07-08-2024, 01:36 PM | #1 |
Rep 11
M850i, running a 0-60 time of about 5.0 seconds
Hi everyone, I have an M850i that I bought with 20k miles on it 6 weeks ago. I noticed it was definitely not performing as I expected since getting it. I bought a dragy and I'm reliably running a 0-60 time of about 5.0 seconds (4.9-5.3 seconds). Engine readout on the car is showing good HP and torque... above the 560 that the display caps it at.
I brought it to the dealer today and they told me, sorry, we can't see any codes... maybe the fuel that's in it isn't good enough. They suggested that I could only get a 0-60 time in the 3s if I was using launch control, not comfort or sports mode. What do you guys think? Anyone else have this kind of problem? What might be a good course of action for me? |
07-08-2024, 01:47 PM | #2 |
12420
Rep 4,312
Are you getting these times with launch control?
///M Power-Belgium71464.00 |
07-08-2024, 02:29 PM | #3 |
3337
Rep 3,278
I wouldn't think you would get into the 3s without launch control. I wouldn't necessary expect 5 seconds but 4s sound reasonable if you are just mashing the pedal from a standstill, without building revs.
07-08-2024, 05:27 PM | #4 | |
821
Rep 1,041
Drives: G31 540i; F87 M2 Comp.
07-10-2024, 10:28 PM | #7 |
1166
Rep 712
In comfort and sport the nannies reduce engine power and apply braking to prevent wheel spin. The numbers you are getting make absolute sense.
Try launch mode and post the results. |
07-11-2024, 09:24 AM | #8 |
Dont listen to me
916
Rep 648
OP, you are likely overthinking this and inventing a problem when there isn't one. It sounds like your car is running normally and the expectation of a specific 0-60mph time is not realistic.
Car manufacturers go to great lengths to post certain 0-60 times, but in reality, to get that published time, you must follow a very specific set of requirements for car setup, environment, road conditions, tire model, fuel level, density altitude, moon phase, etc. Then you have the actual measurement method of the time and when the time starts, such as the "1 foot rollout" rule.
Instagram: @thatwhitem4
07-11-2024, 03:33 PM | #12 | |
Rep 11
07-11-2024, 03:38 PM | #13 |
Rep 11
I have not tried this, I actually didn't know you could launch from 2nd, I'll see if it'll do it though! I can get as good as low 4s if I hold gas and brake for a second and then release brake, but it's really more just across the whole acceleration band when it's not a launch. Like I responded to the other guy, I feel like you'd kind of expect a flagship engine from bmw to be able to beat a mustang or a genesis across the band.
07-11-2024, 03:45 PM | #14 |
146
Rep 93
Are you using the cars actual launch control mode? You're not going to get the advertised 0-60 times if you're just mashing the throttle pedal from a standstill.
07-11-2024, 04:43 PM | #15 | |
412
Rep 1,458
Being a used car, I'd throw some Liqui Moly voodoo at it (Fuel/Injector/Oil cleaner - all of it) - might do nothing, but will cost you less than $100. I'd also find a reputable independent mechanic near you, ideally one who deals with modified cars regularly. You might have a minor boost leak. Are you slipping at all (i.e. tire grip)?
2017 X5M - Current
2017 F31 Wagon - Current 2014 M5 ZCP - Retired 2011 135i Coupe - Retired 2007 335i Sedan - Retired |
07-11-2024, 05:36 PM | #16 | |
Rep 11
I did think there might have been a bit of tire slip. The car came with all season run flats so I just bought some sweet Michelin pilot 4s summer tires. Really hoping that'll do something good. Thanks for the suggestion about the boost, I will follow through on that and let you know! |
eleven11412.00 |
07-12-2024, 10:57 AM | #17 | |
525
Rep 369
07-12-2024, 12:38 PM | #18 | |
Rep 11
07-12-2024, 12:51 PM | #19 | |
5340
Rep 5,137
are you using brake boost? i am presuming without brake boost it will be 5 seconds 0-100 the throttle response in every auto non hybrid BMW i've tested without brake boost is crap, even my 2007 Toyota moves off the line faster my 2.5 tonne EV Kia however, is 3.7 0-100 every single time (did >20 runs in an hour) without brake boost and it spins all 4 wheels all the way to 100 (now winter). i will try again in summer to see if i can get another 0.2 with better traction |
07-12-2024, 04:54 PM | #20 |
Rep 6
Definitely need car in sports+, traction control/ dsc mode off. And transmission should be flipped in sport as well. Launch control shouldn’t need to activate to reach 3s-4s. IMO, the car definitely has some issues if you cannot do that
07-12-2024, 05:09 PM | #21 | |
5340
Rep 5,137
So if you don't brake boost, it will crawl slowly until it hits 3000rpm before it flies. That thing weighs a good 2 tonnes. |
bimmertricks2.00 |
07-13-2024, 03:25 PM | #22 |
5340
Rep 5,137
did about 6 brake boosted 0-100 in a row in my 550 on a cold frosty morning today
average 4.2s, fastest i got was 3.99s never even bothered without brake boosting, i don't want to see the number lol my brake boosting is to let go as soon as the revs stop climbing (around 2100rpm), so i didn't even build that much boost, just enough to give it a kick in the ass. i feel the TC intervening in some runs so could have been faster with DTC but i don't want to be unsafe |
