      12-14-2024, 06:39 PM   #1
geneatals
Ninja
geneatals's Avatar
735
4,085
Drives: 2019 530e
IND reflector delete installed
Really easy to do. No need to even loosen up the bumper. Reflectors are accessible already. Just need a pry tool, heat gun optional to loosen up the adhesive. Just work your way around the reflectors.
Removed the OEM ambers ones and installed the paint matched reflectors in less than 10 minutes a side.
To get the new ones in, I inserted the bottom side first then angled the top into position. Practiced a few times before I took the adhesive tape off and really installed them. Used a MF cloth on the outside/front of reflectors and my fingers on the back side to apply some extra pressure and get the adhesive to stick and reflectors flush.
Current:2024 G60 550e
Retired: 2022 G30 530e, 2019 G30 530e, 2016 F80 M3, 2012 E90 M3 ZCP, 2008 535i
Appreciate 8
dfc888216.00
SkykingUSA4734.50
Scrapula5076.00
ToddRGuy4650.50
a3dewe373.50
      12-16-2024, 12:21 PM   #2
1SIK_I8
70
523
Drives: I8
Great information, I'm in the process of switching out mine and was wondering about taking off that top screw, loosening the inside wheel plastic, etc..
But I guess I don't have to do none of the above.
SkykingUSA4734.50
      12-22-2024, 07:24 PM   #3
JCB1242
Drives: '24 G60 540 M Plus
Where did u order?
SkykingUSA4734.50
      12-22-2024, 08:03 PM   #4
nacs
nacs's Avatar
1024
261
Drives: 550e, Ford 68 Deluxe
Originally Posted by JCB1242 View Post
Where did u order?
https://ind-distribution.com/product...-reflector-set
ToddRGuy4650.50
SkykingUSA4734.50
