02-15-2023, 11:48 PM | #1 |
3541
Rep 1,761
Why do people cycle on busy streets?
Excluding metro areas.
I live in Phoenix and I see people bicycle (cycle) on busy streets when there's no reason too. They cycle on busy main streets. Why would you even want to do that when you can do it on side streets? Aren't they afraid of getting hit by a car? Makes no sense |
02-16-2023, 12:17 AM | #2 | |
5547
Rep 5,761
02-16-2023, 01:25 AM | #3 |
67
Rep 21
I’m afraid we have the same in each and every country…
Are they also very aggressive against pedestrians? |
Th3Walrus555.50 Sherrie_goff1.50 |
02-16-2023, 03:43 AM | #4 |
2JZ-GTE
3174
Rep 4,149
It’s because they want to die or be run over and sent to the closest emergency room
02-16-2023, 07:45 AM | #5 |
5552
Rep 3,352
Apparently none of you all are cyclists or even motorcyclists. Many people use cycling as their commuter vehicle. Many people prefer to use their bicycle as basic transportation. And depending on what you define as a busy main road, traveling via bicycle can in many ways may be faster than driving. There are tons of people that cycle in NYC for this very reason and no one here can argue that NYC streets are not busy. Also, some places/areas prohibit cyclists from riding on the sidewalks.
Yes, cyclists have to adhere to the same rules of the road as motor vehicles. But unless there is a sign prohibiting a cyclist from riding their bicycle on that stretch of road, the cyclist has every right to be on that road as you in your cage. As long as the cyclist isn't doing something stupid on the road or being an ass by riding slow in a through lane blocking traffic flow, I see nothing wrong. |
02-16-2023, 08:55 AM | #6 | |
11015
Rep 9,140
I live in a smaller, less populated town. I WOULD never cycle on streets unless it's just to get around a sidewalk that is unavailable... it's simply far too unsafe to be sharing roads with 3000-4000 lb cars. Then you add in the biker clowns that feel they are entitled, wear headphones and don't even look when crossing the roads... yeah good luck. As far as bike lanes... those are excellent if you want to die as well. I would stick to sidewalks almost exclusively unless in suburban neighborhoods. In a big city - like NYC, LA, MIA and the like... you shouldn't be biking that's my opinion... its just too dangerous.
2 x N54 -> 1 x N55 -> 1 x S55-> 1 x B58
RickFLM411909.50 |
02-16-2023, 09:31 AM | #7 |
452
Rep 156
My peeve is that they ride ON the stripe of the dedicated bike lane. imagine driver's response if I kept left tires on the centerline stripe...
Th3Walrus555.50 bobowar1353462.00 |
02-16-2023, 09:48 AM | #8 | |
5552
Rep 3,352
Probably not. But for many streets I don't have an issue especially since I can maintain a speed of 28MPH for a decent duration. This is the same argument made about motorcyclists. Maybe I'm a bit screwed up in the head as I've personally faced death twice which tends to screw you up a bit mentally. So my level of risk tolerance is higher than most. But if everyone (cars, trucks, motorcyclists, cyclists) pays attention to what the hell they're doing on the roads, it wouldn't be so risky for everyone to share the same road. |
02-16-2023, 10:07 AM | #9 | |
5997
Rep 2,039
Typically a single tour de france trannie isn't much of a bother, but still makes me wonder why they choose to do this pass time (because these mofos are not commuting anywhere) on roads with heavy traffic. I'm not a cyclist, but I do ride a bike sometimes... in parks and other areas where it's pleasant to do so. I just don't see how one enjoys riding their bike on busy streets risking getting run over at any moment. Then again maybe they like the adrenaline rush of almost dying all the time. |
02-16-2023, 10:13 AM | #10 | |
5552
Rep 3,352
As to riding on busy streets, per my reply above, everyone has their risk tolerances. For me, I use cycling as my aerobic workout. For the speeds I need to travel to get a good workout, I'd be in violation of prudent speed limits on bike trails and endangering pedestrian traffic. |
dreamingat30fps5996.50 |
02-16-2023, 11:08 AM | #11 |
Infinite Boulder Roller
602
Rep 413
Cycling on the road... ie.. "Sharing the Road" is fraught with issues. One of them being that, when there are dedicated cycling "lanes", most of the time they are never swept and are covered in shards of glass and debris.
so... when getting from point A to point B (why I used to cycle on busy roads), if you ride in that "proper" cycling lane, you stand a decent chance of cutting a tire down and ending up with your head under a tire of a passing car. that could be 1 of the reasons to ride on the white line... but generally, riding on smooth paint is a bad idea. Safety in traffic also means (usually) taking enough of the lane that cars have to physically go far around you, and "uneducated-about-cycling" drivers don't subconsciously assume that they can skim by you while still taking the entire lane you are in... which can easily result in you (the cyclist) getting hammered by a mirror at speed... in traffic. ie... if you try to ride far to the right, you may have to swerve deeper into the lane to avoid a metal grate... no matter the direction of grating... they are a bad deal for cyclists. bad-bad.... but a person driving a car trying to skim by you wouldn't know that you need to do that. again. bad-bad. Why? Point A to Point B. Though as phones became more of a distraction for drivers, my road-cycling days have dwindled. Being in another car among distracted drivers is dangerous enough. Last edited by br438; 02-16-2023 at 11:51 AM.. |
02-16-2023, 11:10 AM | #12 | |
11015
Rep 9,140
You are on a 20 lb device vs people in 3-4k lb devices... if u get hit, no matter what u lose. The real problem is that NO ONE pays attention and that won't change... driver or biker... however, the driver will always win due to sheer mass. I drive every day and see so many bikers not even looking both ways when crossing... its insane But again, this is more of a competition of size on the road... one which ur always poised to lose.
02-16-2023, 12:10 PM | #13 |
7013
Rep 3,313
It's absolutely insane, people have a death wish I swear. never, ever trust a driver. Ever. Why people risk it does my head in and actually angers me when they have their kids do it too. A 5 year old died not long ago after being hit just down the street from me, he was riding with his dad. Why you'd have a 5 year old riding a bike with 4K lb SUV flying past at 30 MPH is fucking beyond me.
Idiots. |
02-16-2023, 02:00 PM | #14 | |
5552
Rep 3,352
Common sense is relative and only common based on point of view. I do things to ensure I minimize my exposure as best that I can. It's not going to prevent every risk factor. There are things I enjoy doing and I'm not going to stop because of some fear something might happen. I'm not being reckless either. I've done nothing risky to increase my risk of cancer. Yet, I got hit with it twice. That there has taught me I have no control over many things no matter how much I try. If it's my time to go, it's going to be that time no matter what I do. |
02-16-2023, 02:07 PM | #15 | |
5552
Rep 3,352
02-16-2023, 02:17 PM | #16 | |
11015
Rep 9,140
1) Imho, vehicles below 3k lbs are no longer fit for the streets in today's traffic. Sadly cars have gone massively larger, this is a fact... this would disqualify your miatas etc on today's streets sorry. 2) Semi trucks have limited exposures in that 95% of their miles are on two lane divided highways as they typically travel long distances where there is less two way traffic... 3) Pedestrians vs bikes -pedestrians DO NOT walk on the streets unless it's to cross them... they should never be on them outside of that. Pedestrians also move at 2 MPH and can move or jump in any direction as long as they are paying attention with little to no risk. A bike moves forward w great speed that you physically don't even need to get hit by anything to fly forward... any bump, rock, undulations on the street, pedestrians walking... absolutely anything can screw you... if this is a risk you want to take on your bikes or motorcycle... i won't argue with you. I own a dirt bike so I like bikes but I wouldn't dare get on a public road.
02-16-2023, 02:37 PM | #18 |
Fleet Mechanic
13300
Rep 1,979
Drives: E86 3.0si
Garage List '19 VW Golf R [10.00]
'55 Ford F100 [0.00] '08 Z4 3.0SI [8.50] '66 Triumph TR4A [0.00] '85 Corvette [0.00] '64 Corvette [0.00] '68 Triumph GT6 [9.50] |
adding this to the discussion...
02-16-2023, 02:57 PM | #19 |
2087
Rep 668
well, give me a minute to slip on my flame retardant vest...
a few reasons. 1. Most of the bike lanes have road debris in them which can puncture a tire or be a hazard. 2. It takes forever to get a bike moving from a stop, if the intersections clear go for it 3. It's much easier to transition to a cross street from the center lane 4. it's fun as hell
02-16-2023, 03:01 PM | #20 | |
3541
Rep 1,761
Just seems like you're needlessly putting yourself in harms way. Why wouldn't you want to cycle on a non busy street? Plus, you are blocking traffic. Last edited by Tyga11; 02-16-2023 at 03:13 PM.. |
02-16-2023, 03:07 PM | #21 | |
The Seeker
15565
Rep 3,930
02-16-2023, 03:15 PM | #22 | |
3541
Rep 1,761
I don't necessarily think they're stupid but it seems like a lot of cyclists do it to make a point and piss drivers off. They think just because there's a bike lane - they should be entitled to the road. They don't realize they are clogging up traffic and preventing people from getting to work while they can exercise. It's selfish and I don't understand who invented 'share the road' anyways when people have places to be? |
