bimmerpost/
BMW M2 and 2-Series Coupe
home
BMW M2 Forums 2023+ (G87) Exterior Modifications
      03-09-2024, 09:24 AM   #1
tonyle_7
Drives: G87 M2
Front Bottom Lip Removal
Hey guys, I just received my Stradale front grill protector but I’m having trouble removing the lower front lip (black trim) to install it.
I’ve watched videos and have removed the 2 push pins, 4 10mm screws and 6 upper clips however it’s still firmly attached. I’m afraid of pulling hard to detach it since I thought it would be easily removable and don’t want to damage anything. Has anyone removed the piece? Is it suppose to come loose? Or do I need to pull hard?
Thank you
mtenhoven125.50
      03-09-2024, 09:33 AM   #2
mtenhoven
mtenhoven's Avatar
126
172
Drives: 2023 Z4 sDrive30i & 2024 M2
There are eight clips in total. Two of them sit to the outside of each sensor along the top edge.
      03-09-2024, 09:40 AM   #3
tonyle_7
Drives: G87 M2
Yea I miscounted, I unclipped them all up top. The issue is that the bottom part is firmly stuck even when I remove the push pins and screws. IÂ’d rather have the piece fully removed than squeeze it through.
      03-09-2024, 01:12 PM   #4
Dbimmer
Dbimmer's Avatar
52
47
Drives: M2 Frozen Pure Grey
2024 BMW M2 G87  [9.00]
I’m doing same process later today. I’ll see what else will be needed. Or if you solve it please give some feedback
      03-09-2024, 09:19 PM   #5
tonyle_7
Drives: G87 M2
Let me know if it came off easily for you after taking off the pins/screws/clips
      03-09-2024, 09:47 PM   #6
Dbimmer
Dbimmer's Avatar
52
47
Decided to remove the entire bumper. Or mostly, to have a gap large enough to get the screen in. Only one side of the wheel well off to get some room. Gave up doing only that part since clips where kind of stubborn.
      03-11-2024, 02:17 PM   #7
DBV
DBV's Avatar
788
962
Drives: G87 M2, G20 330d, Brabus Smart
2023 BMW M2  [9.17]
2018 Brabus Smart  [10.00]
2021 BMW 330d  [10.00]
I recently replaced the entire front bottom piece, and was surprised at the amount of screws I had to remove. Double check you have them all out. Once I had them all off, the bottom was easy to pull off.
@DBV_
Current: '23 G87 M2 6MT / '21 G20 330d / '18 Brabus Smart
Gone: '21 G05 X5 M50d / '18 MB C63s (632hp) / '16 F80 M3 6MT (570hp) / '09 F01 750i / '16 Abarth 595 Competizione (202hp)
g87
