11-07-2022, 05:35 AM | #1 |
1201
Rep 636
Staggered 20x10" rear / 19x9" front fitted
Extra rubber 265 rear / 255 front Handles beautifully, rides very well even while lowered. Grip is insane, launches harder, cornering grip is endless, brakes harder and front end has a little more feedback. I can see why the M2 runs a staggered 20/19" setup the chassis feels made for this configuration. |
9
XC3LLR82062.50 mblaucoupe135286.50 Red_sir134.50 Summeristooshort16.50 jbazz256.50 hooked191.00 Alpine Flyer138.00 Vaticous134.00 VegasG42390.00 |
11-07-2022, 10:47 AM | #2 |
2063
Rep 1,559
Looks good!
Did you consider going with 295/30 in the rear? That would give you a sidewall height identical to the 255/35 in the front, and still be in spec on a 10" wheel. |
11-10-2022, 05:58 AM | #4 |
1201
Rep 636
You could go to 295 but I wanted to retain the factory Scrub Radius/Centre line as I was shooting for performance, balance and not just asthetic. 295 are going to start to push very close to the struts so you'd have to increase offset thus push outside of factory Scrub Radius and your tire would be right on the fender line. But you absolutely could do it. The 275 on 20x10 stays within xDrives front/rear +1% max differential so that was the best set up with really no compromise. If you go wider you're increasing offset and pushing toward the Bodyline or running dangerously close to the suspension, if not touching, either way that was to much compromise for what I wanted. The 265 has virtually no lateral sidewall deflection either, all around it drives beautifully.
11-14-2022, 07:48 PM | #5 |
326
Rep 498
At your leisure, would you be able to post a few side photos showing how flush the wheels are with the wheel arches and how the tire sidewall fits on your wheel sizes? Curious. Everyone is always looking to push the limits but if you say that the wheel and tire sizes are a perfect match then the debate is settled. Also which spring did you choose? Thanks.
Rivian R1T
VegasG42390.00 |
11-17-2022, 06:22 PM | #6 | |
1201
Rep 636
I went with MSS height adjustable so I can manage the +/- front to rear ride heights and keep the car balanced. The rear should sit at +5mm-10mm higher once the springs have settled to maintain the 50/50 weight distribution and COD of the car. The guys who just dump it all around don't know what they're doing to the handling of the car. |
11-17-2022, 06:39 PM | #7 | ||
2063
Rep 1,559
11-30-2022, 08:55 AM | #8 | |
191
Rep 127
More specs please
I'm considering a similar setup for summer. I ended up taking the summers off (mine came with PS 4S / ZTK pack) and putting the winter tires on the OEM wheels. What offsets did you end up going with? Spacers? I'm looking for a little bit of a step up for the summer ride but it's critical that any changes only improve/retain the best handling balance for the chassis. Looks are secondary to me and I don't plan to lower it or anything like that...I'm not a suspension engineer and I did not sleep in Holiday Inn recently. Just want a fun summer setup and a safe winter setup. |
04-20-2024, 08:32 PM | #9 | |
390
Rep 656
But do you happen to remember the offsets ? |
