      04-05-2024, 01:48 PM   #1
opposer
15
35
Drives: Subaru STI EDM 2005
325ci e46 - Brake pedal to the floor after spinning
Hi.
I tried to drift my e46 (it has a locking diff and a manual)
After being spun, the brake pedal becomes absolutely soft - falls to the floor and the car doesn't brake. If you press it one more time - it becomes firm again like always.
I disabled totally the DSC (holding DSC button for 5secs).
What can be the problem? Maybe I should take out the ABS fuse before drift training?
The brake fluid is fresh and level is ok.
      04-05-2024, 02:04 PM   #2
tracer bullet
tracer bullet's Avatar
3905
4,365
I like the line of electronic thinking, but - is there a chance your brake fluid level is low and you momentarily slosh the fluid up to the side and let some air in? I wouldn't think it'd suddenly purge back out right afterwards so probably not, but - maybe check the level?
      04-05-2024, 11:06 PM   #3
cbpip
cbpip's Avatar
264
275
Drives: BMW Z4C 3.0si 3 pedal
2007 BMW E86C  [10.00]
Could be pad knock back.
      04-06-2024, 03:05 PM   #4
M3SQRD
M3SQRD's Avatar
4073
7,644
Drives: G20 330ix,F22 240iX,e92 M3
I agree. It sounds like the brake piston(s) are getting pulled back off of the pads and into the caliper while drifting. Getting the pedal back after pumping/bumping the brake pedal once and then works properly again. There’s not much you can do with stock calipers. The usual solution is to install 6 lbf/in anti-knock-back springs behind each piston.
