      12-28-2023, 10:00 AM   #1
Jurama81
114
219
Drives: i5 M60 and X7
i5 M60 knocking sound
I've had my i5 M60 since late October and love the vehicle. Given the quiet nature of an EV I tend to focus on interior noises more than I did on my G80. While the AC is running I've heard a knocking sound that seems to be coming from under the center console, behind the wireless charger tray, from the passenger side.
For now my fix is just to crank up the tunes but I need to get it checked out at the dealership.
Anyone else hearing the same thing.
      12-28-2023, 07:09 PM   #2
Hrod23
12
Drives: BMW I5 M60
I have mine since November and have the same issue. I am doing the same as you for now, bring the volume up and forget about it till I can go to the dealer to figure what the noise is.
      12-29-2023, 01:29 AM   #3
G35c6MT
233
124
Drives: i5 M60
I have not heard this but have experienced a sort of a pulsation or thud while DC charging. It’s almost as if a pump is moving fluids around. Actually reminds me of when a sump pump abruptly shuts off and shakes the pipes. Could be the battery coolant pumps.
I’ll try to keep track of this over different scenarios and outside temps.
SkykingUSA4489.00
      12-30-2023, 01:35 AM   #4
alewifebp
560
284
Drives: 2024 i5 M60
2024 i5 M60  [0.00]
I do feel a slight bump while DC charging. Could no doubt be a variety of things, but seemed like it was a normal sound/feeling. At least it doesn't sound like a PTU in an Airbus.
      01-01-2024, 05:31 PM   #5
NAL
38
57
Drives: '24 BMW i5 eDrive40
Add me to the list with the knocking sound. If you turn off the climate system it goes away. That narrows it down for dealer repair.
The audio volume is my solution until I have to bring in the car for something else.
If anyone out there got it fixed, please let us know what it was.
Thanks.
SkykingUSA4489.00
Jurama81114.00
      01-02-2024, 03:38 PM   #6
Jurama81
114
219
Somewhat glad to learn that its not just my i5. I plan on taking it in for a check-up in the next couple weeks.
      01-02-2024, 11:03 PM   #7
freshxdough
BMW Elite Master Tech | HV Gen 5 | HV Specialist
freshxdough's Avatar
3772
4,353
Drives: 2024 iX 50 | 2020 X3 M40i
Sounds like a coolant valve operating. But without a video i can’t say for sure. Common on i4 where the coolant valve behind the LF headlight would make a knock sound in consistent fashion when at a standstill.
Appreciate 4
      02-29-2024, 12:09 PM   #8
ramiro31
Drives: 2024 i5 M60
I got my i5 M60 last month and am also experiencing same sound. Also my friend with an i5 same problem. Clearly AC related but haven’t been able to go to service dept.
Anyone had this looked at yet?
      02-29-2024, 12:40 PM   #9
Jrjones4
106
82
Drives: 2022 M550i, 2023 X7 M60i
The knocking sound, I believe, is condensate from the AC dripping down a tube. I have the same noise in my I5 M60 produced in October.
BMW implemented a change at the factory in December 2023 to fix the problem, and the bulletin I saw from BMW says a fix is being developed that our dealers will install.
They change a part inside the drain tube to break the water flow so you no longer hear the drip as it drains.
Appreciate 8
scas12570.00
MrDit435.00
SkykingUSA4489.00
deutsch1005455.00
Jurama81114.00
      02-29-2024, 10:26 PM   #10
dubb13
dubb13's Avatar
772
294
Drives: 2024 530i M Sport
Is this a only for the I5 M60 does this affect the 530Xdrive? And it's cold here in Mass so not much AC yet.
      03-04-2024, 12:23 PM   #11
Jurama81
114
219
I took mine in last month and they said we are working on it but didn't show me the bulletin. No timeline was given but they said they would contact me as soon as the fix was finalized.
      03-04-2024, 12:56 PM   #12
RichardInCA
RichardInCA's Avatar
5570
1,364
Drives: 24 BMW i5 M60
I’ve not experienced this problem either but it’s nowhere near warm enough in Northern CA to have meaningful AC use yet. Will be interesting to see if more complaints surface as we move through Spring
SkykingUSA4489.00
Scrapula5064.00
      03-04-2024, 01:45 PM   #13
Scrapula
Scrapula's Avatar
5064
1,367
Drives: BMW i5 M60
I had snow again this morning. I usually don’t need AC until August. We normally get about one week of upper 80’s to 90.
      03-04-2024, 01:47 PM   #14
Theophilus
450
126
Drives: 2024 BMW i5 M60
I noticed a similar issue with my car, but not sure if it's the same. When the car is stopped, I not only hear a knocking, but there is a thump and a bit of movement, somewhat reminiscent of an ICE engine with a rough idle. Of course, it's nowhere near as constant or turbulent, but it's definitely out of place with an electric powertrain.
Is that what you are experiencing, as well? Or is this very different?
      03-04-2024, 02:13 PM   #15
SpaceSilver.X1
world's slowest BMW driver
1565
1,003
Drives: U11, G60, W211, AZ20
knocking sound? don't use regular gas... make sure it's premium unleaded.
oh.. wait a minute.... never mind...
Appreciate 6
DHDCF422.00
Scrapula5064.00
SkykingUSA4489.00
      03-04-2024, 03:02 PM   #16
RichardInCA
5570
1,364
That or it’s the new virtual assistant in the OTA update to iDrive
Appreciate 5
deutsch1005455.00
Scrapula5064.00
SkykingUSA4489.00
      03-13-2024, 09:54 PM   #17
i5M60
35
Drives: i5 M60
Just as an additional data point: I’m experiencing the exact same knocking sound under the center console. It seems to occur more frequently when I come to a stop after braking or turning hard. While it's not a huge annoyance, it's very apparent given the rest of the car is so quiet. I'm interested to hear when dealers will start installing the fix.
SkykingUSA4489.00
      03-14-2024, 08:09 AM   #18
GamoX
25
Drives: 525D
The sound is well documented in Carwow review. Watch a bit to the fifth annoying thing.
      03-14-2024, 10:00 AM   #19
RichardInCA
5570
1,364
Really helpful! I will say, I’ve also hit my knee on that dash trim exactly as he noted, fortunately just once but it’s a good call out.
SkykingUSA4489.00
      03-14-2024, 11:11 AM   #20
deutsch100
deutsch100's Avatar
5455
2,972
Drives: iX, i7, M8, M3, 911
This knocking sound...so sorry some are hearing it, but I have never heard it and I drive a lot!
Scrapula5064.00
SkykingUSA4489.00
Mac545484.00
      03-14-2024, 12:49 PM   #21
Scrapula
Scrapula's Avatar
5064
1,367
Drives: BMW i5 M60
Same here. My car has had no sounds whatsoever.
deutsch1005455.00
SkykingUSA4489.00
Mac545484.00
      03-14-2024, 07:04 PM   #22
deutsch100
deutsch100's Avatar
5455
2,972
...And the A/C is running the VAST majority of the time whilst driving & not a single sound like some are experiencing. Our mornings can be cool (even cold) here, but by afternoon time...A/C AUTO 70F is running 12 months a year!
Scrapula5064.00
SkykingUSA4489.00
Mac545484.00
