03-07-2023, 12:54 AM | #1 |
8326
Rep 10,740
Your favorite detailing products
Polishes. Soaps. Towels. Mitts. Brushes. Ceramics. Tire dressing. Wheel cleaners. Etc etc.
Name some of your favorites! |
03-07-2023, 02:55 PM | #2 |
![]() ![]() ![]() 841
Rep 489
Tire Shine: CarPro PERL
Drying Aid: P&S Beadmaker Wheel/Tire Cleaner: P&S Brake Buster Interior Cleaner: Nextzett Cockpit Premium Leather Cleaner: Sonax Leather Foam Glass Cleaner: Sonax Glass Cleaner |
03-07-2023, 03:05 PM | #3 |
![]() ![]() 3155
Rep 5,582
P21S Bodywork Shampoo
https://www.p21s.com/portfolio/p21s-...oning-shampoo/ Lucas Slick Mist Spray Wax https://lucasoil.com/products/appear...mist-speed-wax Sprayway Glass Cleaner https://spraywayautomotive.com/produ...leaner-sw-050/ Zymol Seal https://zymol.com/products/seal™-window-door-seals Waxes. Polish, Sealant, Clay - these products I'm always changing up because the claims are never quite as advertised or the results are all pretty much similar. |
Game8325.50 |
03-07-2023, 04:54 PM | #4 |
![]() ![]() ![]() ![]() 17777
Rep 11,713
Drives: 2018 M4 Comp Indv
For name brand stuff, it's generally all fairly good, but my picks are:
Tires:Car Pro Perl / Darkside Wheels: either Brake Buster or SP Road Warrior Road Film Remover: SP Road Warrior or SP Pink Perfection Bugs: SP Pink Perfection Microfiber: The Rag Co Wash Media: Chenille mitts Brushes: EZ detail wheel brushes Rinseless Wash: McKee's N914 Foam: SP Cherry Foam Sealant: Turtle Wax Seal-n-Shine Finisher: Turtle Wax Ice Spray Wax Ceramic for Wheels / Exhaust Tips: Car Pro DLux Baller Sealant & Hydrophobics: NV Nova Lustre & Jet |
03-07-2023, 05:07 PM | #5 | ||
8326
Rep 10,740
03-07-2023, 07:46 PM | #6 | |
Rep 11,713
Generally, decon products are only needed for cars that aren't regularly maintained. It takes more/less 3ish weeks for enough expand/contract heat "breathing" cycles to work the particles into your clear coat; so if you're washing more frequently than that you'll get little to no contamination. For example my vehicle is 16 months old & been on 4 West Coast top to bottom road trips and has no embedded particles that I can feel yet. That's said, when I go to polish it, I'll definitely do a iron & clay decon |
Game8325.50 |
03-08-2023, 09:52 AM | #7 |
![]() ![]() 7642
Rep 5,394
I want to mention the CARPRO DHydrate Drying Towel which my PPF shop uses and turned me on to. It comes in various sizes, absorbs a great deal of water and does an amazing job drying the car. I recommend getting the large size as it speeds up the process. It isn't cheap but definitely worth the price!
LivingInSalt2010.00 |
03-08-2023, 10:27 AM | #8 | ||
8326
Rep 10,740
GrussGott17776.50 |
03-08-2023, 01:05 PM | #9 |
![]() 96
Rep 165
Couple that haven’t been mentioned:
As a sacrificial topper to ceramic coatings: Carpro HydrO2 (not the premixed spray bottle one, use other one that you mix yourself, the SiO2 content is significantly higher) Griots 3-in-1 ceramic spray - super easy to use, easiest I have found actually Tires Blackfire Tire Gel (I also use Carpro Perl sometimes but it’s been mentioned already) Car Soap Carpro Reset DIY Ceramic Coatings Kamikaze Miyabi with Kamizake ISM over it (and then either the Griots or HydrO2 as the top coat as mentioned above) Extending Car Mitt Autofiber Leather Coating Gyeon Leather Shield - used for first time when we picked up our X3 in early Jan, super easy and forgiving to use. Miscellaneous Adams Brilliant Glaze for interior windows (also great on a glass shower enclosure) The Rag Company Liquid8r drying towel, best I had tried and I have tried almost all of them lol |
Clark_Kent2325.50 GrussGott17776.50 |
03-08-2023, 02:12 PM | #10 | |
8326
Rep 10,740
03-08-2023, 03:06 PM | #11 |
![]() 96
Rep 165
Yes, the Luiquid8r left my panels dryer after one pass than the Gauntlet. I guess the Achilles heel of the twisted loop towels like the Liquid8r is that they are hard to wring out. I usually take mine and put it right into the washer with microfibers and mitts after done vs trying to wring and air dry, I tried that once and it stayed wet a long time before I gave up and into the wash/dry cycle it went. |
GrussGott17776.50 |
03-08-2023, 03:50 PM | #12 |
![]() 2326
Rep 1,921
Car Shampoo: GTECHNIQ G Wash
Consumer Grade Ceramic Coating: GTECHNIQ Crystal Serum Light + EXOv4 + C2V3 = killer combination Tire Dressing: I've used just about every tire dressing under the sun and the best one I've used is GYEON Tire Q². It's a SiO2-based solution that works incredibly well. For best results, I heat up the tire wall before and after application. Wheel Cleaner: TUGA Devil Special Wheel Cleaner. This stuff is expensive but works like magic. It requires very little to no manual intervention, especially on a coated wheel. Leather: GYEON Q²M Leather Cleaner Strong + GYEON Q² Leathershield
Retired: 2018 BMW M3 CS, 2018 BMW M3 ZCP, 2016 BMW M3
GrussGott17776.50 |
03-08-2023, 06:41 PM | #13 | |
Rep 604
I'm in the UK so some of these products may not be available in the US... Pre Wash...Autobrite Direct Citrus pre-wash/APC...Gyeon APC. Snow Foam...Autobrite Direct Magifoam...Autobrite Direct Custard Magifoam...Gyeon Foam...Garage Therapy Snow Foam V2...Bilt Hamber Auto Foam. Shampoo...Car Chem 1900:1...Gyeon Bathe+...Gyeon Bathe Essence... Garage Therapy Car Shampoo V2...Bilt Hamber Auto Wash...Autobrite Direct Ceramic Infused Shampoo...Autobrite Direct Purple Velvet Shampoo. Wheel Cleaners...Garage Therapy Wheel shampoo...Autobrite Direct Wheel And Tyre Cleaner. Spray On Rinse off sealants...Autobrite Direct Magiseal...Autobrite Direct Top Gloss...ValetPRO Snow Seal...Gyeon Wet Coat...Bilt Hamber Touch-On...Koch Chemie Protector Wax. Mitts...Garage Therapy Wheel mitt...Gtechniq Mitt, Microfibre Madness Mitt...Soft99 Mitt to name but 3. Brushes...Wheel Woolies...Ultra Soft Detailing Brushes from Aliexpress...various sizes of Hogs Hair Brushes. Ceramics....Gyeon. Drying Towels...Autobrite Direct Ultimate Twisted Loop Drying Towel...Gyeon Silk Dryer. Car Blowers...BigBoi BlowR Mini+...BigBoi Buddi. Tyre Dressings...Gyeon Q² Tire Si02...Garage Therapy Tyre Serum. |
GrussGott17776.50 |
03-08-2023, 06:54 PM | #14 |
Rep 11,713
I gotta jump in on this as I have a ton of experience with these:
Totally agree with Ljn21 that the liquidator is best for pure drying and it what I use for a high volume fast dry. That said, the Gauntlets are great when using a drying aid as I use 2: one for the first pass, a different one for the 2nd buffing pass. In that scenario, the gauntlet's bite is much better. I love the gauntlets for this "Rinseless" wash & dry use and it's what I use 80% of the time but that's just my process. |
03-10-2023, 02:48 AM | #15 | |
8326
Rep 10,740
I plan on using a Blo Car Dryer S to dry out the nooks and crannies and handle the rest with either the gauntlet or liquid8r. So if I’m understanding correct the point of a drying aid is to provide lubrication during drying as well as aid some gloss (even protection). |
03-10-2023, 08:54 AM | #17 |
![]() ![]() ![]() 2090
Rep 515
Soap/Shampoo: Megs Hyper Wash (works great in the bucket or foam cannon) or Duragloss 902
Mitt: lambswool Liquid Wax/Sealant: Collinite 845 or Wolfgang Deep Gloss Paint Sealant Paste Wax: Wolfgang Fuzion Drying towels: Griots PFM Wax / polish towels: Rag Company Eagles (various), Chemical Guys gold Window towels: blue huck cloth, CarPro glass cloth Topper / recharge: Duragloss rinseless wash (#931) mixed 10:1 with water. Everyday detail: Meguiars, Griots speed shine Wheel cleaner: Griots (green) or Sonax Tires: Wolfgang Tire Gel (low gloss) Windows: Invisible Glass / Sonax Glass cleaner Interior: Meguiars interior detailer UV protectant: 303 Aerospace
2022 BMW M240i Portimao
Gone: 2020 Genesis G70 3.3T | 2018 Audi A5 SportBack | 2015 Challenger Scat Pack | 2011 Mustang V6 | numerous others.. |
03-10-2023, 10:48 PM | #18 | |
8326
Rep 10,740
03-11-2023, 06:53 PM | #19 |
![]() ![]() 371
Rep 298
Drives: 2022 M5C /// 2025 iX xDrive50
After cycling through numerous brands, I’ve seriously landed on everything CarPro for all the chemicals.
Still want to try Bilt Hamber and Koch Chemie (although I have Motorplast and it’s excellent). The only thing different I use for wheels is Sonax Wheel Cleaner Plus, which I find is the only thing that cleans all the brake dust properly from the F90. Stuff is expensive as it needs to be used undiluted, and I’ve resorted to buying the 5L pales for $100. Stupid expensive. The one I can’t get my head around for wheels is P&S Brake Buster, that so many people rave about. That stuff has just never worked well anywhere close to Sonax.
Reventon Splitter /// Reventon Diffuser /// Addlights M Door LEDs /// Dinan Inlets /// Gentleman's Switch /// Paddleshifterz With Piano Black Steering Wheel Trim /// Charcoal Filter Delete /// Piano Black Side Skirts /// Funk Motorsports Turbo Blankets
03-11-2023, 07:37 PM | #20 |
![]() ![]() 111
Rep 324
What would ya'll suggest for leather cleaning? I was gonna probably use Gyeon Interior Detailer for everything, but I'd also like something specifically for leather, either colourlock or gyeon leather cleaner mild, or Carpro Inside
03-11-2023, 07:41 PM | #21 |
![]() 2326
Rep 1,921
GYEON Leather Cleaner Mild or Strong work well.
03-11-2023, 08:37 PM | #22 | |
8326
Rep 10,740
Which CarPro products are your favorites? |
