01-26-2024, 05:38 PM | #1 |
913
Rep 516
Heads-up display default layout...
In sport mode heads-up display always defaults to some weird "sport mode" graphics, which I don't like. I keep changing it to "reduced" view but the car does not remember the setting. That means next time I toggle between modes, the heads-up goes back to the default sports view.
Does anyone know how to adjust the heads-up default view? To make it clear, I am not talking about adjusting left\right, up\down, tilt position or brightness of the heads-up display in idrive.
Current: 2024 540i MSport
Prior: 2021 540i MSport, 2018 540i MSport, 2015 BMW 528i MSport, 2012 BMW 528i |
01-26-2024, 06:15 PM | #2 | |
240
Rep 67
That is interesting. I don't have this issue. I guess my question is whether you have the same BMW ID associated with your drive? Others can comment but I believe it's your BMW ID that saves all your preferences with regards to displays etc... |
Trevor G1852.00 SkykingUSA4489.00 |
01-26-2024, 07:13 PM | #3 | |
913
Rep 516
I read quite a bit on this topic before I posted here and can't figure it out. Weird. I did have to reboot idrive as driving assistant pro (the 85mph self driving thingy) wasn't kicking in. Now it is. Maybe I'll bounce it again. |
01-26-2024, 07:44 PM | #4 | |
240
Rep 67
01-26-2024, 07:48 PM | #5 |
5064
Rep 1,367
[QUOTE=COBodom;30848987]In sport mode heads-up display always defaults to some weird "sport mode" graphics, which I don't like. I keep changing it to "reduced" view but the car does not remember the setting. That means next time I toggle between modes, the heads-up goes back to the default sports view.
Does anyone know how to adjust the heads-up default view? To make it clear, I am not talking about adjusting left\right, up\down, tilt position or brightness of the heads-up display in idrive. Sport mode does change the heads up display from your default which is stored in personal mode. I only use sport mode when I want to stiffen up the suspension for curvy roads, and I’m not really looking at the HUD for navigation or anything during those drives. When I switch back to personal, my settings are there. |
01-26-2024, 07:50 PM | #6 |
913
Rep 516
01-27-2024, 10:30 AM | #7 |
146
Rep 42
Pretty sure the only HUD displays you can customize is for personal mode. All the other modes have a default display that it resets to when you enter that mode.
SkykingUSA4489.00 Trevor G1852.00 |
01-27-2024, 11:21 AM | #8 |
240
Rep 67
I can confirm that for myself, I have the HUD on minimalist mode and it stays on minimalist mode when I switch driving modes. The only time my HUD switched modes is if I hit the sport paddle to activate 10sec of boost.
01-27-2024, 01:37 PM | #9 |
1566
Rep 836
I believe there is a setting that turns off the HUD layout changing with drive modes.
01-28-2024, 02:02 PM | #10 |
652
Rep 588
Drives: 2021 BMW M550i xDrive Sedan
Go to heads up display settings and change the setting which makes the HUD change depending on driving modes.
2024 BMW 540i xDrive Sedan (G60) (Carbon Black Metallic/Black Veganza)
01-29-2024, 10:54 PM | #11 |
913
Rep 516
Bounced the idrive for an unrelated hiccup - out of nowhere audio became very choppy no matter the source including the assistant voice.
Both issues solved, audio back to normal and heads-up remembers last picked view. |
