04-14-2024, 08:33 PM | #1 |
221
Rep 218
Charging Door Won’t Unlock
The other day I pull in to my garage and walk around to open the charge port door and it won’t open. I unlock/lock the door 50 times. Nothing. Try the real key, the digital key…nothing. I started the car and took it for a quick ride around the block and when I pulled back in the port door was unlocked. Figured oh well.
It’s happening again now! The @#$!@# door won’t unlock. Any tips on what I can do? Thanks in advance. |
04-14-2024, 08:46 PM | #2 |
136
Rep 128
there should be something in the setting to unlock the charging flap. hopefully it will work for you.
SkykingUSA4489.00 |
04-14-2024, 08:51 PM | #3 |
5570
Rep 1,364
Drives: 24 BMW i5 M60
I also read a post on another forum about an i5 user who took delivery and his charging port door stuck shut. It needed a fix at the dealer/replacement. If it’s not obvious from the settings, it’s probably worth a check-in with the dealer.
SkykingUSA4489.00 Tek-dad220.50 |
04-14-2024, 08:57 PM | #4 |
570
Rep 159
I've had this issue sometimes, I just locked the door (for the car) and unlocked and the charging door would open.
04-15-2024, 11:42 AM | #5 |
5455
Rep 2,972
This happened to me last week. Car was unlocked, parked in our garage. Charger door would not unlock. I locked and unlocked the car with digital key+ and even went and got the actual key fob...charger door would not open. I tried locking and unlocking from inside the car with the door lock buttons....charger door would not open.
Then randomly, the charger door let me push to open it :/ It has not happened again, but could have been an issue if trying to public charge and being critically low. |
04-15-2024, 07:37 PM | #6 |
5064
Rep 1,367
This finally happened to me today. I tried unlock, lock, toggled settings in the car, walked away, came back, etc. I finally turned on the car and then turned it off. That worked. This time.
04-15-2024, 10:00 PM | #7 |
221
Rep 218
It’s crazy right? When it happens there is no way to get the port open! So far it’s happened twice to me.
04-16-2024, 10:42 AM | #8 |
435
Rep 206
Happened once to me, I lock and unlocked the car and then it worked. Perhaps they should have made it a mechanical switch accessible from inside the vehicle. Sort of like a lot of cars have to pop open the gas tank cover.
05-02-2024, 09:15 AM | #9 |
54
Rep 17
This just happened to me as well. I've only had the car for two days. Tried locking/unlocking several times. Nothing.
Luckily I have 60% right now, so should be ok for a bit. But this is definitely something that will need to be fixed. Has anyone successfully gotten this addressed at the dealer? |
SkykingUSA4489.00 |
05-02-2024, 10:11 AM | #10 |
221
Rep 218
The problem is when the car was in the dealer they could not replicate it!
But it’s definitely a thing. Not sure what the solution is. |
SkykingUSA4489.00 |
05-02-2024, 12:58 PM | #11 |
5064
Rep 1,367
Happened again last night. I turned the car on, then off, and it opened. Definitely glitchy.
SkykingUSA4489.00 LVBMW3073.50 |
05-02-2024, 07:45 PM | #12 |
4489
Rep 1,456
Drives: 2024 i5 eDrive40
The same thing happened to me once about 2 weeks ago, but I was able to fix it by simply locking and unlocking the car again.
05-03-2024, 08:21 PM | #13 |
671
Rep 190
Happened to me last Friday. Wonder if it is. Coincidence since I did the software update a few days before. Couldn’t open it at all even tried setting the filler door to always in lock. Went back a few hours later and it was working again. I also did the reset by pushing down on the volume button until it reset. Also a few things didn’t work the 2 days later. No CarPlay. Brought it in and they reprogrammed it apparently. Said they could t reproduce the fault.
05-03-2024, 11:36 PM | #14 |
Chief Engineer
1852
Rep 425
Drives: 2024 I5 M60
what happens is that if you have the charging door set to always be unlocked the spring loaded door latch gets sticky and at times does not release the charge door. To fix this I just set it to look when car locks then lock and unlock door a few times and problem is solved. I am going to get some lubricant and put it on the spring loaded part this weekend.
2024 i5 M60 Carbon Black / M Veganza-Alcantara Black / Grey Blue Ash Trim Dk Silv Acc / Executive Package / Driving Assistance Pro Package / M Sport Professional Package / 20" Bicol JetBl 938M AS NonRFT / Front and Rear Heated Seats / Front ventilated seats
05-07-2024, 05:56 AM | #15 |
671
Rep 190
Car wouldn't charge again. Door unlocked but this time kept getting charger cable unlocked message on app. I am using My Tesla HPWC with an electron adaptor. Real PIA. I think this car seems to be finicky. Also occasionally the hand gesture to fast forward to next song doesn't work. It recognizes the gesture but doesn't fast forward.
05-07-2024, 11:29 AM | #16 | |
5570
Rep 1,364
I’ve had the “no next track” issue you describe a few times - I think it’s some Bluetooth CarPlay issue from what I can tell. Tends to resolve when I next start the car. |
05-07-2024, 01:35 PM | #17 | |
671
Rep 190
SkykingUSA4489.00 RichardInCA5569.50 |
05-07-2024, 01:40 PM | #18 |
671
Rep 190
Had weird CarPlay issues again this morning. Taking my son to school we got in the car, carplay was working normally paired up by the time I put it in drive. Made a stop at a store on way home, no CarPlay. A few hours later went out again, still no CarPlay. Took videos of all these things. Made a call on phone BT worked, but not through CarPlay. Went into the app for CarPlay and my phone was there, proceeded to go through the steps to choose my phone and after about a minute it paired. No other phones paired with the vehicle, and I was alone. Going back to dealer again tomorrow.
SkykingUSA4489.00 Scrapula5064.00 |
05-07-2024, 06:15 PM | #19 | |
4489
Rep 1,456
I hope this helps.
LVBMW3073.50 |
05-08-2024, 11:46 AM | #20 |
671
Rep 190
Thanks saw that but I don’t have that one. The adaptor I have is for the Tesla home charger.
SkykingUSA4489.00 |
05-09-2024, 01:18 AM | #21 | |
Chief Engineer
1852
Rep 425
Drives: 2024 I5 M60
SkykingUSA4489.00 Bklyn670.50 |
05-10-2024, 06:51 AM | #22 |
671
Rep 190
Thanks I thought the same thing about the hand gesture. But it worked with the hard buttons on console. And the loaner they gave me charged no problem. They are trying to sort it out. Just figures it's working fine as soon as I got to the dealership.
