12-15-2024, 05:08 PM | #1 |
347
Rep 71
Navigation display question
The nav system would show turns and distance to the next exit in the heads up display, but not on the nav screen itself. Is there a way to change that? Also, can it show a 2D display with north up instead of the 3D display?
12-15-2024, 08:48 PM | #2 |
5064
Rep 1,367
If you put the nav/directional view in the dashboard, it shows upcoming turns and the distance until those turns all stacked 3D. It also shows an image of the freeway exit signs. I switched mine to do this and put my music on the main screen. I’m not sure about always having north pointed up, as I always have it set from the driver’s point of view.
12-15-2024, 10:17 PM | #3 | |
347
Rep 71
SkykingUSA4489.00 AiredaleDad3388.00 |
12-16-2024, 01:08 AM | #4 |
4489
Rep 1,456
Drives: 2024 i5 eDrive40
I believe you can have north always up. There is a "button" on the screen when in Nav view that you can tap and it cycles through the 3 or 4 different views available.
12-16-2024, 11:42 AM | #5 |
347
Rep 71
I spent some time in it this morning and found that. Thanks! My wife will appreciate it. She thinks differently.
12-16-2024, 12:06 PM | #6 | |
643
Rep 202
Also, think you can put turn directions as a widget. I wish there was more info on turns like drive 7. |
12-16-2024, 12:14 PM | #7 |
5064
Rep 1,367
I have it on directional view. It still shows the camera with AI turns. I like the big freeway signs. Just in case I was zoning out, that alerts me to my exit. I found this setting when I had an i4 loaner without the HUD. I need to play more with widgets, but they always disappear so I haven’t bothered lately.
12-16-2024, 12:18 PM | #8 | |
643
Rep 202
12-16-2024, 02:22 PM | #9 |
3074
Rep 1,403
Augmented reality (camera view with superimposed arrows) should appear on either the main screen display or the instrument cluster display at turns depending on where you've set it to appear.
12-16-2024, 02:36 PM | #10 |
643
Rep 202
Normally, I put Ai behind the steering wheel. Sounds like I should switch to directional behind the wheel then ai will pop up at turns?
There is also a view can’t remember the name that shows car tracking around you without the camera view. Away from the car for a few days. Will have to check this out. Thanks |
12-17-2024, 07:05 PM | #11 | ||
5064
Rep 1,367
SkykingUSA4489.00 aherman18642.50 |
12-18-2024, 02:05 PM | #12 |
347
Rep 71
My dealer showed me how to use the buttons on the steering wheel to set things up. This changed the situation completely.
