      09-14-2024, 08:55 PM   #1
arkadhome
Drives: 2024 530i
recommended washer fluid for 2024 530i
Folks,
Anyone knows if there is a recommended windshield washer fluid to use / not to use for 2024 530i? Or just put in distilled water?
Arkadiy
SkykingUSA4487.50
      09-14-2024, 09:57 PM   #2
claykin
1672
4,601
Drives: various BMW
If you live in an area that freezes during winter, distilled water would not be a good idea. I suggest you buy a gallon of washer fluid from an auto parts store. Or take it to the dealer and they should top it off for no charge.
2023 840GC | 2021 740i | 2019 X3
ToddRGuy4439.00
SkykingUSA4487.50
      09-14-2024, 11:24 PM   #3
ToddRGuy
ToddRGuy's Avatar
4439
1,057
2025 BMW 540  [10.00]
Originally Posted by arkadhome View Post
Folks,
Arkadiy
Distilled water won't do much for bugs, etc. I see it says you're in the Golden State. Distilled water will also freeze solid if you're going into anywhere with below freezing temps, like the Sierra.
If you want to play it really safe, BMW makes a concentrate you can purchase for like $5-8 dollars. P/N: 83192221702
Just mix it with Distilled Water at a ratio that best describes the lowest temperatures you typically encounter.
Not sure how good it is, other folks that have used it can comment on that though
SkykingUSA4487.50
      09-14-2024, 11:28 PM   #4
whofelt
360
438
Drives: M340x Drive
go to your local parts store and buy washer fluid, this is not rocket science, i've never heard of using just distilled water, makes no sense.
2022 BMW M550 Xdrive (stock).
Appreciate 4
SkykingUSA4487.50
ToddRGuy4439.00
      09-15-2024, 01:15 PM   #5
Blue Sky
Blue Sky's Avatar
1206
706
Drives: F10 M5 CP, F10 550i
I just buy a jug of the blue washer fluid whereever opportunistically. It’s all the same. Large grocery stores often have it in their tiny little automotive section. So do pharmacy stores like Walmart and CVS. It contains a kind of anti-freeze agent so it won’t freeze and also prevents anything from growing in reservoir
      09-15-2024, 01:20 PM   #6
ToddRGuy
ToddRGuy's Avatar
4439
1,057
After thought: I would do research before deciding to use RainX products. I have read where people said that it both smeared their windshields, and created some clearcoat related issues. I can't attest to the validity of it, but I would do more reading before I'd consider using them.
SkykingUSA4487.50
      09-15-2024, 05:54 PM   #7
Blue Sky
Blue Sky's Avatar
1206
706
I gave up on RainX in the ‘80’s, because it leaves a smeary, prismatic sheen that looked to my eye like grease and defies wiping away, and worse leaves the trail of where you just wiped behind. Yes the water beading action is really great, but I don’t like greasy looking smudges on my car windshield.
That’s said, you can actually get a similar hydrophobic effect just by intensively cleaning the glass using a windshield clay bar the same way you would use a paint cleaning clay bar. I had a video somewhere where I rest a bottle of instant detailer on my car’s windshield which is pretty sloped. The bottle stays put from friction from microscopic dirt on the glass, even though the glass is quite clean from car washing and wiping down. Then I use the glass cleaning clay. Without applying any chemical coating afterwards, the bottle slides ride off the windshield if I try to rest it on it and it’s impossible to get it to stay put. Water beads up also and tends to blow off from the airstream if you are going fast enough.
ToddRGuy4439.00
SkykingUSA4487.50
      09-16-2024, 01:32 AM   #8
AiredaleDad
AiredaleDad's Avatar
Spain
3381
940
Drives: 2025 BMW 540i XDrive
Prestone makes on that is pretty good clearing bugs. It's orange in color. What you want to try to avoid is one with a high alcohol or ammonia content as this can deteriorate rubber gaskets over time.
SkykingUSA4487.50
ToddRGuy4439.00
      09-19-2024, 11:23 AM   #9
NJ530
54
29
Drives: BMW 530X
The BMW where I get my car serviced in NJ has a huge tank with complementary washer fluid
SkykingUSA4487.50
      09-19-2024, 03:37 PM   #10
RichardInCA
RichardInCA's Avatar
5570
1,364
Drives: 24 BMW i5 M60
Honestly….I think this is squarely in the “you might be overthinking it” category
Appreciate 4
SkykingUSA4487.50
LVBMW3067.50
NJ53054.00
      10-22-2024, 09:11 PM   #11
ToddRGuy
ToddRGuy's Avatar
4439
1,057
Sorry to resurrect a month old thread, but I do have a question regarding windshield washing on this car. I looked in the manual, however, I can't seem to find any information on the capacity size of the windshield washing reservoir.
Is anyone aware of this?
Also, from some earlier threads, seems there are spray nozzles on the exterior for the camera systems? How about headlights?
SkykingUSA4487.50
      10-22-2024, 09:45 PM   #12
SkykingUSA
SkykingUSA's Avatar
4488
1,456
Drives: 2024 i5 eDrive40
Here is a video showing how it works externally. It's in the menus somewhere, or you can ask the car to clean the cameras.
https://www.tiktok.com/@bmwblog.com/...40576188353822
I think you just fill it until you see the fluid. The manual shows a capacity of 2 Liters.
Here is an old thread about it too: https://g60.bimmerpost.com/forums/sh....php?t=2093611
No headlight cleaning is built in. You have to use your hand and a cloth with soap for that one!
ToddRGuy4439.00
