12-17-2023, 12:37 AM | #1 |
Rep 12
SRSNVR: Misalignment – Side Radar Sensor Short Range Front Right
Hi Everybody,
I really can use some help here. I have been getting those lane departure warnings, active blind spot detection warnings, side collision warnings and intersection protection malfunction. As speed increases, these warnings start coming up. The malfunction warnings come up at 5 mph, 20 mph and 40 mph, which make sense. We don't really need lane departure at 5 mph. Used a scanner and got: 481CFB - Intermittent SRSNVR: Misalignment – Side Radar Sensor Short Range Front Right I could try getting a used radar sensor black box and see. Am I supposed to perform an alignment or re-calibration? Anyone can share a procedure on this? Much appreciated! |
12-18-2023, 11:27 AM | #2 |
Unapologetic Tool Hoarder
736
Rep 966
It's in behind the front wheel arch. You have to pop the wheel arch trim off and then remove the wheel arch. Doesn't look like it can be adjusted though. You can check the wiring/connector and make sure it's secured though.
