      01-09-2024, 01:36 PM   #1
MoreCowbell
MoreCowbell's Avatar
536
1,702
Drives: 24 i5M60 23 X740 23 Vette Z06
CarPlay / Phone Not Connecting 50% of the time
About 50% of the time when I get into the car, my phone, an iPhone 15 Pro max will not connect. Even when I go into 'connect a mobile device' and select my phone it still won't connect. The only fix is to hold down the volume button and reboot the iDrive. As soon as it is rebooted the phone automatically connects.
I have tried removing and adding the phone back. I have tried changing the phones name. I have tried manually connecting to the phones Wi-Fi. Nothing seems to work.
Does anybody else have any ideas?
This is my one and only issue with the car. I love it so far.
Trevor G1852.00
SkykingUSA4489.00
      01-09-2024, 04:34 PM   #2
whofelt
360
438
Drives: M340x Drive
Reset the phones network settings. It’s in the same menu that you would utilize to reset the phone. Don’t reset the phone! Just the network settings
2022 BMW M550 Xdrive (stock).
Appreciate 4
OHV_442002.50
LVBMW3073.50
SkykingUSA4489.00
      01-09-2024, 06:33 PM   #3
trivalent
trivalent's Avatar
210
77
Drives: 2024 BMW i5 eDrive40 M Sport
But know that when you do that, you will lose some things, for example Wi-Fi network passwords.
LVBMW3073.50
SkykingUSA4489.00
deutsch1005455.00
      01-09-2024, 06:42 PM   #4
trivalent
trivalent's Avatar
210
77
Hello. Do you have or can you borrow a pre-15 iPhone for testing CarPlay?
If so, connect it to your car exactly as you are doing with your iPhone 15 Pro Max now, and see if the problem persists.
If it does not, then likely the problem is specific to iPhone 15 generally or to iPhone 15 Pro Max specifically.
SkykingUSA4489.00
      01-09-2024, 06:57 PM   #5
Trevor G
Chief Engineer
Trevor G's Avatar
1852
425
Drives: 2024 I5 M60
2024 i5 M60  [9.50]
Oy you could just go Android
I know.. No help but couldn't resist.
SkykingUSA4489.00
      01-09-2024, 07:06 PM   #6
trivalent
trivalent's Avatar
210
77
Heh. I use both.
SkykingUSA4489.00
Trevor G1852.00
      01-09-2024, 08:21 PM   #7
darylp310
1361
981
Drives: 2025 BMW iX 50
I've had problems connecting to CarPlay maybe 2-3 times over almost a year of ownership. But a soft reboot of iDrive also fixes it.
Any chance that this could be related to your My BMW profile? I think it makes certain assumptions about which phones should be connected by default. If you have multiple Fobs vs. Apple Watch vs. NFC card vs. spouse's phone, etc., each of these could cause a conflict with your primary login. That's another variable you should try to eliminate from the equation.
SkykingUSA4489.00
Trevor G1852.00
LVBMW3073.50
      01-09-2024, 08:21 PM   #8
MoreCowbell
536
1,702
Do you know for sure if this works? I’d hate to lose all network settings just on a hunch.
Very much appreciate your response
SkykingUSA4489.00
      01-09-2024, 10:00 PM   #9
Sequence001
Sequence001's Avatar
512
131
Drives: 2019 X5 & 2024 i5
2019 BMW X5  [10.00]
So this has happened to me a bit, and I work in the Tech Industry so I know my way around a little. What I found is a few things that could cause it to occur / fix the issue.
1. A Bluetooth headset.
I had “Nothin Ear 1” earbuds that wouldn’t disconnect from my phone when i put them back in the case. So me being unaware of this, would get in the car and experience the same issue. I replaced those and haven’t experienced it since.
2. Before that, I found that my BMW was not connected in my wifi settings and my bluetooth settings. I connected those and saw no improvement of the issue but that led me to finding out the Nothing Earbuds were still connected. I only note this because it’s possible it may still help in the event you have no external Bluetooth devices involved.
3. Exit the car, lock it, wait 20 seconds and unlock and re-enter the car and try to use it again. This has worked for me in some situations.
4. (Sort of related) sometimes when I entered the car, the Audio would skip. No matter where the source was coming from: The Youtube app, Apple Music, Soundcloud, or even from BMW Assistant, the audio would skip. Restarting the phone didn’t work.
I fixed this by resetting iDrive. (Hold the volume knob for 20-30 seconds until the screen turns black) the iDrive system restarts and the skipping went away.
Hope this helps.
SkykingUSA4489.00
OHV_442002.50
      01-09-2024, 11:31 PM   #10
whofelt
360
438
Drives: M340x Drive
you won't know until you try it.
play it on the safe side and reboot idrive, if that doesn't work, try my suggestion, what do you have to lose? the shits not working anyways, might as well try it.
Trevor G1852.00
SkykingUSA4489.00
trivalent210.00
      01-10-2024, 12:02 PM   #11
Scrapula
Scrapula's Avatar
5064
1,367
Drives: BMW i5 M60
Mine doesn’t connect 50% for my husband but always works for me. He does wear an Apple Watch. Also we are both in the car together, so 2 phones and one watch. I am always alone when I drive.
SkykingUSA4489.00
deutsch1005455.00
ToddRGuy4445.00
      07-04-2024, 10:19 PM   #12
vallejojo
27
10
Drives: i5 M60
2024 BMW I5 M60  [0.00]
Call Verizon. The Apple watch was causing issues.
SkykingUSA4489.00
Scrapula5064.00
      07-11-2024, 05:57 PM   #13
richpat69
112
30
Drives: 2024 540i X, 2020 M550
I have had this problem a bunch of times. Doing a reset of iDrive seems to fix the problem assuming the appropriate boxes on the device have been checked and unchecked.
SkykingUSA4489.00
deutsch1005455.00
      07-13-2024, 09:28 PM   #14
pfannenstiel
noob
180
45
Drives: i5 M60
can you elaborate on how the Apple watch was causing issues?
2/28 ordered i5 M60 Carbon Black metallic/Burgundy Red Veganza/Aluminum Rhombicle trim/20" Star-spoke Mixed nonRFT/Drive assistance/Premium package/Sky Lounge Roof
3/4 VIN assigned; 3/18 SOP;3/28 EOP&Awaiting carrier assignment;4/2 dispatched from factory;4/3 at the port;4/8 shipped from Zeebrugge;5/3 Port Hueneme;5/7 In transit to dealership;5/9 delivered!
SkykingUSA4489.00
      07-17-2024, 05:35 PM   #15
vallejojo
27
10
Drives: i5 M60
I don't know but the Verizon tech had to disable my watch and then enroll the car. He then enabled my watch and it worked.
SkykingUSA4489.00
      09-19-2024, 08:56 PM   #16
winstonbmw
Drives: BMW i5 xdrive 40
Apple Car Play
I have had this issue for several months. Dealership did a software update twice, now it is in again for a hardware update. They are contacting BMW NA. I noticed my apple car play shuts down when I drive under electrical wires. My wife who is a Biomedical Engineer and builds CTs and MRIs said that it is likely the car is not protected from outside radiation or power lines. It's an error in the build by BMW. That's what I'm working with. But I'm regretting selling my Tesla now. .
SkykingUSA4489.00
Bklyn670.50
      09-19-2024, 09:55 PM   #17
PsychDoc
2584
641
Drives: 2024 540ix
Hope this helps.
Don't you have to hold down the volume roller until the screen reboots 3x?
That has always been my understanding.
SkykingUSA4489.00
aptekcom214.00
      09-19-2024, 11:12 PM   #18
Scrapula
Scrapula's Avatar
5064
1,367
Drives: BMW i5 M60
When I was rebooting with a genius, he told me I could let go of the knob as soon as it turned black.
SkykingUSA4489.00
PsychDoc2584.00
