      06-23-2024, 12:59 PM   #1
sebash
sebash's Avatar
27
108
Drives: 2021 Bernina Grey 540i M Sport
G30 wheels on G60?
Hey all. I have HRE wheels from my 2021 G30 and I’m wondering if you all know if the fitment is the same on the G60? Hard for me to find much info. Thanks.
SkykingUSA4489.00
      06-23-2024, 07:27 PM   #2
dsgs
239
84
Drives: 2024 BMW i5 M60
The OEM sizes are not the same, even for the same rim diameter, but the bolt pattern is the same. You could try https://www.wheel-size.com/size/bmw/5-series/ and see if they have what you need.
SkykingUSA4489.00
sebash27.00
      06-25-2024, 02:00 PM   #3
sebash
sebash's Avatar
27
108
Thanks so much. Since the bolt pattern is the same, the wheels will work, it’s just a matter of fitment?
SkykingUSA4489.00
      06-25-2024, 05:07 PM   #4
arkhi
240
202
Drives: 21 540i
The G60 OE rim is like 0.5 inches wider, but the G60 and G30 tire widths are the same. There's a 1-incb difference in tire diameter so a 19-in G30 tire/wheel will look like 18-inches on a G60 using the same wheel since the tire will be bigger. Offsets are very similar between the two so you should be fine.
Just make sure you get the correct tire width/diameter for your G60.
sebash27.00
SkykingUSA4489.00
      06-25-2024, 06:36 PM   #5
sebash
sebash's Avatar
27
108
Needs low but they fit perfect.
SkykingUSA4489.00
      06-25-2024, 06:52 PM   #6
dsgs
239
84
Seems the wheels fit, that's great! It's hard to tell from your photo, but if those are 285/30R20 tires you may want to consider getting some 275/35R20 OEM-sized tires. 285/30R20 is 3.3% smaller in diameter than the 275/35R20. You should also check the tire load rating. The G60 is heavy (especially the i5).
https://tiresize.com/calculator/ can be useful.
Scrapula5064.00
SkykingUSA4489.00
      06-25-2024, 09:53 PM   #7
sebash
sebash's Avatar
27
108
Yep. Those are the tires and wheels from my G30. I need a little more meat on them for this ride. Now I gotta find/wait for lowering springs! I haven’t found any available yet.
SkykingUSA4489.00
      06-26-2024, 06:13 PM   #8
sebash
sebash's Avatar
27
108
Here’s a better look at the fitment.
SkykingUSA4489.00
      06-27-2024, 02:27 PM   #9
drmlee
70
151
Drives: F06 650i
i also swapped my bbs cir's from the g30 to the g60. the rear fitment seems identical to where its sits dead flush with the same 15mm spacer. the front wheel, on the g30 was flush without a spacer, but on the g60 it looks like i need to add 10-12mm spacer to get the same look and fitment. tpms from the g30 works on the g60. i had to buy new tires as the g30 fitment is smaller in profile/diameter and it looks crazy high with thinner tires.
SkykingUSA4489.00
Scrapula5064.00
      06-29-2024, 01:37 PM   #10
sebash
sebash's Avatar
27
108
Pictures didn’t upload last time. Here’s a look at my fitment. So far Covra Suspension is the only company making lowering springs. I don’t know anything about them. As for now I’m gonna wait for H&R.
SkykingUSA4489.00
