11-08-2007, 02:26 AM | #1 |
Remember
39
Rep 115
135i vs. Cayman
I might be a dunce when it comes to image. I'm starting to seriously consider the Cayman, while 12k more than the 135i, as a reasonable comparison. Maybe it's even more ultimate as a driving machine. The power-to-weight ratio of the 135i, though, keeps bringing me back. What strikes you most in comparing the two?
11-08-2007, 04:11 AM | #2 |
Rep 23
I considered a Cayman. Excellent ride. But after adding the very pricey options & factoring in the expensive maintenance costs & higher insurance, the Cayman costs are way, WAY higher than the 135. Plus, the 135 will have power similar to the Cayman S. Way faster than the Cayman.
11-08-2007, 07:55 AM | #3 |
Rep 4
1Power's right about the price difference, but if you can accommodate that, you really owe it to yourself to test drive both. (Especially if you've never driven a mid-engined car before). The two offer completely different driving experiences and one is probably going to appeal to you much more than the other.
Also stock for stock both Caymans offer slightly better pw ratios than the 335 (and the 135 assuming same engine output and 200 lbs lighter). Clearly the 135 engine has some big tuning potential though. Code:
Model Year HP Curb Ratio Accel Top Speed CD MPG MSRP (USD) 335i Coupe 2007 300 3571 11.9 5.3 150 0.3 29/20 40800 135i Coupe 2007 300 3371 11.2 ??? ??? ??? ????? ????? Cayman 2007 245 2867 9.72 N/A N/A N/A N/A N/A Cayman S 2007 295 2976 10.09 N/A N/A N/A N/A N/A http://www.aspecpro.com/ |
11-08-2007, 08:11 AM | #4 |
Rep 4
Incidentally, that last post was meant to be objective. The nonobjective side of me would have just posted this :biggrin:
http://www.autoexpress.co.uk/carrevi..._cayman_s.html |
11-08-2007, 08:29 AM | #5 |
No longer moderate
335
Rep 4,401
The Cayman S is the standard which I'm judging the 135i on - I know the 135i won't touch the chassis dynamics of the Cayman but if it comes fairly close then the value of the 135i will be more than adequate to bridge the gap. You need to drive a Cayman - it is an excellent driver, one of the best around. The CG of the Cayman is lower than the 135i, more weight is inside the centerline of the axles - so it WILL rotate better. It's a great car but you'll spend over $65K to get a comparable amount of kit on the Cayman S as the 135i. The Scot in me tells me the 135i is a better value (and that and when I'm traveling the American west, do I want to park the Porsche in the lot of the Super 8 Motel in Cortez, CO? ; -).
All things being equal - if Subaru made a mid-engined coupe with their 6 cylinder boxer motor - and they got the chassis dynamics right - I'd be in one of those immediately (even if I did have to wear a paper bag due to styling ; -). |
11-08-2007, 09:55 AM | #6 |
Rep 24
Are we really comparing the 135i with a Cayman S? Just because they similar power to weight ratios doesn't mean a thing. They are two completely different cars, I can't imagine the 135i coming close to the Cayman S in driving dynamics. Seriously folks...have you driven a Cayman S?
11-08-2007, 10:19 AM | #7 | |
No longer moderate
335
Rep 4,401
11-08-2007, 11:37 AM | #8 |
Rep 23
I totally agree with the above-mentioned merits of the Cayman - particularly the Cayman S.
If money was not a factor & practicality of a coupe was not an issue, I would definitely choose a Cayman S over the 135. I test-drove an S this summer & was hot for one - figuring what a great performance value it would be after the prevailing discount. However, after adding the options, the higher insurance & the high maintenance costs, it became a budget buster for me. The reason I initially replied to this post is because gimme135 seemed to say a Cayman was close in price to the 135 - only 12k more. IMO, the total cost difference is much larger than that. And that total cost difference does not allow a fair comparison. I'm a great admirer of the Cayman S, but I can't afford one for now. I'm hoping the 135 meets my expectations. |
11-08-2007, 11:46 AM | #9 |
Zoom Zoom
38
Rep 1,069
Personally, I would much rather have the Boxster S rather than the Cayman S. The Cayman looks ungainly with that hatch. And, when you factor in the price of options, I tend to think that a 911 is a better buy.
As for how it compares to the 135i, it all remains to be seen but what you will probably notice throughout all your comparisons is that the 135i has a distinct advantage in power but will probably not provide the feedback and crisp handling you may be looking for. Again, it all remains to be seen.
In the garage: 2022 G80 M3 Manual - Portimao Blue
11-08-2007, 12:42 PM | #10 | ||
Remember
39
Rep 115
I don't know where you got 9.72 Quote:
And don't you all do your own maintenance? I do whatever I can if it doesn't require special tools (and I consider purchasing special tools, too), more because I do a much cleaner, thorough, loving job on my own vehicle than any grease monkey I know of. Always have, always will. Then it comes down to reliability and rattles and squeaks of the two... |
11-08-2007, 02:51 PM | #12 |
Rep 16
I'm not sure what formula you guys are using but those numbers are all wrong. You have to devide power by weight, then take the inverse. The lower the number the better. The Caymen S actually has the most HP per LBS.
Cayman S 10.09 135i 11.23 Cayman 11.76 335i 11.90 |
11-08-2007, 02:58 PM | #13 | |
57
Rep 1,015
+1 ... two totally different animals .. Crowley
The last words on the powerplant should go to a clearly overwhelmed Hormazd Sorabjee, editor and publisher of Autocar India: “There is something simply magical about BMW’s in-line six. It has a creamy smoothness that makes velvet feel like sandpaper.” |
11-08-2007, 05:51 PM | #14 |
Mr. Happy
Rep 479
If you can afford the Cayman and you want a REAL sports car, there is no comparison.
Cayman = light, very real sports car with nearly perfect handling 135i = piggy hopped up economy car in coupe guise with understeer Is there any comparison? |
11-08-2007, 07:04 PM | #15 | ||
Rep 4
http://www.aspecpro.com/browse.php?car=Porsche Quote:
(Power / Weight ) ^ -1 == Weight / Power Your numbers match the chart (aside from the previously mentioned Cayman typo) |
11-09-2007, 12:29 AM | #16 |
Remember
39
Rep 115
I matched their two dyno charts (c/o Automobile and Porsche) by eyeball. :eyebulge: The twin-turbo's torque curve rises earlier and higher. The Porsche (245HP) engine has a slight dip but looks flatter. HP graph doesn't line up as well.
It was red before my convert-to-greyscale (to equalize the two cars). |
11-09-2007, 11:46 AM | #19 |
Moderator
594
Rep 4,240
Fall back Hugo, haha. I mean in acceleration. Plus, I'm sure Dinan will gladly help me out.
- 04 Honda S2000(gone)
11-09-2007, 12:23 PM | #20 |
No longer moderate
335
Rep 4,401
Yeah - I figured you'd take that out. ; -)
But I think at sea level - the Cayman S has some distinct advantages in getting to speed:
11-09-2007, 09:33 PM | #21 |
4-6-8
242
Rep 990
The Cayman S is the way to go. There are a couple F/I kits for it that make it very competitive with the 911, but they are $$$. You gotta pay to play.
M3 E46 PY/Black
S2000 AP2 GPW/Tan |
11-09-2007, 09:51 PM | #22 |
Rep 184
My mother (!) drives a Cayman S. I had no idea how sexy that car was until I stood next to it. It is low, sleek, and simply looks fast.
I don't think the 1 series is especially attractive. Unfortunately, the 135i has all the current styling trends: tall, boxy, bold, and a high hoodline. At least it doesn't have a giant grill and huge headlights. That said, my wife and I are likely to ED a 135i, boring styling and all. Both cars are cool, and both are fast. The BMW will be cheaper to buy and own, while being more practical (rear seats, more interior ******* than the Porsche. Somebody else rightly said apples to oranges. |
