12-31-2024, 10:34 PM | #1 |
4445
Rep 1,057
Active Park Distance Control Question
Okay, so I've been fiddling with various settings this weekend and I do have a question about this feature.
In my Audi, when I pulled into the garage and approached the wall of the garage this came on automatically. I don't know if I turned something off in my exploration or if the G60 just doesn't do this when approaching an obstacle from the front, but it doesn't automatically 'turn on'. It works beautifully if I press the 'P)))' symbol on the console, and it always turns on when switching into reverse, but I've noticed I've had to activate it manually to better gauge my proximity to the front garage wall. I did go into 'Vehicle>Driving Settings>Driver Assistance>Parking and verified that it's toggled on, along with the other host of nanny anti-collision features there. Any thoughts on th is? |
01-01-2025, 01:06 AM | #2 |
915
Rep 234
I too press the park setting and then change camera view to car wash as there is a turn in our driveway and I like having the better view of my passenger front corner when pulling in….
01-01-2025, 01:23 AM | #3 |
4489
Rep 1,456
Drives: 2024 i5 eDrive40
It will come on automatically if you have a path saved and you have the setting turned on for activation points (it may be called something different, I don't remember right now). For example, when I pull into my driveway, the parking screen comes on automatically because the car knows I'm in my driveway and I have a path saved that takes my car into the garage.
If you want the same thing, just save a path in iDrive as you drive into your garage from your driveway. You don't have to use the path if you don't want to, but just because it's saved, the car will bring up the parking screens/cameras each time you return to the driveway in case you do want to use it. Give that a try.
01-01-2025, 01:25 AM | #4 | |
4445
Rep 1,057
AiredaleDad3388.00 MiGs550e1015.50 |
01-01-2025, 02:42 AM | #5 |
4489
Rep 1,456
I use a saved path most times when I enter the garage. I just stop in the driveway in about the right spot, then let the car pull into the garage and park me in the right spot. It is almost always centered side to side, and always leaves the exact distance in the front and back so the door can close, and so I don't run into the wall. :-)
01-01-2025, 10:17 AM | #6 | |
(OO=[][]=OO)
1016
Rep 235
(OO=[][]=OO)
SkykingUSA4489.00 |
01-01-2025, 10:47 AM | #7 | |
1851
Rep 1,115
Bluegrass Bimmers
Current: 2019 G30 540i M Sport | 2022 & 2018 G01 X3 xDrive30i Past: 2017 F30 340i M Sport/6MT | 2013 E70 X5 3.5 | 2011 E90 ///M3 6MT | 2005 E46 330i ZHP 6MT | 2001 E53 X5 3.0 | 2000 E39 528i Sport/5MT | 1998 E39 528iA | 1997 E38 740i | 1993 E36 318is |
01-01-2025, 02:58 PM | #8 | |
4489
Rep 1,456
RichardInCA5569.50 AiredaleDad3388.00 |
01-01-2025, 03:26 PM | #9 |
4445
Rep 1,057
Okay, I tried it. Recorded a path and bravely let it do its thing with a bit of brake riding 😅
I may redo this, as I recorded a path from the street, turning right, into my driveway and then into the garage. May I should have just gone with a “universal” on the driveway recording. I wasn’t sure if it was smart enough to understand doing the same manuever with a left hand turn into the driveway, so I recorded a second path. This is why I’m wondering if something more simple like beginning while on the driveway rather than the road might be more efficient. I guess it doesn’t really matter. |
01-01-2025, 04:31 PM | #10 |
(OO=[][]=OO)
1016
Rep 235
I reverse park in my garage does that change anything?
(OO=[][]=OO)
SkykingUSA4489.00 AiredaleDad3388.00 |
01-02-2025, 01:08 AM | #11 | |
4489
Rep 1,456
One thing to note - I think there is a minimum distance you need to travel for a path to record. I think it's about 20 feet minimum, or it won't be able to save the path. Keep that in mind when choosing your starting point. I don't think it matters, it should work either forwards or backwards. When parking in a parking lot, you can choose whether to park in the spot forwards or backwards, so I think it can handle either when recording a path. BTW, if you haven't tried the parallel parking feature yet, give it a try. I've used it a bunch of times to parallel park on the street and it works like a charm. I have to park on the street 2 or 3 times per week amongst other cars. One other thing - I'm not sure how many of these features requires the purchase of the Parking Professional option from the iDrive store. I think that purchase only buys you the remote parking feature and the ability to park between lines in a parking lot when there are no other cars parked beside you, but not sure.
01-02-2025, 08:23 AM | #12 | |
4445
Rep 1,057
Definitely will redo the parking manuever, based on this information, even though my “street” is more of a private road with only occasional residential traffic. Thank you! |
01-02-2025, 01:51 PM | #13 | |
3074
Rep 1,403
01-02-2025, 01:53 PM | #14 | |
3074
Rep 1,403
01-02-2025, 02:01 PM | #15 |
4445
Rep 1,057
Thanks for the heads up! I deleted the two where I started on the street, and replaced it with a single one where I started at the edge of the driveway. I’ll map a night version now.
01-03-2025, 01:57 AM | #16 |
3388
Rep 942
Drives: 2025 BMW 540i XDrive
I recorded one from the street to inside my carport, behind my wife's SUV. Works both day and night, but I also have a streetlight right across from my carport door.
SkykingUSA4489.00 ToddRGuy4445.00 |
01-03-2025, 03:25 AM | #17 |
4489
Rep 1,456
My single recorded path works both day and night as well. Perhaps because I have a motion sensing light above my garage door, so it's never really that dark in the area, even at night.
AiredaleDad3388.00 ToddRGuy4445.00 |
01-03-2025, 06:11 PM | #18 |
1209
Rep 706
Sounds like a lot of fun to ride in while just pressing the integrated garage openner button. I presume it won’t record that into the path for liability concerns, or does it?
Is anyone using this for remote park, or specifically for unparking? It can be very useful to unpark/repark the car for cleaning. And then there’s the underground garage where my daughter lives which has concrete pillars that make it had to get out of a larger car. It would be great to train parking and unparking, where those are two different paths, since unparking needs to end up pointing the car in the opposite direction from which I drove in. |
01-03-2025, 06:49 PM | #19 |
538
Rep 90
A related feature that sounds very cool to me as I peruse the manual is the ability to save certain activation points where the panoramic view automatically comes on. I pull out of an alley leaving work every evening onto a road where my view of cross-traffic, especially from the left, is almost always obscured by parked cars. Auto-panorama should be very handy for this. Cool tech if it works as described in the manual.
01-03-2025, 07:42 PM | #20 | |
3074
Rep 1,403
01-03-2025, 08:41 PM | #21 | ||
4489
Rep 1,456
To summarize, I have only used the "manual" option for remote parking, but the recorded paths do show as an option, I have just never tried them. Quote:
I have not tried creating a manual one yet for particular intersections like you're referring to, because I really don't have a spot like that, but I'll try one out anyway, to see how it works. During that 20% of the time when activation points don't pop up automatically, or when the drivers assistance PLUS does not pop up when I'm on the freeway, I believe it's either due to not getting a GPS signal or some other software-related or connectivity-related issue. I will usually reboot iDrive when I see this happening more than once or twice in a row and that solves the issue. Just two days ago, I was on the freeway and I wasn't getting the option to let go of the wheel like I usually get. When I arrived at my destination, I just rebooted iDrive, and since then everything worked normally again. I find that I need to reboot the system about 1 time per quarter - that is in addition to the OTA updates that come out once per quarter (roughly).
