| 04-18-2024, 04:40 PM | #1 |
164
Rep 43
Driver seat moving all the way back
Sometimes when I get into the car as the driver, the driver seat starts moving all the way back pretty fast making a strange noise (as if it is scratching against something) instead of moving forward to the saved position. I then have to use the memory button to get it to the saved position. It happens maybe 1-2 times per month.
Has anyone else observed this issue? |
| 04-18-2024, 05:50 PM | #2 |
50
Rep 23
You’re probably referring to the feature called Comfort Exit.
With that, your seat will move backwards to give you more space for entry/exit. Once you buckle up, the seat should return to you saved driving position. |
SkykingUSA8348.00 |
| 04-19-2024, 05:17 PM | #3 |
164
Rep 43
Nope.
Comfort access works as designed about 49 out of 50 times. But every once in a while when I get in the seat first moves a bit forward and then all the way back with a scratchy noise and very fast. It’s rare so haven’t been bothered too much, and I can’t consistently replicate it. Just wondering if anyone has had the issue. |
| 04-19-2024, 05:27 PM | #4 |
50
Rep 23
Sounds like a defective seat and potentially dangerous. You should bring it in to your dealership for diagnosis. Good luck!
| 04-19-2024, 07:08 PM | #5 |
![]() 7834
Rep 1,863
Drives: 24 BMW i5 M60
I’ve not heard or experienced anything like this with my i5 M60 after 5months ownership. Agree with Silvermember that this should go to the dealer.
| 04-24-2024, 11:36 AM | #6 |
103
Rep 29
I am also having issues with my seat. Whenever i used to open my door before, the seat used to go back as expected for comfort entry, but it does not move when I open the door anymore. Also, when I turn off the car to exit, it goes forward and then slightly back. Something seems to be off because it is operating very unusually. Also, I have tried resetting my seat, turning on/off comfort entry/exit. Taking it to the dealership soon.
SkykingUSA8348.00 |
| 04-24-2024, 11:42 AM | #7 | |
![]() 7834
Rep 1,863
SkykingUSA8348.00 Scrapula5918.50 |
| 04-24-2024, 11:44 AM | #8 |
103
Rep 29
Yes, that might be the case as well. But it is working weirdly when buckling/unbuckling seatbelt as well.
RichardInCA7833.50 SkykingUSA8348.00 |
| 04-24-2024, 12:07 PM | #9 |
![]() 5716
Rep 2,451
Yes, comfort access is related to buckling and unbuckling the seatbelt.
SkykingUSA8348.00 |
| 04-24-2024, 01:04 PM | #10 |
![]() 8348
Rep 2,401
Drives: 2024 i5 eDrive40
Have you tried rebooting iDrive?
| 05-30-2024, 12:36 PM | #11 |
39
Rep 24
Drives: 2024 BMW 530i xDrive M Sport P
Just started having problems as well. When I unbuckle my seatbelt, the seat moves back as advertised but instantly moves back forward even past my saved seat position.
| 06-03-2024, 04:00 PM | #12 | |
![]() 130
Rep 35
Can't believe a $94,000 vehicle new is having bullshit issues like this. Like, come on. How does something like this even happen? |
SkykingUSA8348.00 |
| 06-03-2024, 04:05 PM | #13 | |
39
Rep 24
SkykingUSA8348.00 |
| 06-03-2024, 04:10 PM | #14 | |
![]() 130
Rep 35
I notice that if I move the seat all the way to the back of the track, it stops then moves itself all the way forward. I did this, then hit Seat Position 1, and it went to its normal seat position. I inched the seat forward a tiny amount and set that to position 1, and it works without issue. I don't think the issue is a problem with comfort exit at this point, but a problem with the seat hitting the back of the track. Also curious -- before it started going all the way forward, did you notice that it would go back like normal, stop, then adjust forward a slight amount? Mine did that for a few weeks before it started going all the way forward today. Last edited by MrMoose0987; 06-03-2024 at 04:19 PM.. |
| 06-05-2024, 05:01 AM | #15 | |
39
Rep 24
Yeah I also had that problem for a couple weeks then I eventually turned off comfort exit because it was annoying. |
SkykingUSA8348.00 |
| 06-05-2024, 08:30 AM | #16 |
![]() 424
Rep 196
When the seat is moving forward after buckling seatbelt, you cannot push / apply pressure to the seat backwards. That will cause the forward movement to be cancelled.
SkykingUSA8348.00 |
| 06-05-2024, 12:03 PM | #17 |
164
Rep 43
SkykingUSA8348.00 |
| 06-05-2024, 05:03 PM | #18 |
326
Rep 172
Drives: BMW i5 eDrive 40
I have some thing similar and I have to press the pre set button to return the seating position. Never happened while driving though, normally happen after entering the car but can’t tell the detail.
SkykingUSA8348.00 |
| 06-26-2024, 02:39 AM | #19 |
![]() 7222
Rep 1,924
Drives: 2025 BMW 540i XDrive MSportPRO
Calibrating the front seat
1.Press the longitudinal direction switch for-ward until the seat stops. 2.Press the switch forward and hold it untilthe seat stops moving forward. 3.Readjust the seat to the desired position. As soon as the message on the control display disappears, the calibration is complete. If the message remains active, repeat the calibration. If the message is still shown after repeated calibration, have the vehicle checked by an authorized service center or another qualified service center or repair shop. |
SkykingUSA8348.00 pixelcort46.00 |
| Bookmarks |
