell: short to ground 80116D - Temperature sensor footwell left or footwell: short to plus or open circuit 80116E - Temperature sensor footwell right: short to ground 80116F - Temperature sensor footwell right: short to plus or open circuit 80435B - Stepper motors: short-circuit by mass
MC-11021112-0001.pdf
SIB 63 04 18 (2025-07-21)
BMW 530I 2024
(plus 47 other models)
AIR BAGS, ELECTRICAL SYSTEM, EQUIPMENT, EXTERIOR LIGHTING, EXTERIOR LIGHTING: HEADLIGHTS: DAYTIME RUNNING LIGHTS: BULBS, VISIBILITY/WIPER
One or more of the LED daytime running lights are dim or discolored.
MC-11020927-0001.pdf
SIB 61 01 25 (2025-07-18)
BMW 530I 2024,2025
UNKNOWN OR OTHER
During highly dynamic driving, washer fluid may be forced out of the windshield washer nozzles. This canlead to the washer fluid reservoir being completely emptied.
MC-11020928-0001.pdf
SIB 66 03 25 (2025-07-14)
BMW 530I 2024,2025
Check control message is displayed indicating the parking assistance systems have limited functionality dueto errors detected within PDC sensors. The warning indicates parking assistance features have limitedfunctionality while the errors continue to be detected. Following faults may be stored 8031BA Ultrasonic Sensor Rear Side Left Software Error 8031CO Ultrasonic Sensor Rear outer left Software error 8031AE Ultrasonic Sensor Rear Outer Right Software Error 8031A8 Ultrasonic Sensor Rear Side Right Software Error 8031B4 Ultrasonic Sensor Rear Middle Right Software Error 8031C6 Ultrasonic Sensor Rear Middle Left Software Error
MC-11020916-0001.pdf
SIB 34 10 25 (2025-07-14)
BMW 530I 2025
SERVICE BRAKES
After programming from the I-Levels between …24-03-505 and lower than …24-03-540 to I-Level …24-11-530 or higher, the following CCM may be displayed: “CCM-2525: Brake system. Drive at moderate speed”
MC-11020910-0001.pdf
SIB 41 05 25 (2025-06-27)
BMW 530I 2024
BMW I5 2024
While attempting to fuel/charge the vehicle,the fuel/charge door will not open.
MC-11020066-0001.pdf
RECALL 25V395000 (2025-06-16)
Affecting 71286 total vehicles built between 2021-02-04 and 2024-01-16
BMW I5 2024
ELECTRICAL SYSTEM: PROPULSION SYSTEM: TRACTION MOTOR: CONTROLLER: SOFTWARE
BMW of North America, LLC (BMW) is recalling certain 2022-2025 i4, 2022-2024 IX, 2023-2024 I7, and 2024 I5 vehicles. The electric drive motor software may shut down the high-voltage system, causing a loss of drive power.
RCRIT-25V395-8044.pdf
SIB 34 07 25 (2025-06-11)
BMW 530I 2025
BMW I5 2025
SERVICE BRAKES
A loud “click”- type noise can be heard from the rear axle brakes when driving off forwards, and/or in reverse.
MC-11019564-0001.pdf
SIB 34 04 25 (2025-06-11)
BMW 530I 2024
ELECTRICAL SYSTEM, SERVICE BRAKES
As a result of a data input error, certain fault memories are permanently stored. The permanent storage offault memories does not comply with the legal specifications of the authority (California Air Resources Board– CARB). The fault has no effect on the use of the vehicle by the customer.
MC-11019563-0001.pdf
SIB 12 04 25 (2025-06-11)
BMW 530I 2024,2025
ELECTRICAL SYSTEM
EMISSIONS RECALL 25E-A02: PROGRAM CONTROL UNITS
MC-11019554-0001.pdf
SIB 27 02 20 (2025-06-06)
BMW 530I 2024,2025
(plus 39 other models)
LANE DEPARTURE, POWER TRAIN, WHEELS
There is a jerking or shuddering during either or both of the following: Cornering or accelerating from low speeds Driving with low to medium loads
MC-11019579-0001.pdf
SIB 64 06 25 (2025-06-06)
BMW I5 2024
A faulty electric auxiliary heater may have been installed in the certain vehicles. This could result in the failure of the electric auxiliary heater.
MC-11019570-0001.pdf
SIB 65 35 24 (2025-06-03)
BMW 530I 2024,2025
ELECTRICAL SYSTEM
Customers may report that the Central Information Display (CID) side of the Multifunction Display flickersonce on and off. This flickering is not continuous but may occur once every 15 to 50 seconds. No fault memory entry is stored for this customer complaint.
MC-11019580-0001.pdf
SIB 54 04 25 (2025-06-02)
BMW 530I 2025
ELECTRICAL SYSTEM
The Sky Lounge sunshade does not open/close. Concern may be intermittent. The following fault codes are stored in the FZD (Roof Centre Function) control module during a vehicle test: 0302A0- ESH (electrical sunshade): No standardization system 03029C- ESH (electrical sunshade): No init because boundary conditions not valid (motordiver)
MC-11019567-0001.pdf
SIB 66 07 25 (2025-05-30)
BMW 530I 2024
(plus 15 other models)
ELECTRICAL SYSTEM
The speed limit warning adopted speed, which is set by the customer, is automatically reverting to lowervalue after an extended duration of the sleep cycle.
MC-11018732-0001.pdf
SIB 61 08 25 (2025-05-30)
BMW I5 2025
ELECTRICAL SYSTEM
The operating time value was written too high in the Storage Management Electronics (SME) during thehigh-voltage battery “End Of Line” (EOL) test. The excessive operating hours input results in a significant limitation in the charging capacity when vehicleis be charged with DC.
MC-11018729-0001.pdf
SIB 65 15 25 (2025-05-20)
BMW 530I 2024
ELECTRICAL SYSTEM
When initiating a phone call to a specific saved contact, Intelligent Personal Assistant may not be able tolocate the contact or may call the incorrect contact.
MC-11018549-0001.pdf
SIB 65 09 25 (2025-05-08)
BMW 530I 2024
ELECTRICAL SYSTEM
Customer may complain that Projected Modes (Apple CarPlay/Android Auto) do not connect in the vehicle. Itis found that the WiFi in the vehicle is also not active and cannot be turned on.
MC-11018546-0001.pdf
SIB 32 02 25 (2025-05-02)
BMW 530I 2024,2025
BMW 540I 2025
BMW I5 2024,2025
STEERING
Parts of the steering shaft universal joint may have been joined together without having beengreased. As a result, there can be audible squeaking and cracking noises. In some cases, moresteering force is required.
MC-11018513-0001.pdf
SIB 17 01 25 (2025-04-30)
BMW I5 2025
ENGINE
The coolant hose which runs from the combined charging unit (CCU) to the front electric motor’s housingmay develop a leak at the motor end of the hose.
MC-11017503-0001.pdf
SIB 51 30 19 (2025-04-29)
BMW 530I 2024,2025
(plus 16 other models)
STRUCTURE, STRUCTURE: BODY
A groaning noise is present from the door frame of any door, most commonly when driving over rough roadsor during body flex. This situation may be worse in vehicles which are regularly waxed in th e area of the door jamb.
MC-11017506-0001.pdf
SIB 51 02 24 (2025-04-22)
BMW 530I 2024,2025
BMW I5 2024
EQUIPMENT, STRUCTURE: BODY, VISIBILITY: REARVIEW MIRRORS/DEVICES: EXTERIOR
A squeaking sound is heard when folding either of the exterior mirrors assemblies in or out.
MC-11017280-0001.pdf
SIB 24 02 24 (2025-04-18)
BMW 530I 2024
POWER TRAIN
Due to a manufacturing issue, the torque on the bolts of the transmission Mechatronics was not carried outaccording to the specification. The faulty torquing can cause a malfunction within the transmission, and as a result, the emergencyoperation of the transmission.
MC-11017286-0001.pdf
RECALL 25V202000 (2025-04-01)
Affecting 4557 total vehicles
BMW 530I 2025
ELECTRICAL SYSTEM: ALTERNATOR/GENERATOR/REGULATOR, ELECTRICAL SYSTEM: STARTER ASSEMBLY
BMW of North America, LLC (BMW) is recalling certain 2025 330i, 330i xDrive, 530i, 530i xDrive, 4 Series Coupe (430i, 430i xDrive), 4 Series Convertible (430i, 430i xDrive), 4 Series Gran Coupe (430i, 430i xDrive) and X3 30 xDrive vehicles. The electrical connection between the starter-generator and battery may come loose.
RCRIT-25V202-3123.pdf
SIB 34 01 25 (2025-03-27)
BMW 530I 2025
BMW I5 2025
SERVICE BRAKES
The parking brake actuator cannot be activated or deactivated due to a failed weld. Check Control message “Parking brake failed. When parking, secure the vehicle against rolling away. Mustbe checked by the Service Partner.” The vehicle is still held by the unaffected side and the transmission lock.
MC-11016432-0001.pdf
SIB 52 05 25 (2025-02-28)
BMW 530I 2025
ELECTRICAL SYSTEM
The customer states: The driver’s seat will not return to its last saved position. No seat memory. The heated seats settings in the menu are missing/different than in their previous BMW vehicle. They canno longer select, under the climate rules, at what temperature Fahrenheit the heated seats willautomatically turn on. Certain other “apps” and functions are not available The driver’s seat moves to an unknown memory position
MC-11014660-0001.pdf
SIB 51 04 25 (2025-02-22)
BMW 530I 2025
STRUCTURE: BODY
BMW Service Action - Tailgate Lock B51 04 25
MC-11014969-0001.pdf
SIB 51 31 24 (2025-02-20)
BMW 530I 2024,2025
UNKNOWN OR OTHER
The clear coat on the carbon fiber MPerformance rear spoiler is delaminating.
MC-11014657-0001.pdf
SIB 51 08 24 (2025-02-14)
BMW 530I 2024
UNKNOWN OR OTHER
The Augmented Reality Camera (ARCAM) shows up blurry when activated.
MC-11014509-0001.pdf
SIB 52 02 25 (2025-02-12)
BMW 530I 2024
ELECTRICAL SYSTEM
The electric front seat adjustment does not work. The problem can occur to the left, as well as the right seat.
MC-11014511-0001.pdf
SIB 51 04 25 (2025-02-07)
BMW 530I 2025
STRUCTURE: BODY
Due to changes in the opening mechanism ofthe trunk/tailgate latch, it is possible that thetrunk/tailgate may not completely lock afterclosing it.
MC-11014036-0001.pdf
SIB 51 46 16 (2025-02-03)
BMW 530I 2024
(plus 72 other models)
STRUCTURE: BODY, STRUCTURE: BODY: TAILGATE
Upon opening and closing the tailgate, a creaking/groaning sound can be heard from tailgate actuator.
MC-11014038-0001.pdf
SIB 34 01 24 (2025-01-29)
BMW 530I 2024
BMW I5 2024
After replacement of the Integrated Braking system (IB)/Power Brake the total distance covered might be lower than when handed over to the workshop for the repair.
MC-11013438-0001.pdf
SIB 11 09 24 (2025-01-15)
BMW 530I 2024,2025
POWER TRAIN
During manufacturing, the dual-mass flywheel has not been sufficiently greased. The insufficient grease may result in acoustic abnormalities and vibrations in the vehicle's powertrain.
MC-11013112-0001.pdf
SIB 65 02 25 (2025-01-14)
BMW 530I 2025
UNKNOWN OR OTHER
If the Head-Up Display (HUD) is deactivated when Navigation View is selected, upon reactivation the Head-Up Display (HUD) will revert to the Standard View. This is most noticeable when the Head-Up Display (HUD) deactivates for automatic mandatory reasons, such as rear camera activation or emergency call activation.
MC-11013062-0001.pdf
SIB 37 01 25 (2025-01-10)
BMW 530I 2024
SUSPENSION
DELIVERY STOP: SUSPENSION STRUT HOLDER
MC-11013116-0001.pdf
SIB 63 04 24 (2025-01-10)
BMW 530I 2025
ELECTRICAL SYSTEM
After the vehicle has been programmed with either RSU (Remote Software Update) or ISTA (I-Level 24-07-5xx), the ambient light on the door panel speakers will only illuminate in white.
MC-11013053-0001.pdf
SIB 32 01 25 (2025-01-10)
BMW 530I 2024
STEERING
Rumbling, groaning type noises from the EPS when the steering wheel is at the end stops.
MC-11013039-0001.pdf
SIB 61 11 24 (2025-01-07)
BMW 530I 2024
ELECTRICAL SYSTEM
After performing a BMW Remote Software Upgrade (RSU), the functionality of the Comfort Access and Passive Go/Exit features may be reduced.
MC-11013050-0001.pdf
SIB 61 01 24 (2025-01-06)
BMW 530I 2024
BMW I5 2024,2025
EQUIPMENT, STRUCTURE: BODY, UNKNOWN OR OTHER
When driving over rough surfaces, a low-frequency rattling noise can be heard inside the vehicle's cabin. The noise typically sounds as though it is coming from the front right footwell area.
MC-11013049-0001.pdf
SIB 65 38 24 (2024-12-13)
BMW 530I 2024
ELECTRICAL SYSTEM
Customers may report issue with Personal eSIM operation, to include: Personal eSIM does not finish the set-up process in the vehicle Telephone function via eSIM is not possible WiFi Hotspot function cannot be used Streaming video service via the BMW Theater Screen is not possible
MC-11012099-0001.pdf
SIB 65 36 24 (2024-12-13)
BMW 530I 2024
ELECTRICAL SYSTEM
MC-11012097-0001.pdf
SIB 64 11 24 (2024-12-09)
BMW I5 2024
ELECTRICAL SYSTEM
Quality checks have determined that the coolant changeover valve may develop a coolant leak undervery low outside temperatures (significantly lower than 32º F (0 C)).
MC-11012093-0001.pdf
SIB 84 04 24 (2024-12-06)
BMW 530I 2024
ELECTRICAL SYSTEM
Customers may report issue with Personal eSIM operation, to include: Personal eSIM does not finish the set-up process in the vehicle Telephone function via eSIM is not possible WiFi Hotspot function cannot be used Streaming video service via the BMW Theatre Screen is not possible
MC-11012103-0001.pdf
RECALL 24V870000 (2024-11-19)
Affecting 3 total vehicles
BMW 530I 2025
BMW 540I XDRIVE 2025
AIR BAGS: AIR BAG/RESTRAINT CONTROL MODULE
BMW of North America, LLC (BMW) is recalling certain 2025 530i and 540i xDrive vehicles. The air bag control unit may have been manufactured incorrectly, which can result in the air bags not deploying as intended.
RCRIT-24V870-5054.pdf
SIB 16 02 24 (2024-11-15)
BMW 530I 2024
There may be a restriction in the low-pressure fuel line at the tank flange for the in-tank delivery pump (lowpressure pump). As a result, the required fuel flow volume is not available. If there is an insufficient supply offuel (even if only for a very brief period), the high-pressure pump might suffer preliminary damage. Inaddition, in the event of a fault, there might be a power reduction or “jerking” motions while driving.
MC-11010757-0001.pdf
SIB 51 27 24 (2024-11-04)
BMW 530I 2024
ELECTRICAL SYSTEM
The Ethernet bus of the Body Domain Controller (BDC) is interrupted so that audio output, rear viewcamera, or the driver assistance systems fail. The symptoms begin to appear during auto locking at approx.10 mph, or after the Central Locking button is activated. Dependent upon vehicle equipment, the following permanent SAE faults may be stored in the vehicle: S 0219, No Communication possible with: Amplifier S 0261, No Communication possible with: Camera-based driver assistance S 0273, No Communication possible with: Headunit S 0313, No Communication possible with: All-round vision camera S 0386, No Communication possible with: Instrument Panel S 0394, No Communication possible with: Telematics control unit
MC-11010762-0001.pdf
SIB 34 03 24 (2024-10-11)
BMW 530I 2024
BMW I5 2024
SERVICE BRAKES
Improved diagnostic software for the brake system.
MC-11008992-0001.pdf
SIB 61 24 24 (2024-10-10)
BMW 530I 2024
UNKNOWN OR OTHER
Small debris may accumulate inside the volume control thumbwheel of the iDrive Controller. Existing gaps between the glass application and the light guide could allow external debris to enter inside the volume thumbwheel under normal usage. This debris can be seen through the crystal volume thumbwheel, giving the appearance of a cosmetic defect with the thumbwheel itself. Active lighting makes this debris more visible when illuminated. This could make the false illusion of a cosmetically defective volume thumbwheel more visible (many small dark spots or streaks).
MC-11008996-0001.pdf
RECALL 24V739000 (2024-10-02)
Affecting 11579 total vehicles built between 2022-11-12 and 2023-10-18
BMW 530I 2024
BMW 530I XDRIVE 2024
ELECTRONIC STABILITY CONTROL (ESC), SERVICE BRAKES, HYDRAULIC: POWER ASSIST: ELECTRIC: CONTROL MODULE
BMW of North America, LLC. (BMW) is recalling certain 2023-2024 X1, X5, X6, X7, XM, 530i, i5, 740i, 760i, i7, and 750e vehicles. Please see the recall report for a complete list of models and model years. The integrated brake (IB) system may malfunction and result in a loss of power brake assist or cause the Antilock Brake (ABS) and Dynamic Stability Control (DSC) systems to not function properly.
RCRIT-24V739-1109.pdf
RCRIT-24V739-5692.pdf
RCRIT-24V739-5275.pdf
RCRIT-24V739-9702.pdf
RCRIT-24V739-5310.pdf
RECALL 24V714000 (2024-09-26)
Affecting 982 total vehicles
BMW 530I XDRIVE 2024,2025
BMW 540I XDRIVE 2024,2025
STEERING: LINKAGES: KNUCKLE: SPINDLE: ARM
BMW of North America (BMW) is recalling certain 2024-2025 530i xDrive, 540i xDrive, 2024-2025 i5 eDrive40, i5 M60 xDrive, 2025 i5 xDrive40, 2024 740i xDrive, 760i xDrive, 750e xDrive, i7 eDrive50, i7 xDrive60, and i7 M70 xDrive vehicles. The steering spindle may break requiring a greater steering effort to control the vehicle.
RCRIT-24V714-9650.pdf
RCRIT-24V714-3745.pdf
RCRIT-24V714-5744.pdf
RCRIT-24V714-6996.pdf
SIB 61 18 24 (2024-09-24)
BMW I5 2024
ELECTRICAL SYSTEM
A manufacturing defect in high-voltage cells of the high-voltage battery can result in electrolyte leakage which might result in a conductive connection with surrounding components. Depending on the contact resistance, a yellow or red Check Control message will then be displayed; it is permitted for you to continue driving, but this will result in a charging interruption during charging.
MC-11008114-0001.pdf
RECALL 24V697000 (2024-09-19)
Affecting 309 total vehicles built between 2024-05-08 and 2024-05-08
BMW 530I 2024
BMW 540I 2024
BMW I5 2024,2025
ELECTRONIC STABILITY CONTROL (ESC): CONTROL MODULE, SERVICE BRAKES, HYDRAULIC: ANTILOCK/TRACTION CONTROL/ELECTRONIC LIMITED SLIP: CONTROL UNIT/MODULE
BMW of North America (BMW) is recalling certain 2023-2024 X1, 2024-2025 X5, 2025 X6, 2023-2025 X7, 740i, 760i, 2024 XM, 530i, 540i, i7, 750e, X2, 2024-2025 i5, 2024 Rolls Royce Spectre, 2025 MINI Countryman S ALL4, JCW Countryman ALL4, and 2025 MINI Hardtop 2 Door (Cooper, Cooper S) vehicles. Please refer to the recall report for the complete list of models. The welds in the servomotor of the integrated brake control module may break, causing a loss of power brake assist and rear brake function. In addition, the Antilock Brake System (ABS) and Dynamic Stability Control (DSC) system may not function.
RCRIT-24V697-3953.pdf
RCRIT-24V697-3624.pdf
RCRIT-24V697-4497.pdf
RCRIT-24V697-5803.pdf
RCRIT-24V697-1756.pdf
RCRIT-24V697-2103.pdf
RCRIT-24V697-2669.pdf
RCRIT-24V697-8245.pdf
RCRIT-24V697-2666.pdf
RCRIT-24V697-8204.pdf
RCRIT-24V697-4928.pdf
RCRIT-24V697-6869.pdf
SIB 63 02 24 (2024-08-21)
BMW 530I 2024
ELECTRICAL SYSTEM, VISIBILITY/WIPER
After programming the vehicle or completing aBMW RSU (Remote Software Upgrade), theblue accents (arrows) of both headlights arenot functioning.
MC-11006746-0001.pdf
This is an automated post created with code written by a human.
Appreciate 5
nacs2735.50
SkykingUSA8240.50
grc_uk97.50
MiGs550e2354.00
alewifebp600.50
      08-26-2025, 07:59 PM   #3
SpaceSilverX1.
418
249
Drives: U11, G60, W211, AZ20
Originally Posted by analogue View Post
SIB 61 01 25[/URL] (2025-07-18)
BMW 530I 2024,2025 ( plus 2 other models )
UNKNOWN OR OTHER
Thanks for the list.
wow! I never say this, but I sure hope that my 530i has that defect!
unless it does, but I'm just not driving dynamically enough to force the washer fluid out? I'll try to drive harder to see if I can induce the defect.
and if it does, I'm going to insist that my BMW dealer to never apply the fix!
SkykingUSA8240.50
MiGs550e2354.00
      08-30-2025, 11:16 AM   #4
RockdriveMD
RockdriveMD's Avatar
20
13
Drives: BMW IX, BMW I5
Thank you
SkykingUSA8240.50
Touringi5501.00
      01-06-2026, 01:01 PM   #5
analogue
analogue's Avatar
937
526
Drives: 1M, iX
New 2026-01-06
BMW I5 2024,2025
ELECTRICAL SYSTEM
BMW 530I 2025
ENGINE
BMW 530I 2026
ELECTRICAL SYSTEM
SIB 65 27 25 (2025-12-09)
BMW 530I 2026
ELECTRICAL SYSTEM
MC-11026963-0001.pdf
SIB 54 06 25 (2025-12-03)
BMW 530I 2024,2025
BMW I5 2024,2025
STRUCTURE: BODY
DELIVERY STOP: SUNROOF WATER DRAIN HOSE
MC-11026953-0001.pdf
Appreciate 4
SkykingUSA8240.50
Touringi5501.00
Scrapula5899.00
      01-23-2026, 07:31 AM   #6
analogue
analogue's Avatar
937
526
Drives: 1M, iX
New 2026-01-23
BMW 530I 2024
BMW 530I 2025
ELECTRICAL SYSTEM
BMW 530I 2025
STRUCTURE: BODY
BMW 530I 2025
ELECTRICAL SYSTEM
SIB 61 23 25 (2026-01-03)
BMW 550E 2025
ELECTRICAL SYSTEM
MC-11027773-0001.pdf
SIB 61 22 25 (2026-01-03)
BMW 550E 2025
ELECTRICAL SYSTEM
The malfunction indicator lamp (MIL) may be triggered by the erroneous fault code: BA0023 - Control unit: internal fault (software group fault) In addition, the BA0008 - CCU, internal coolant temperature sensor: Signal implausible faults may be stored in the CCU memory. However, AC charging will still operate as designed, without any related drivability complaints. Affected PHEV (plug-in hybrid electric vehicle) vehicles with CCU_P1 (7.4 kW and 11 kW) with I-levels from …24-07- 500 to …25-11-5xx.
MC-11027772-0001.pdf
SIB 61 19 25 (2026-01-03)
BMW 550E 2025
ELECTRICAL SYSTEM
SITUATION The malfunction indicator lamp (MIL) is triggered by the erroneous fault code 031BFC- AC charging, charging electronics 2,internal fault: No internal capacitor discharge stored in the CCU. However, AC charging is operating as designed without a charging concern or issue. Affected PHEV vehicles have the CCU-03 (7.4 kW / 11 kW) with I-levels from 24-07-500 to 25-11-5xx
MC-11027771-0001.pdf
BMW 530I 2024,2025
BMW I5 2024,2025
STRUCTURE: BODY
Touringi5501.00
Scrapula5899.00
      02-03-2026, 07:49 AM   #7
analogue
analogue's Avatar
937
526
Drives: 1M, iX
New 2026-02-03
BMW 530I 2025
STRUCTURE: BODY
BMW 530I 2024,2025
VISIBILITY/WIPER
SkykingUSA8240.50
      02-05-2026, 07:52 AM   #8
analogue
analogue's Avatar
937
526
Drives: 1M, iX
New 2026-02-05
InVehicle-InApp-Comm (2026-01-27)
BMW 530I 2025
AIR BAGS, ENGINE, POWER TRAIN, SERVICE BRAKES
It was determined that due to bad data input of the DSC, there can be damage to the rear axle differential of your vehicle. It is necessary that the control units in your vehicle are reprogrammed.
MC-11028297-0001.pdf
      02-07-2026, 07:31 AM   #9
analogue
analogue's Avatar
937
526
Drives: 1M, iX
New 2026-02-07
BMW 530I 2024
SkykingUSA8240.50
      02-24-2026, 07:58 AM   #10
analogue
analogue's Avatar
937
526
Drives: 1M, iX
New 2026-02-24
BMW 530I 2025,2026
ELECTRICAL SYSTEM
BMW 530I 2024,2026
STRUCTURE: BODY
SkykingUSA8240.50
      02-25-2026, 07:56 AM   #11
analogue
analogue's Avatar
937
526
Drives: 1M, iX
New 2026-02-25
SkykingUSA8240.50
      02-27-2026, 07:45 AM   #12
analogue
analogue's Avatar
937
526
Drives: 1M, iX
New 2026-02-27
BMW I5 2024,2025
There is coolant leaking from under the car Low heater output Possible Check Control message ?Drive, you can continue driving? (ID49) Possible fault codes stored in these BEV vehicles: 224163 ? Electric auxiliary heater for the high-voltage battery unit: Undervoltage or internal communication fault 8049AA - Coolant level sensor, expansion tank: Coolant level low or short circuit to ground or line disconnection 80124F ? Electric auxiliary heater: Communication in electric auxiliary heater faulty 224F60 - Coolant level sensor, expansion tank: Coolant level low or short circuit to ground or line disconnection 224111 - Cooling system for power electronics: Coolant loss detected 224107 - Cooling system for high-voltage battery unit, component protection: Detection of coolant loss
SkykingUSA8240.50
      03-04-2026, 09:27 AM   #13
Wolfman64
Wolfman64's Avatar
3682
1,531
Drives: M8C Coupe,E63s ED1,AMG GTC
Just FYI.
Since not all forum members reside in the US, I thought it might be helpful to list the corresponding German/European recall ID: 0061510900
The recall shows in the myBMW app but for the first week without any explanation.
SkykingUSA8240.50
arkhi635.00
      03-04-2026, 02:13 PM   #14
bavarianboar
bavarianboar's Avatar
883
2,050
Drives: 2020 540i, 2020 430i
Everything is broken.
But at least they are fixing it all!
Driving: 2020 540i M-Sport Carbon Black, Ivory Nappa - Dec 2019 BTO - Feb 2020 Delivery
Returned: 2016 535i M-Sport Carbon Black, Ivory Nappa :: 2014 F30 335i M-Sport Min Grey, Coral Red :: 2011 E90 328i Deep Sea Blue, Oyster Dakota
SkykingUSA8240.50
      03-14-2026, 08:34 AM   #15
analogue
analogue's Avatar
937
526
Drives: 1M, iX
New 2026-03-14
SIB 12 03 26 (2026-03-11)
ELECTRICAL SYSTEM
BMW AG is conducting Voluntary Emissions Recall (effective March 11, 2026) on certain Model Year 2023 -2026 BMW vehicles that were produced between January 14, 2022, and September 16, 2025.
MC-11030061-0001.pdf
BMW I5 2024
ELECTRICAL SYSTEM
Several complaints are possible: Vehicle does not start Gear cannot be engaged Various Check Control Messages Malfunction indicator lamp (MIL) on Several Check Control messages are possible: ?It is possible to continue driving. High-voltage system.? ?You can continue driving. Drivetrain.? ?Restart not possible. Drivetrain fault.? ?Call Roadside Assistance. Drivetrain failure.? ?Information: Total error of vehicle.? The following fault memory entries are stored in the CCU: D796D9 - Message (- 0x91) not up-to-date, receiver CCU, transmitter EME D796DC - No message (- 0x91), receiver CCU, transmitter EME D796D8 - No message (- 0x91), receiver CCU, transmitter EME Other fault codes below may be stored in the EGS BA09B8 ? Inverter, Voltage Sensor, 5V HV AUX: Out of range or open connection detected BA0A45 ? ECU internal: Internal error of the synchronous serial data bus. Additional fault memory entries are possible. Similar fault memory entries indicating a missing EMEmessage (Traction E-Machine Electronic) can also be stored in other control units.
ELECTRICAL SYSTEM
The malfunction indicator lamp (MIL) is triggered by the erroneous fault code 031BFC- AC charging,charging electronics 2, internal fault: No internal capacitor discharge stored in the CCU. However, AC charging is operating as designed without a charging concern or issue. Affected PHEV vehicles have the CCU-03 (7.4 kW / 11 kW) with I-levels from ?24-07-500 to ?25-11-5xx.
ELECTRICAL SYSTEM
ELECTRICAL SYSTEM
      04-28-2026, 06:28 PM   #16
analogue
analogue's Avatar
937
526
Drives: 1M, iX
New 2026-04-28
BMW 530I 2024,2025
STEERING
BMW I5 2024
ELECTRICAL SYSTEM
BMW 530I 2024
ELECTRICAL SYSTEM
BMW I5 2024
ELECTRICAL SYSTEM
Copyright ©2000 - 2026, vBulletin Solutions Inc.
