bimmerpost/
BMW M2 and 2-Series Coupe
home
BMW 2 Series Technical Topics (G42) Wheels / Tires
      12-21-2022, 01:44 PM   #1
Stradale Design
Stradale Design's Avatar
129
20
Drives: Bmw m3 e46, g80 m3
APEX VS-5RS 19x9.5 +25 Square setup with 265/35/19
Just installed my new track setup. Couple things was being considered since we will use this car as a test bed for our new track suspension development, when; the ability to rotate wheels for even wear, and no modifications done to the fenders to fit the wheels.
Apex suggests 19x9 +25 w/ 265/35/19 tires for its square setup but I opted to take a gamble and try fitting their 19x9.5 +25 with Falken RT660 in 265/35/19 to get a better stance.
Currently it’s lowers on MSS Adjustable Springs and stock alignment, and I haven’t had any issues with rubbing. Next week I will take it in for track alignment and corner balance so clearance and turning from Lock to Lock might change, so I’ll have to report back on that.
Let me know what y’all think, any thought and suggestions are appreciated!
Appreciate 8
PNTDG42469.00
Red_sir134.50
XC3LLR82062.50
Coconut771.50
ZHPsedan135.50
      12-21-2022, 01:52 PM   #2
Expert@ApexWheels
Expert@ApexWheels's Avatar
3571
6,805
Drives: M3
This is fantastic, I actually had a testfit of these same wheels scheduled for a ZTK car combined with a brake scan but you beat us to it. Once it's aligned I'd like to hear your thoughts on rear tire to rear fender liner clearances and the clearances between the inner tire edge and the front struts/spring assembly. Those are the 2 pain points I've been concerned about with this fitment.
Also, that caliper clearance is pretty tight! Likely not an issue but debris like rocks or something might get caught between the front caliper and spokes and scratch up both components. Maybe a small spacer like 3mm would build that margin back up if the front can support that change.
Can we use your photos on our gallery thread/site? We'll tag your socials/link your site when sharing the images.
-Tom
      12-21-2022, 03:39 PM   #3
Stradale Design
129
20
-Tom
Thanks for the tip Tom!
And yes you guys are welcome to use the photos.
      12-22-2022, 01:42 PM   #4
XC3LLR8
2063
1,559
Drives: Super73
Best looking aftermarket wheel/tire setup I've seen yet!
      12-22-2022, 01:56 PM   #5
XC3LLR8
2063
1,559
Drives: Super73
With BMW's ZTK package coming with 9.5 on 255, I'm surprised Apex recommends 265 on a 9.
I wonder if this is because most people do not have the ZTK package with the 4mm fender flares, thus keeping the fitment for the majority a little safer?
      12-22-2022, 06:02 PM   #6
Stradale Design
129
20
Alignment done
-1.5 degree front camber 0.09 toe
-2.5 degree rear camber 0.15 toe
Now the rear clears with no issues. The alignment also helped the car feel lighter compared to the stock settings.
      12-22-2022, 06:24 PM   #7
Expert@ApexWheels
3571
6,805
Drives: M3
Correct, the 265 is one of the 3 sizes we list for 9" square and of the 3 probably the one I'd recommend least often. 245/40-19 or 255/35-19 are what I recommend to most on the phone, 265/35-19 makes sense if you're running an all season or summer tire who's true width runs a bit narrower than the listed size.
Once we do a bit more testing with the 9.5 ET25 as shown here, it'll go onto the guide with 265s but I want to check clearances on stock cars before trying it or recommending it to unsuspecting street customers looking for easy fitment.
With 200TW tires that run as wide as the RT660s, the 9.5 is definitely a better width of wheel.
Alignment done
Nice! I'm surprised you got that much range out of the stock suspension in the rear! That was just with MSS springs and the OE eccentric bolt?
-Tom
XC3LLR82062.50
      12-22-2022, 07:55 PM   #8
enome
enome's Avatar
20
27
Drives: BMW M240i RWD
-Tom
Assuming you are talking about my car, I’m excited to hear that these were the wheels getting prepped for our January schedule.
Will be looking forward to it.
      12-27-2022, 02:15 PM   #9
Expert@ApexWheels
3571
6,805
Drives: M3
Yep, it should involve wheels in this size along with the brake scan. looking forward to bringing you in!
-Tom
enome19.50
      12-27-2022, 05:53 PM   #10
PNTDG42
469
408
Drives: G42, F97 LCI, EBA R35, Z34
I really like this fitment. Possibly my favorite so far.
Anyone know what the factory alignment specs are?
      12-29-2022, 03:30 PM   #11
Zero7
Zero7's Avatar
31
411
Drives: M3 Dakar Edition
How did you go about getting the negative camber, have you installed top mounts (camber adjusters), also would you not prefer 18’s for the track set-up and leave the 19s for road.
      12-29-2022, 09:55 PM   #12
Stradale Design
129
20
The factory camber range is pretty large so we’re able to get a lot of camber in the rear.
I would have preferred 18inch wheels for the track but due to the lack of wheel choices in 5x112 we chose to go with 19inch. In addition, this car is no means a dedicated track car so putting 18inch wheels with 35 series tires on a relatively big car looks weird IMO 🙂
Zero731.00
      12-31-2022, 12:01 PM   #13
Zero7
Zero7's Avatar
31
411
Thanks, how much camber were you able to achieve on the fronts
      01-01-2023, 11:18 AM   #14
Stradale Design
129
20
Front was set to -1.4 degrees
      01-15-2023, 09:21 AM   #15
TUG_H1LL
33
13
Drives: BMW M240i
This information is great!! thank you for posting it
      01-18-2023, 10:16 PM   #16
shonseb
149
140
Drives: '23 240ix, gone: '14 Audi RS5
2023 m240ix  [0.00]
I did a thing....
Stradale Design
Thanks for posting the specs and dialing in the fitment. I was initially going to go staggered, but after seeing this thread I changed my order. I would have initially went square but I wasn't sure about fitment and I didn't want to run spacers. Now rotating these wheels for track use now should be easy. 👍🏾
Appreciate 5
      01-21-2023, 11:02 AM   #17
Stradale Design
129
20
Originally Posted by shonseb View Post
I did a thing....
Stradale Design
Nice!! Looking forward to seeing your setup!
      01-21-2023, 04:24 PM   #18
Jack@AUTOID
Jack@AUTOID's Avatar
1777
597
Drives: G87 M2, G42 M240i, F87 M2, E36
Gonna try and get same camber set up as you guys with my MSS. Looks great guys. Nice work.
      08-13-2023, 10:33 PM   #19
G42.Drxw
50
61
Drives: BMW M240i
2022 BMW M240I  [0.00]
How would this fitment work with 19x9.5 +20?
g87
