10-17-2007, 04:46 PM | #1 |
11
Rep 291
GTR autoweek first review/preview!!
Sounds good :w00t:
http://autoweek.com/apps/pbcs.dll/ar.../71017001/1065 part 1 Quote: Yes, it lives up to all the hype! The coming Nissan GT-R is a world-class supercar: Top speed of 193 mph, 0-60 in 3.5 seconds, a 473 hp, 433 lb ft twin-turbo V6 mounted in the front and driving all four wheels through a rear-mounted transaxle. Take a breath. Okay, continue. And a dual-clutch six-speed automatic you can operate via paddles on the steering wheel. After a full day driving it on the Nurburgring, the Autobahn and up and over numerous little German country roads we can easily say this is one car that was not over hyped. It is truly a world-class supercar on par with, if not just ahead of, the iconic Porsche Turbo. (They had a Porsche Turbo on hand, too, and we thought the GT-R felt better tied down.) But it's one thing to put a license plate on a race car and call it streetable. Chief engineer Kazutoshi Mizuno said the new GT-R was designed and engineered as an all-around, all-season, all-weather car that is comfortable to drive every day, even at normal speeds on a normal day. During the few minutes we drove at what could be called a "normal pace" that day we'd have to say we agree with him. But given only a few hours at the wheel of this, the most highly anticipated supercar in years, we were only in "normal" mode for very brief spurts. The rest of the time we were at some level between "pushing it" and "hammering on the mutha'." Our first time behind the wheel was on the A48 autobahn in Germany somewhere out around Koblenz or Koln or some other K-town where the German socialist government had not yet succeeded in adding those awful 120-km-hr speed limits. It was like Bonneville with elevation changes and guardrails. The only limitation out here was aerodynamic. Hence, we were obliged to go all-out whompin' fast the whole time. Rolling right out of the autobahn rest stop where we rendezvoused with the Japanese engineering support crew, we nailed the throttle to the floor and man did the throttle respond. The 3.8-liter VR38 V6 is "an evolution" of the award-winning VQ engine family. It sits up front, with two of its six cylinders forward of the front axle and four aft. Two bagel-sized IHI turbos sit right at the exhaust manifold for quick response. The 433 lb ft of torque rails across the tach from 3200 to 5200 rpm. Peak 473 hp comes at 6400 revs. A carbon fiber prop shaft ("Good damping and stiffness") runs back to the transaxle, incorporating the clutch, transmission and transaxle altogether. The shifting is done via a direct, twin-clutch system. One clutch handles the odd gears and another clutch handles the even ones. Shifts take 0.2 seconds. There are BorgWarner triple-cone synchronizers for all gears. Another shaft runs forward from that transaxle to send power to the front wheels. Below 25 mph the torque split is 50/50, above that, under normal driving, the split is 40/60. But it can split up to 2/98 under hard acceleration, which was what we were giving it. Our car rode on 20-inch wheels wrapped by Bridgestone Potenza RE070s, 255/40 in front and 285/35 rears. Front suspension was upper and lower A-arms and the rear was a five-link. It's always fun to go from zero to warp factor in a right hand-drive car using a jet-lagged left hand-drive brain, trying not to turn on the windshield wipers when you think you're hitting the turn signal. The GT-R lists quarter-mile time at 11.7 seconds and entering the Autobahn we had no reason to doubt that. The turbo boost was, as promised, very progressive, with little or no discernable lag, just smooth, even power delivery. Despite the late-morning hour and the mid-week day, there were still a few cars in the way. When we eased onto the 15.2-inch ventilated cross-drilled Brembo brakes from well into triple-digit speeds the car slowed without drama. But then traffic would clear out and the GT-R resumed its high velocity chase with ease. There are three settings for the Bilstein Damptronic shocks: R, Sports and Comfort. We went out in Sports. Top speed is listed at 193 mph but with traffic the best we could do was 176. You wouldn't try that in any country but Germany, where you can usually assume everyone else is paying attention. There was a Japanese engineer riding shotgun over on the left whom we dubbed "Bushido engineer-o" or brave engineer. He thought that was pretty funny. While the coefficient of drag is an impressive 0.27, more than almost any production car, the GT-R also produces downforce at each axle, something very few production cars can claim. "Cd is more important than downforce on a G35," said chief designer Hiroshi Hasegawa. "But in the case of the GT-R we have to make downforce." At 193 mph you might appreciate that philosophy. The first time we went out, the right front wheel felt just a little out of balance, so we came back in and they changed all four wheels. They're efficient, these guys. After that the car was smooth as well as stable and safe, due in equal parts to the German roadway and the Japanese engineering. The whole car sits on the new PM platform, PM meaning Prime Midship. It's an evolution of the ubiquitous FM platform that sits underneath everything from 350Zs to crossover SUVs. The PM incorporates what Mizuno-san called a "hybrid superstructure body." There is carbon-injected material in the front end and carbon composite material underneath for aerodynamic downforce. There's even some polypropylene in the body, too. In any case, it's not just another FM variant. We truly enjoyed the Autobahn experience. This is the perfect car for such a top-speed run-it gives such a sense of control at those speeds that you feel like you could do anything. Next on our agenda of "anything" were some miles of country road. We were able to drive the GT-R back-to-back with a Porsche Turbo. "Okay now, please enjoy," said the Nissan technician as we exited the company compound down the street from the Nurburgring. After "much spirited driving," we can say the Turbo had a good deal more lag and more dive and squat than the GT-R. But once the Porsche got spooled up, achtung, baby. It felt lighter and the steering felt quicker, too. The biggest difference between the two was that the Turbo demanded more of its driver while the GT-R was easier to handle, flatter and more stable. We'd be happy with either one, if you're considering a birthday present or anything. Next up on this Disneyland of a day was Der Nurburgring. This is what all those teenagers whose parents have not taken away their Playstation access really want to do: drive an actual GT-R around the actual Nurburgring as fast as grip, guts and gasoline allow. Man-oh-flippin'-man. The real deal is about 100 times more thrilling than any computer simulation, even those with the little plastic steering wheel and feet pedals attached. |
10-17-2007, 04:51 PM | #2 |
11
Rep 291
Part 2 Quote:
This was the new Nurburgring, too. Nissan wasn't foolish enough to turn this small squadron of car writer hacks loose on the narrow, blind, crazy-dangerous Nordschliefe. At the time of our drive there were only three prototype GT-Rs extant in the world, and all the apologizing on Earth wouldn't bring one back if you crunched it. The new Nurburgring is faster, with wide, sweeping turns bordered by runoff areas so huge that even the most no-talent buffoon could likely stay on the pavement. So we did. All the Japanese engineers and executives had been telling everyone that there was a 35-mph speed limit in the pits, but in all the excitement we kind of forgot about it and nailed the throttle right out of the parking spot right there in pit lane. The wide, low, squealing run-flat tires laid down long patches of black rubber as we launched past the closed garages, pulling back on the right paddle to shift the rear-mounted dual-clutch six-speed transaxle every time the engine got close to its 7000-rpm redline. In no time at all we were roaring onto pit-out near the end of the straight and directly into the low, evening sun. By the time we got fully out on the front straight and were shifting up from four to five or so, the sun was directly in front of the GT-R and streaming into the windshield; we were trying to remember if that first right-hander came at this rise or just past it. It was just past it, but we'd already started braking and downshifting, the GR6's "synchro-rev control," which perfectly matched each downshift with a throttle blip much better than we'd ever have been able to match it. Tiptoeing through the first couple turns to avoid the infamy of the run-off gravel, the car felt perfectly safe and willing. So we hammered it up through the gears down the hill and to the far 180-degree turn and started to feel more confident. By the end of the first lap we were flat out on the front straight, roaring up through all six gears for all it was worth. Nissan lists lateral g's at 0.99, and we certainly bumped up against that in many a Nurburgring corner. We only got three full laps and no one was timing us, so you'll just have to assume we set the lap record. Earlier, Mizuno-san had offered some lap times from the Nordschliefe for various cars driven by the German magazine SportAuto. Those times are driver-dependent, track-knowledge-dependent, weather-, traffic- and bunny-crossing-the-track dependent. But Mizuno suggested the GT-R could get anywhere from 7:44 on up, with most laps coming in between 7:55 and 7:58. So he suggested the GT-R's strong suit was that it offered "the best cost per lap time." For whatever that's worth. The GT-R will be worth somewhere in the low-$70,000 range, which does make it perhaps the best cost per lap. We'll know for sure when it enters U.S. showrooms in May or June. Japan will get first crack at it, we get second and the Europeans, who did such a great job of getting out of our way during our Autobahn drive, will have to get it third. SPECS: 2009 Nissan GT-R On Sale: May/June Base Price: Low 70s Drivetrain: 3.8-liter, 473-hp, 433-lb-ft twin turbocharged V6; awd, six-speed automatic Curb Weight: 3792 pounds 0-60: 3.5 seconds Fuel Economy (EPA Combined): 21 mpg (mfg. target) |
10-17-2007, 05:09 PM | #3 |
Moderator
594
Rep 4,240
Damn, turbos and AWD does wonders. Since when does 470hp propel 3800 pounds to 60in 3.5???
505 propels a 3100lb Z06 to 60 in 3.5sec. What the hell?
- 04 Honda S2000(gone)
10-17-2007, 05:13 PM | #4 |
11
Rep 291
AWD traction man. AWD makes a big difference in the 0-60 mph mark. Still the supposed 1/4 mile time is still making that hp/weight ratio seem wrong lol.
10-18-2007, 10:42 AM | #5 | |
14
Rep 810
http://www.egmcartech.com/2007/10/17...s-slr-mclaren/
10-18-2007, 11:11 AM | #6 |
Zoom Zoom
38
Rep 1,069
What a ridiculous car. I'm disliking this car more and more every time I see it. Also, the weight of the thing is ridiculous. If I am going to spend 70-80 grand on a sports car, I am not going to have to it weigh 3,836 pounds.
In the garage: 2022 G80 M3 Manual - Portimao Blue
10-18-2007, 11:20 AM | #7 | |
Rep 91
Couldn't agree more. Z06 all the way for that money.
135i 6/M
Jet Black/Coral Red Premium Package Sport Seats Aluminum Trim Maybe... we'll see how it compares to the M |
10-18-2007, 11:35 AM | #8 | |
14
Rep 810
I know it's not everyone's cup of tea, and I have been very skeptical of this car as well, but if Nissan really made a car that does Nurburgring in 7:35, and can be driven everyday with usable back seats for $80K, I think it deserves plenty of respect. As for the Z06, I'm pretty sure the GT-R will outpace it in most tracks, despite the weight disadvantage. And the Z06 is a two seater. |
10-18-2007, 11:36 AM | #9 |
Moderator
594
Rep 4,240
I would have said that a few weeks ago but damn. This thing has 2 back seats too. It will destroy a Z06 in a straight line and on a track. ANY TRACK. Excuse my language but this car is FUCKING GODZILLA! Like Edmunds so wonderfully said: This car is not entering the sports-car performance market, it is detonating it. I'm thinking I need to have one of these at some point. I'm not too keen on the styling so mine would have to be all black. Nissan really created a serious piece of work. I mean the tires come from the factory with nitrogen in them!
10-18-2007, 12:07 PM | #10 | |
Rep 91
135i 6/M
10-18-2007, 02:32 PM | #11 |
Moderator
594
Rep 4,240
Nissan says 0-62mph in 3.5 seconds. The fastest I've seen was 3.6seconds. And take not that was 60 and not 62.:biggrin:
10-18-2007, 03:24 PM | #12 | |
Large Member
167
Rep 937
And Chevy still has the Blue Devil in the pipeline. |
10-18-2007, 03:39 PM | #13 | |
Moderator
594
Rep 4,240
10-18-2007, 05:16 PM | #14 |
Rep 91
Destroyed was a vast overstatement. But I share your enthusiasm. AWD is impressive, simply put that is what makes all the difference for this car...I'd rather have the Viper or Vette though... AWD is not my preference in a sports car. And yeah... in a 911 I'd rather have a GT3 to avoid AWD too.
135i 6/M
10-19-2007, 02:14 AM | #15 |
Junior Baller
Rep 23
*drool* Now, what happens when a higher flowing exhaust is put in and the boost gets turned up....still on the stock turbos??? holy shiet! I'm excited as hell for this thing to FINALLY hit american shores!
Current ride-1998 Audi A4 1.8T Quattro (gt3076r turbo, pauter rods, wiseco pistons) loud as hell and the best 400hp sleeper evAR!!
Jr. Ride - 2007 HD Sportster (Roadster) 1200 (V&H Slips ons, stg1 re-map) 45/60 mpg!! Sweeeett!!! Hopefully soon-135i, White (is there any other color for a Bimmer??) lol |
10-19-2007, 12:54 PM | #17 |
Rep 91
Agreed. It looks like a current model eclipse. At least the front air damn.
135i 6/M
10-19-2007, 02:59 PM | #18 |
Zoom Zoom
38
Rep 1,069
The GT-R is supposed to be a bare-bones, high-tech sports car. It does not have anywhere near the intent of luxury as the M5 or M6. Two very, very different cars. For the same money (and those that lust after ridiculously pointless numbers are going to hate this...) I would much rather have a Porsche 911 (much preferred in GT3 trim if the bank will allow). Or save a little and get an E92 M3. Just a man's opinion...
10-20-2007, 03:18 AM | #21 |
Rep 60
Anyone ever seen a Z06 in the real world? not magazine racing. It may be under 4 seconds 0-60 with a flawless launch but not many drivers are capable of that. I have seen them running just under or at 5 seconds 0-60 at tracks. The GT-R is AWD and the twin clutch system will shift faster than any human ever could. Very easy to get the most out of it, I want one bad! :w00t:
