2Addicts
2Addicts
2Addicts | BMW 2-Series forum Classifieds Members Classifieds Tools / Garage Supplies CGDI CG Pro 9S12 Programmer Mileage Correction Diagnostic OBD tool for BMW / Mercedes
      03-25-2023, 07:44 PM   #1
HootisTigglebits
HootisTigglebits's Avatar
25
199
Drives: BMW M240i & BMW 330e
Exclamation CGDI CG Pro 9S12 Programmer Mileage Correction Diagnostic OBD tool for BMW / Mercedes
BIMMERPOST / Classifieds
Asking Price:
USD 400.00
Or Best Offer
Item Interest
This is the device used to virginize all F-series (as well as MANY other) instrument clusters.
This programmer has been very lightly used. In fact only 2 of the adapter boards were used, the rest and all the adapters are brand new still. I am also including an additional pig tail for BMW F-series instrument clusters that allows you to view the mileage (once hooked to 12v). This can virginize and do mileage correction on most instrument clusters, key fob programming, airbag module renew, and MUCH MORE. This stays sold out all the time for a reason, because it's so versatile. Check out my other auctions for similar items. This includes all adapters.
CG Pro 9S12 new product, the next generation of CG-100, can perform automatic conversion for BMW, for Mercedes-Benz kilometer and for BMW, for Land Rover, for Porsche key matching.
CG Pro 9S12 Features:
Support for Freescale 705 series
Support for Freescale 908 series
Support for Freescale 711 series
Support for Freescale 912 series
Support for Freescale 9S12 series
Support NEC V850 series
Supports engine computer change and ISN read
Support automatic conversion for BMW, for Mercedes-Benz kilometers
Support for BMW, for Land Rover, for Porsche key programming
CG Pro 9S12 Flash point:
Support a variety of strong encryption chip crack, stable fast
Software equipment using high-end technology, real-time monitoring, anti-loss
This programmer is complementary to the CG-100
With independent intellectual property rights, arbitrarily increase the chip model according to customer demand.
CG Pro 9S12 Highlights:
Read and write any for BMW CAS 1-4, for Porsche BCM, for Mercedes-Benz EIS, for Audi BCM2 Etc anti-
theft computer (100% stable security, subject to domestic test users alike)
CG Pro 9S12Support ECU IMMO List:
for BMW:
CAS4+ 5M48H/1N35H (9S12XEP100)
CAS4 1L15Y (9S12XDP512)
CAS3 0L15Y/0M23S (9S12XDP512 including CAS3+ series)
CAS3 0L01Y (9S12DG256)
CAS2 0L01Y/2K79X (9S12DG256)
CAS2/E66 0L01Y/2K79X (9S12DG256)
CAS1 0K50E (912DT128A Write FLASH data online)
EWS4 0L86D/1L86D/2L86D (9S12DJ64)
EWS3 0D46J/2D47J (MC68HC711EA9)
EWS2 1D47J (MC68HC711EA9)
(Support read/write data above for mileage correction and immobilizer reset )
for BENZ:
EIS 211 ST12 3L40K/1L59W/4L40K/1L85D/0L85D/2L85D/
EIS 211 HC12 0K50E/3K91D
EIS 209 ST12 3L40K/1L59W/4L40K/1L85D/0L85D/2L85D/
EIS 209 HC12 0K50E/3K91D
EIS 215 ST12 3L40K/1L59W/4L40K/1L85D/0L85D/2L85D/
EIS 215 HC08 2J74Y/4J74Y/1J35D(Can directly reset EIS data with 08 adapter;and read write EEPROM without extra adapter)
EIS 220 HC05 0D53J/0D59J/0D62J/0D69J/0F62J/0F82B/0G47G/0H51A/1D59J/1D69J/1H52A/2D20J/2D59J
EIS 210 HC05 0D53J/0D59J/0D62J/0D69J/0F62J/0F82B/0G47G/0H51A/1D59J/1D69J/1H52A/2D20J/2D59J
EIS 203 HC08 1J35D/2J74Y/4J74Y
EIS 164 ST12 3L40K/4L40K/1L59W/0L85D/1L85D/2L85D
EIS 169 ST12 3L40K/4L40K/1L59W/0L85D/1L85D/2L85D
EIS 639 ST12 0L01Y
EIS 639 HC08 0L02M/1L02M/4J74Y/1J35D/2J74Y
EIS 199 ST12 3L40K/4L40K/1L59W/0L85D/1L85D/2L85D
EIS 230 ST12 3L40K/4L40K/1L59W/0L85D/1L85D/2L85D
(Support all above data read/write for mileage correction and immobilizer reset)
for Roewe:
for Roewe 750 IMMO 0M89C (Read/Write)
for Land Rover:
EWS ST12 3L40K/4L40K/5L40K
RFA 9S12XEQ384 (1M12S 2M12S 1M53J 2M53J ) 9S12XET512 ( 3M53J 2M53J 1M53J)
Support Dash Type:
for Benz
for BMW
for Domestic cars 9S12 dash
for Land Rover
for Mini
for Audi:
for Audi A4/A5/Q5-BCM NEC D70F3634/D70F3380
for Audi ELV HC08GR 4L35K
Key Programming:
for BMW CAS3 YES
for BMW CAS3+ YES
for BMW CAS4 YES
for BMW CAS4+ YES
for BMW EWS4
for BMW EWS3
for BMW EWS2
for Porsche 911 BCM YES
for Porsche Boxster BCM YES
for Porsche Cayman BCM YES
for Porsche Panamera BCM YES
for Porsche Cayenne BCM YES
for Porsche Macan BCM YES
(Program key via eeprom data)
Support Chip List:
for Microcontroller:
for Motorola:
9S12 series:
9S12XDP512-0L15Y
9S12XDP512-1L15Y
9S12XDP512-0M23S
9S12XEP100-1N35H
9S12XEP100-5M48H
9S12XEx512-2M25J
9S12XEx512-3M25J
9S12D64-2L86D
9S12DJ64-0M89C
9S12DT128-1L59W
9S12DT128-4L40K
9S12DT128-1L85D
9S12DG128-3L40K
9S12DG256-0L01Y(CAS)
9S12DG256-2K79X
9S12XHZ384-1M80F
HC912 serie:
HC912DG128-0K50E
HC912DG128A-0L05H
HC912DG128A-3K91D
HC908 series:
HC908AZ60-4J74Y
HC908AZ60-1J35D
HC908GR16-4L35K
HC711 series:
HC711EA9-2D47J
HC705 series:
HC705-0D69J
HC705-0D53J
NEC:
D70F3634
D70F3380
CPU:
ST:
35080DQ
35160DQ
35080_3/6
35080VP/V6
8-foot chip:
24C01
24C02
24C04
24C08
24C16
24C32
24C64
24C128
24C256
24C01A
24C01B
24C02B
24LC01A
24LC01
24LC02
24LC04
24LC16
24LC32
25010
25020
25040
25080
25160
25320
25640
25128
25256
93C46
93C56
93C66
93C57
93C76
93C86
93A86
93CS56
93CS66
93S56
93LC46
93LC56
93LC66
93LC76
93LC86
95010
95020
95040
95080
95160
95320
95640
95128
95256
AMD:
AM29BL802CB
AM29F200
AM29F400
AM29F800
2017 M240i - Estoril Blue
      01-17-2024, 08:53 AM   #2
Franktea1$
Franktea1$'s Avatar
34
104
Drives: BMW e39 540 sport & BMW X5M
I have an F85 cluster has some issues, I am buying a used cluster from another F85. What do i need to match my vin and miles? Any issues if i just install it as is? Thanks Frank
2addicts
