F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > F30 GTS Hood Lift Supports?
GetBMWParts
      04-12-2023, 11:15 AM   #1
tikalize
37
Drives: BMW E60
What brand/model lift support hood struts are you guys using with the GTS aluminum hood on a F30? I heard the stock ones are too strong. I don't have the original struts to test. I need to purchase a set soon for my new hood. I have a 13 335i Sport.
      04-13-2023, 03:00 AM   #2
tikalize
37
Drives: BMW E60
Wow.. Nobody has a GTS Aluminum Hood on forum??? I have looked all over trying to get a simple answer but to no avail. I guess I have to start buying gas struts, try them and return what doesn't work. Thanks guys.
      04-13-2023, 06:38 AM   #3
WillLowe
310
REP
598
Drives: F32 435d
I've got one and the standard struts are fine. As far as I know 3 or 4 other people have the same and I don't think they've changed the struts
Billfitz9043.00
      04-13-2023, 06:54 AM   #4
Billfitz
Billfitz's Avatar
9,043
REP
17,297
Drives: '15 328iX GT
You'd only need different struts if the hood was heavier.
Wires2014.50
      04-14-2023, 01:17 PM   #5
1QuikWS6
No 55mph
1QuikWS6's Avatar
1,646
REP
8,498
Drives: F32 435ix MSport
I have one on my 435 - kept the stock struts = no problems
F32 435ix//MGM//M Sport-Prem-Tech-Driver Assist-Lighting-Cold Weather-Dyn Handling Pkgs//M4 Black Lthr Int w/M4 Alum Blade Trim//HK w/Bavsound Stg3//763M//M4 Euro LCI Tails//M4 Mirrors w/CF Covers//AWCarbon CF F/R Spoilers-Side Splitters-Diffuser 6WB/ID6 HU+HUD/IND M4 Alcantara Armrest//PURE S2 Turbo//AA FMIC+DP//ER CP+TIC//3.5bar TMAP/TS DV//AWE Tuning Exh w/Blk Tips//Turner MS CF Intake//BM3 Cary Jordan Tune//MPerf Diff//PrecRW Ignition Kit
Billfitz9043.00
      04-25-2023, 10:13 AM   #6
fortythirtyfive
United Kingdom
765
REP
1,472
Drives: 435i
The OEM ones are a bit too strong for carbon/fiberglass and for aluminium they're just "okay".
For my old carbon hood I had to drop a strut on one side. With my aluminium one now I have both attached. I have to be careful though as it does require quite a bit of force which flexes the hood.
2015 435i - 401whp
Scorpion catless dp, VRSF 6.5" HD FMIC, MST V2 inlet, NGK 97506, B58tu HPFP, MHD Stage 2 HPFP 102, xHP Stage 3, M Performance Exhaust (modified for valved straight thru)
      04-26-2023, 01:42 AM   #7
MTTH
MTTH's Avatar
237
REP
738
Drives: '11 328xi |'18 440xi GranCoupe
  [0.00]
I have a GTS hood and I think the stock struts are way too strong and causes bending. I believe the M4 GTS/M3 CS struts fit if I remember correctly. I’ll likely upgrade to those.
f30post
