      04-07-2023, 07:52 AM   #1
Raimo5
433
785
Drives: BMW 740d xDrive (G11)
Putting car in "detailing" mode
Hi,
As the days get longer and weather gets warmer in northern hemisphere, it is time to start detailing again.
I wonder if throughout the years, someone has finally discovered how to put car's interior in to "detailing mode", so to speak. Every time I go over a capacitive touch button or an iDrive controller with a microfiber, the car wakes up, reacts to my (inadvertent) inputs and messes up all the settings. Short of disconnecting all the batteries, is there a way to disable car listening for those inputs? I haven't tried it, but I think even sending the power down command wont work as it will still listen for button inputs.
      04-07-2023, 08:49 AM   #2
tracer bullet
tracer bullet's Avatar
4220
4,608
I've found if I leave the key on a bench in the garage, and not have it in my pocket, it's basically achieving what you are asking about. But if I've got it in my pocket, interesting things do happen, i.e. the locks will lock / unlock just with the water being sprayed on the car.
Might be different from one car to the next.
      04-07-2023, 09:09 AM   #3
Raimo5
433
785
Yes, that does work for exterior comfort access sensors. Water has capacitance greater than air so if the key is in required proximity, doors will react. You can leave the key inside the car as well which will yield same result.
For interior buttons, this approach wont work. Car will wake up regardless whether the key is visible or not.
M4Tejas1098.00
      04-07-2023, 10:24 AM   #4
diirk
diirk's Avatar
1061
261
Drives: 2023 X3MC BGM
Maybe try opening the doors and double press the lock button. That should set the alarm and disable interior motion sensors. Not sure if it'll accomplish what you're asking, but worth a try.
23 X3MC BGM. MSS. H&R 12mm spacers
20 4Runner
18 Cayman GTS
15 Beetle Vert
      04-07-2023, 07:38 PM   #5
Raimo5
433
785
Thanks, I'll give it a try.
      04-07-2023, 10:47 PM   #6
MMnut
562
416
Drives: M4
Wont work. You can try leave the key in house, then sit inside with windows opened, then lock the car with your phone and start to clean up interior.
diirk1061.00
      04-10-2023, 11:16 AM   #7
shawndean22
53
57
Drives: 2022 BMW M3 (on order)
I was annoyed by this too, I just place keys in cupholder and good to go.
      04-10-2023, 02:01 PM   #8
Raimo5
433
785
That sounds like it might actually do the trick! I'll try it, thanks.
      05-27-2023, 06:45 PM   #9
Raimo5
433
785
Update: Locking yourself in to car by phone with keys outside of range doesn't do it either.
