02-08-2024, 03:52 PM | #1 |
Rep 1
New Electric install recs
I just purchased my new i5 m60 and have an electrician running the wires to my garage. Given that I require extensive install as circuit is far from garage, should I have an outlet installed to just use the provided NEMA 14-50 charger
Or buy a separate dedicated charger and have a 60;amp breaker installed. Essentially I would not be using the provided level 2 for anything then Thanks for the thoughts |
02-08-2024, 03:58 PM | #2 | |
3074
Rep 1,403
SkykingUSA4489.00 |
02-08-2024, 03:59 PM | #3 |
Chief Engineer
1852
Rep 425
Drives: 2024 I5 M60
I installed a Charge Point Home Flex half way down my driveway so plugging in every night is super simple. Has worked flawlessly and I only need about 5 feet of cable to plug in to my car. I recommend getting a level 2 charger installed. FYI if you are running wires underground you might need a permit.
2024 i5 M60 Carbon Black / M Veganza-Alcantara Black / Grey Blue Ash Trim Dk Silv Acc / Executive Package / Driving Assistance Pro Package / M Sport Professional Package / 20" Bicol JetBl 938M AS NonRFT / Front and Rear Heated Seats / Front ventilated seats
LVBMW3073.50 SkykingUSA4489.00 |
02-08-2024, 04:01 PM | #4 |
Chief Engineer
1852
Rep 425
Drives: 2024 I5 M60
You can also get the Nema 14-50 plug installed at same location as the charger and if anything goes wrong with your level 2 then just unplug it and plug in the one that came with the car.
02-08-2024, 06:48 PM | #5 |
671
Rep 190
If you go with a Nema make sure you get the right one. The home depot lowes ones are not really reliable long term.
Honestly the Level 2 is simpler to use. Sure it cost more upfront but the ease of use is worth it. And check with your local power company some offer significant programs to lower costs for install or offer money back to monitor the use. I have ConEdison in NY and get a "reward" for charging off peak. |
02-09-2024, 04:27 AM | #6 | ||
4489
Rep 1,456
Drives: 2024 i5 eDrive40
There are some downsides too with my decision.
For me, I think the benefits outweigh the downsides. By the way, I decided to go with the Emporia EV Charger that was reviewed on the State of Charge site because it seemed to be a great deal for what you get. I don't have a review of it yet since I don't have my car to plug it into, but based on Amazon reviews and the State of Charge channel review it should do the trick. All I can say so far is that it powered up right away and I was able to connect to it with the Emporia app on the first try. Once I connected to it and it connected to my wifi, it immediately downloaded the latest update and is now ready to go. The whole connecting and updating process only took about 3-5 minutes.
02-09-2024, 09:59 AM | #7 |
5570
Rep 1,364
Drives: 24 BMW i5 M60
I added a 60A circuit and put in a BMW Wallbox. No complaints on my side - it’s faster than the L2 at my office. There’s a fairly common point that if you put an outlet in then you want to make sure it’s a high quality outlet that will take both the amount of current that goes through it (probably the highest single draw in your house) and will be robust enough to take a cable being plugged in/removed many times.
02-09-2024, 01:01 PM | #8 |
517
Rep 132
Drives: BMW i5 eDrive 40
I don't remember where on YouTube I heard this, but someone said that 240v outlets are not designed for frequent plugging-unplugging which implies you wouldn't want to do that with the Flexible Fast Charger.
