Thread Tools
      10-25-2024, 01:43 PM   #1
usdk
12
Drives: BMW i5 Touring e40 M Sport
i5 Touring snow tire options
Hi,
I recently moved from California to Denmark, and, well, you need winter/snow tires here
I recently leased an i5 e40 Touring, and I absolutely love it!
But, the i5 Touring has different front and back wheel sizes. Mine was delivered with 245/45/19 and 275/40/19 (on summer tires). But now it's getting colder.
I'm looking for a tire + rim combo, but finding rims that can fit the 275 size is challenging, at least here in Denmark.
My question is, would it be OK to opt for 255/45/19 in the back?
I have limited experience with tires since, in California, I just drove on summer tires, which came with the cars (I had an X3e and a Palisade).
Is there anything else I should be mindful of? I have been told by a mechanic that they cannot program the TPMS, so I need to get the OEM ones.
Thanks!
SkykingUSA8202.50
      10-26-2024, 03:18 AM   #2
DomiGijzen
DomiGijzen's Avatar
Netherlands
312
284
Drives: BMW 530e M Sport Pro (G61)
Why 255? Just get same sizes all around for winter tires. This also enables you to use snow chaines.
Grz D.!
SkykingUSA8202.50
Llarry30112.00
      10-27-2024, 10:14 AM   #3
usdk
12
My thinking was that since the car is delivered with wider back tires, that is to sustain weight or something else. So that I should also have wider winter back tires. Chains is less of a concern, but I appreciate the tip!
SkykingUSA8202.50
      10-27-2024, 01:10 PM   #4
RichardInCA
RichardInCA's Avatar
7807
1,858
Drives: 24 BMW i5 M60
The width of the tire is more to do with getting power down efficiently. Not sure that logic holds for winter driving - I lived in Montreal before I moved to California and used to do the seasonal switch out to winter tires. The main things at play are to have a softer compound rubber that doesn’t turn so solid in sub zero temps (softer tires grip more, just like in F1), and a tread pattern to hold onto snow - it turns out that snow packed in the treads can help with traction with the snow on the road etc.
ToddRGuy5845.50
SkykingUSA8202.50
      10-28-2024, 08:13 AM   #5
usdk
12
Thanks for sharing these insights. I really appreciate it. My concern is still if I should go for 275 wider winter tires or if I can downsize to 255 (or even less) and what impact downsizing may have. The winter tires my dealership sells are 275 (back) and 245 (front), but they are extremely overpriced.
SkykingUSA8202.50
      10-28-2024, 08:48 AM   #6
AiredaleDad
AiredaleDad's Avatar
7034
1,884
Drives: 2025 BMW 540i XDrive MSportPRO
The stock rim size is 19 x 8.5" and has 245/45 R19 all season tires. If you have the 19 x 8.5" rims all around, you might be should be able to put 245/45 R19 snow tires on for the winter.
      10-30-2024, 03:26 AM   #7
usdk
12
Thanks for the info.
I have the M Sport version, which comes with summer tires (at least here) and 245/45/19 (front) + 275/45/19 (back). I'm not sure what the rim widths are, but I assume they're 8.5" + 9.5".
      10-30-2024, 04:06 AM   #8
AiredaleDad
7034
1,884
Understood. I also have the MSport and MSport Pro packages. Maybe there is a way you can check? I don't know about BMW Rims, but some have a stamp either inside our outside where it says the size. I ordered 20" 938 style rims, They are staggered with 20 x 8.5" in front and 20 x 10" rear, and they came with either All Season, or Summer tires. I chose the All Season tires. I was going to change my order for Summer tires, but that's when my build went to 150 and I was too late. In US Spec, the 19" M Sport rims (935 style) are all the same size. And only come with All Season tires. Since you have wider rear tires, you probably got wider rims as well. Maybe it's a Denmark thing, or a Touring thing. I wouldn't know, since the touring is not available in the US. I went on the Danish website, and it did not say the width of the rims.
SkykingUSA8202.50
      10-30-2024, 05:41 AM   #9
DomiGijzen
DomiGijzen's Avatar
Netherlands
312
284
Rims for 275 are wider than for 245. I have both sets (summer, winter). I think it's listed in the pricelist.
Grz D.!
SkykingUSA8202.50
      10-30-2024, 08:40 AM   #10
tsbrown
tsbrown's Avatar
2855
1,644
Drives: 2023 M550i xDrive
BMW uses a staggered setup for summer tires, wider in rear. It promotes understeer, which is safer in a way. Understeer scares the driver (so they slow down), oversteer scares the passenger. For winter tires you want a square setup, same width all around.
Bluegrass Bimmers
Current: 2023 G30 M550i xDrive | 2022 & 2018 G01 X3 xDrive30i
Past: 2019 540i M Sport | 2017 F30 340i M Sport/6MT | 2013 E70 X5 3.5 | 2011 E90 ///M3 6MT | 2005 E46 330i ZHP 6MT | 2001 E53 X5 3.0 | 2000 E39 528i Sport/5MT | 1998 E39 528iA | 1997 E38 740i | 1993 E36 318is
SkykingUSA8202.50
      10-31-2024, 02:18 AM   #11
usdk
12
Thanks for all the input. I forgot that the US is not blessed with the Touring version.
I managed to get a reply from BMW and they informed me that it is a requirement that the wheel size (width) on the back wheels are 275.
And yes, it requires wider rims, which is precisely why it's been challenging to find a set of four wheels since most (online) sellers only support a square setup.
SkykingUSA8202.50
Dnill18.00
      10-31-2024, 03:31 AM   #12
AiredaleDad
7034
1,884
Ah. I see. Sounds like you will have to buy them from the dealer then, unless you can order from a clearing house like Tirerack.com. I don't know if they sell in DK or if you have some equivalent.
SkykingUSA8202.50
      10-31-2024, 07:53 AM   #13
tsbrown
tsbrown's Avatar
2855
1,644
Doesn’t the local dealer parts department sell winter wheel/tire sets? They usually do to ensure you get what BMW recommends for your car. Not usually the cheapest option though.
Bluegrass Bimmers
SkykingUSA8202.50
      10-31-2024, 09:09 AM   #14
AiredaleDad
7034
1,884
Yes, He said that already. He's looking for a more cost-effective option because the dealership's prices are ridiculously high.
tsbrown2854.50
SkykingUSA8202.50
      10-31-2024, 03:25 PM   #15
tsbrown
tsbrown's Avatar
2855
1,644
thanks, I did read the thread completely at one point, just not right before I posted that. It happens...
Bluegrass Bimmers
SkykingUSA8202.50
      04-11-2025, 01:15 PM   #16
Machinebuilder
Machinebuilder's Avatar
389
292
Drives: I5, I4 Mini Cooper Se,Outback
I am going to put on 245/50-18 square on older BMW 8 x 18 wheels I had on my G32 640GT (same size as 7 series) The rims are 1/2 " narrower but the tire width size is the same as the stock 245/45-19's on the car. I put one on and I can not see or measure a difference. I will report back.
SkykingUSA8202.50
      04-12-2025, 02:14 AM   #17
JohnOuick
JohnOuick's Avatar
168
40
Drives: BMW G61 520D
Usually, my local tire shop looks what's allowed in the conformity certificate and find the most cost effective alternative.
I'm really surprised there would be no square setup. From my understanding there is one in 19 inch for M sport pro and both 19 et 18 on others.
SkykingUSA8202.50
      10-24-2025, 03:47 AM   #18
Dnill
18
Drives: i5 Touring
I had the exact same dilemma for this winter (i live in Sweden) and indeed the touring needs to have the f/r 245/275 setup as this is what it says in its conformity letter. According to the dealer they will void the warranty on the suspension etc if you mount other rim/tire sizes to the car and they can prove it. For the sedan though, a square setup is OK.
My car is an i5 edrive40 touring with the M-sport package.
SkykingUSA8202.50
      10-24-2025, 05:23 AM   #19
Wolfman64
Wolfman64's Avatar
3602
1,511
Drives: M8C Coupe,E63s ED1,AMG GTC
In Germany and perhaps other countries in Europe you can lease a BMW with a set of winter wheels as an add-on. Even with wheel storage.
I mentioned in another post that I rather buy a set of tires but if full sets are of interest just go with BMW winter set options.
You can just buy a set from BMW for your car or from EBay. Likewise you can sell it on EBay if you swap cars after the lease in case the size changes.
BMW sets are original 19” BMW rims with a straight set.
If you go staggered and just swap tires, go with the original sizes…
EDIT
Just realized that this is an ancient thread.
SkykingUSA8202.50
Copyright ©2000 - 2026, vBulletin Solutions Inc.
