01-31-2024, 09:27 PM | #1 |
![]() ![]() 5635
Rep 5,202
reason for larger rear wheel and narrower front tire?
i see a few cars that BMW spec with either
- larger rear wheel vs front - 10mm wider rear tire vs front - or both what is the reasoning for this? i presume it has something to do with performance? |
02-01-2024, 09:52 AM | #5 |
![]() ![]() 4596
Rep 8,139
A 20” dia rear with a 285/30 tire and a 19” dia rear with a 285/35 tire have the same tire rolling dia but the 20” setup has a longer contact length (circumferential direction, same contact patch width of 285 mm). This would increase the rear’s ability to put the power/torque to the ground.
Smaller front dia wheel will reduce the rotating inertia compared to a 20” front dia wheel so turn-in/change of direction is a little easier to initiate. Staggered F & R tire widths help dial in understeer, which is safer, and allows the car to more easily get the power/torque to the ground. |
02-02-2024, 07:04 AM | #6 |
![]() ![]() ![]() ![]() 1014
Rep 812
It's for when you are at the drag strip, you can pop a wheelie easier with a lighter tire in the front.
nyalpine907753.00 |
02-02-2024, 08:33 AM | #7 | |
![]() ![]() 4216
Rep 4,601
I'm not saying you're wrong, just not seeing it. Care to explain further? Usually fatter rear tires shorten the front / rear contact patch length and can help limit sliding sideways, but are worse for actually putting power to the ground. The size of the contact patch is psi / weight dependent and the dimensions of the tire change the shape of the patch sideways vs front to back, but the overall size remains the same. Shorter in the front to back direction makes spinning the tires more likely, not less, when hitting the gas. |
02-02-2024, 08:52 AM | #8 | |
![]() ![]() 4596
Rep 8,139
02-02-2024, 09:16 AM | #9 | |
15697
Rep 3,966
tracer bullet4215.50 |
02-02-2024, 10:00 AM | #10 | |
![]() ![]() 4216
Rep 4,601
Shorter sidewalls tend to stiffen the tires, sure, but in that direction, the bump absorbing direction. The actual tread of the tire which touches the road doesn't change much if at all. There's sort of a certain amount of tread "blocks" on the ground and they don't change unless of course the tire's like actually flat. True drag tires are sort of a different animal. They go wide of course, but they're also really low on pressure (15psi???) so that they get that front to back grip as well. Ever seen the slow motion take-offs and watch the wheel turn before the tire does and how the entire sidewall twists and buckles? I'd love to see some resources showing otherwise, if you find them. Not to prove any points or right / wrongs just because I think it's pretty interesting. I kind of wish cars would have square setups, I know big rear wheels look cool but as I get older I'm less interested in expensive tires due to their sizes and more happy to actually rotate them and make them last longer. Maybe my front lefts from the on / off ramps wouldn't wear so fast if I could rotate them, LOL. I know a lot has to do with balance, over and understeer, etc. and I know a little understeer is safer, but I wish they'd have square setups and then do the rest with suspension tuning. It's certainly far easier to fit big tires int he rear, there's no engine or steering just eating up trunk space. |
02-02-2024, 11:03 AM | #11 |
Field Marshal
![]() 7462
Rep 2,045
Drives: '08 E92 M3
Oh yeah the underwater part. I forgot about that.
'08 E92 M3 DCT Melbourne Red/Bamboo Beige Leather/EDC/SSP Spec-R DCT clutch/SSP Pro-Gold DCT Fluid/Quaife LSD/3:45 Final Drive/BE Bearings & ARP Bolts/LUX H8 180/DCT Tune by BPM Sport/PFC Z-Rated Pads/ECS Brass Brake Caliper Guides/Alex Shop Solid Sub-frame Bushings/Motul 600/Tint
///M Power-Belgium73700.00 M5Rick72667.00 |
02-02-2024, 12:06 PM | #12 | |
15697
Rep 3,966
Adding to that is the fact that direct comparisons are impossible. Like if you're testing different widths of the same make/model of tire it's going to be impossible to keep the weight the same because it increases as the tire gets larger. Even the construction of the tire can differ, depending on the size. He and I agree that to increase acceleration grip the psi in the tire should be lowered first, then the compound, then the size, and finally the weight-transfer, but that's just our agreement, not set in stone. There is some sort of inarticulate law of diminishing returns too, like if you're running a 255 at perfect grip, a 285 might offer better acceleration than a 245 would, but it's so application dependent that it's not worth noting. But in general, when guys add wider tires and get better acceleration it's usually down to the newer tire or one/multiple of the myriad of parameters has changed. |
02-02-2024, 02:16 PM | #13 | |
![]() ![]() 4596
Rep 8,139
Tire contact area is not as simple as corner weight divided by inflation pressure. They are the primary variables but not the only two variables that affect contact area. Tire construction/stiffness of tread and sidewall do alter the static, and dynamic, contact area. Inflation pressure contact length and width do NOT change linearly with varying pressure. As the pressure is increased, there’s a pressure above which the circumferential length no longer decreases as the pressure continually increased. Similarly, as you reduce tire pressure, the contact width will stop decreasing at a certain pressure. This has been demonstrated by many tests and these data/results are out there. Contact patch area and shape vary with pressure stiffness and structural tread/sidewall stiffness. Data shows very highly non-linear relationships in circumferential contact patch length vs. inflation pressure. For example, a 20” tire will have a higher structural stiffness than a 19” tire of the same width but they’ll have different contact patch length-pressure relationships as well as a different transition pressure where the length stops decreasing with increasing pressure. So for a given pressure it’s possible for a 20” tire to have a longer or shorter contact length than a 19” tire. Tire design is very complex and tires have highly nonlinear relationships between lateral grip and slip angle, grip and normal load, grip and temperature, etc. Nonlinear relationships also exist for contact patch length and width (bilinear) vs. pressure. So two 285 mm tires, on the same or different wheel diameters, from two different tire manufacturers will have different contact areas, shapes, widths and lengths. I’m talking about drag tires used on street cars - people put on 17” wheels (along with smaller calipers and diameter brake rotors!) so the can maximize sidewall height and flexibility to “wind up” the sidewall at launch. Yes, lower pressures than street tire pressures are used as well to maximize grip. In the E generation M3s I ran square tire setups but with the F and G generations I find a staggered setup works better because of the massive torque these cars have. I still run a 285-295 mm front tire but the rear is at least a 305 mm tire. It sucks not being able to rotate but the staggered setup yields better times. |
///MPhatic15697.00 |
02-02-2024, 02:27 PM | #14 | |
![]() ![]() 4216
Rep 4,601
![]() Yeah, we are totally on the same page I think. I agree with everything you wrote. I guess on the internet you never really know at first how much to get into or how much someone already knows. |
02-02-2024, 02:34 PM | #16 |
![]() ![]() 4596
Rep 8,139
I agree with you but my driving style likes the wider rear tire. Thinking of switching to the GTmore F camber plates and MCS 3WR eye-to-eye struts. Then I’d be able to run a 305 mm square setup. However, it feels like selling 1/2 of a complete MCS 2WR setup will be painful finding a buyer and on price.
02-02-2024, 03:01 PM | #17 | |
![]() 7282
Rep 3,670
Current: E92, E46
Prior: F80, F82, F32 |
02-02-2024, 03:28 PM | #18 | |
![]() ![]() ![]() ![]() 3987
Rep 10,664
"Drive more, worry less. "
435i, MPPK, MPE, M-Sport Line |
02-02-2024, 03:46 PM | #19 |
![]() ![]() 4596
Rep 8,139
02-02-2024, 03:50 PM | #20 |
15697
Rep 3,966
It'd help if most every manufacturer didn't set their cars up to be 4x4 height and understeer like pigs. If the suspension came correct from the factory it'd be easy to select tires, but since it doesn't, and most everyone's first priority is to rid themselves of that front gap, any mods become a bad band-aid, including reasonable tire choices. To do it right is to consider the application, then the correct suspension/settings, then everything else, it just doesn't end up getting done that way by most users.
02-02-2024, 04:00 PM | #21 | |
![]() 7282
Rep 3,670
Also, it's hard to compare different engine + drivetrain layouts. A major reason why BMWs like square (or have a smaller 10-20mm stagger) is because of the front engine, rear drive dynamics. Front needs grip due to weight, rear needs grip due to drive wheels. Mid and rear engine cars typically have a much more extreme stagger as they don't need the extra grip up front to support the engine weight.
Current: E92, E46
