E90Post
The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > NA Engine (non-turbo) / Drivetrain / Exhaust Modifications > How to know if your engine is warmed up!!
Reply
      07-11-2005, 09:26 AM   #1
silverado
silverado's Avatar
288
874
Drives: 2018 M2
Thumbs up How to know if your engine is warmed up!!
I discovered today that the tachometer has a way of telling you if the engine temperature is cold or if it is running at normal temerature! I don't know if this is new or it has been posted before, but I didn't find it when searching and it is not in the user's manual.
The red line in the tachometer in my 330i starts at 7000 rpm. However, there are a number of small lines that go from ~6750 to 7000.
When you first start the car after a long stop, these series of lines are red. After a while, they turn white! I am pretty sure this means that the temperature is now normal!! I'm psyched... now I will know when the engine is warmed up and can safely start stepping on it!
So essentially the car can tell you about three temperature levels: cold, normal and too high. The letter would be conveyed using a warning light. Not like a dedicated temp gauge, but not too bad!
2018 F87 M2 | LBB | Executive | Moon Roof | Apple CarPlay [2018 F22 M240 (sold) ; 2015 F22 M235i (sold); 2006 E90 330i (sold); 1983 E30 Coupe 320i (sold)]
      07-11-2005, 10:15 AM   #2
YYdoodle
117
666
Drives: E92 M3 fanatic
First time I've seen this mentioned anywhere.. if you're indeed right, that's an awesome find! Thanks!
      07-11-2005, 10:27 AM   #3
itznin
itznin's Avatar
27
679
Drives: 2013 F30
This is in fact correct, check the below thread:
http://www.bimmerfest.com/forums/showthread.php?t=95483
      07-11-2005, 10:32 AM   #4
silverado
silverado's Avatar
288
874
Drives: 2018 M2
itznin,
That thread suggested that the tachometer has the M-style temp indications (which I haven't seen), but the E90 doesn't do it that way (and the thread says that a dealer denied that this feature is in the E90). However, this got me looking closely at the tachometer and I noticed the behavior I described in both threads.
      07-11-2005, 10:34 AM   #5
itznin
itznin's Avatar
27
679
Drives: 2013 F30
Yeah it was your post on bimmerfest that shed the light on it I should have realized that LOL, my bad!
      07-11-2005, 10:41 AM   #6
romeo26
44
354
Drives: e30 325 (no lette)
can yo post pics of this?
      07-11-2005, 10:43 AM   #7
john4.4x5
E46 ~ E53 ~ E90 ~ E92 ~ F30.
john4.4x5's Avatar
51
Drives: 2013 335i Sedan EB II/Red
OMG! Great Find!! :rocks:
Current BMW: 2013 335i Sedan 09/12 build
Estoril Blue & Coral Red int., ZMM, 2PF, ZDA, ZDB, ZDH, ZPP, ZTP, 2TB, 5DP, 688, 417, M Performance Brake Kit (Yellow).
Former BMW: 2011 335is Coupe 05/10 build
ZPP, 7-SPD DCT, 19" 225M, Sirius, H/K, DCT, iPod, NAV. TiAg, Black int.
      07-11-2005, 10:47 AM   #8
nexus66
64
239
Drives: F80 M3
I seem to remember hearing something about this only being enabled on 330's, not on any of the other engines.
Anyone confirm or deny this??
      07-11-2005, 10:52 AM   #9
Robin_NL
S0THPAW
Robin_NL's Avatar
8739
7,847
Drives: HS M2 Competition
Nice find indeed. But the lines are rather tiny, unlike my former M3 which has the(already posted) red squares/M-style indications.
So it's not quite noticable. But it's there though.
      07-11-2005, 10:53 AM   #10
silverado
silverado's Avatar
288
874
Drives: 2018 M2
I will try to take pictures later today.
      07-11-2005, 11:58 AM   #11
gtaste
25
Drives: E46 ///M3
The e46 temp indicator is still based on water temp gauge which is a dummy gauge. If this is the case for e90, this is still pretty useless.
      07-11-2005, 12:45 PM   #12
silverado
silverado's Avatar
288
874
Drives: 2018 M2
Ahem, cough, ummm
Well, I may have made a "slight" mistake here. I based what I said on what I saw this morning. I started the car up in my garage and looked at this, it looked quite red to me. It is also sitting in a groove that goes all the way around the tachometer range and the piece with these lines on it look like it can move (in a way similar to how the cruise control speed indicator can move). I then looked at it several minutes later while I was driving and it was white.
I am now thinking I may have been fooled by the VERY amber instrument panel lighting that came on in the garage because my light switch was in the Auto position. I will double check again tonight after I let the car cool completely.
But my enthusiasm is waning. Sorry if I got other people's hopes up
      07-11-2005, 12:50 PM   #13
ldpantoja
Puerto Rico
15
582
Drives: 330i (E90)
I don't know if I am just blind but I don't see the lines
P's Little Ride
2006 330i / SG / SP / NAV
      07-11-2005, 01:11 PM   #14
silverado
silverado's Avatar
288
874
Drives: 2018 M2
You can see the lines I'm talking about in the attached image, above where the arrow is pointing.
      07-11-2005, 01:15 PM   #15
ward
155
6,158
Drives: F
those are white all the time
      07-11-2005, 01:17 PM   #16
silverado
silverado's Avatar
288
874
Drives: 2018 M2
Not at night, when the instrument panel is lit, they aren't
Too bad I don't have the thread delete privilege!
      07-11-2005, 01:36 PM   #17
kronzprinz
kronzprinz's Avatar
286
Drives: 2008 M3
i say just give a couple of mins... unless you're gonna keep the car forever, then give it five mins
      07-11-2005, 03:45 PM   #18
ldpantoja
Puerto Rico
15
582
Drives: 330i (E90)
lol, Thanks for attaching that pic Silverado. I had seen them b4 but as far as I know, they have always been white.
Then again, I was never looking red ones.
P's Little Ride
      07-11-2005, 05:20 PM   #19
john4.4x5
john4.4x5's Avatar
51
You are not crazy this was a mistake by Silverado.
The "lines" are always white.
      07-13-2005, 09:44 PM   #20
benoitch
benoitch's Avatar
19
959
Drives: E90 330i
Question
Hi guys. I don't know if their always white and I did not notice it myself, but when testing the car yesterday, the sales rep told me that some "ticks" move around the tachy to indicate engine temperature. Litteraly, he said the "redline" moves downward when the engine is cold and moves towards the 7000 when heating up. Like I said, I haven't witness it myself. What I am wondering now is if this is true, does the actual engine redline change or is it only the marker without any effect on the rpm limiter. I assume the later is the right answer, but maybe someone can verify this. However, I guess you would need to get the car cold enough which might be hard this time of year.
Regards
Benoit
PS: Maybe will order my E90 tomorrow or really soon (SP,NAV?, Terra, Artic). Still love my E46 xi though
      07-13-2005, 10:25 PM   #21
George Chronis
73
Drives: 330i 2006
Mine are always white (even in the morning), but it's 70 degrees out here in the morning, so it may not be cold enough.
      07-29-2005, 05:45 PM   #22
tartopomme
tartopomme's Avatar
France
10
68
Drives: 335i E92
Do you have an indicator around the speedometer for the max rev when the engine is cold (like the cruise control) ?
Reply
e90post
