BMW 3-Series (E90 E92) Forum
DIY: How to remove the Non-Sport steering wheel airbag
05-11-2006, 08:28 PM | #1 |
76
Rep 1,440
As what some other members here on the forum posted on how to take the Airbag from a sport steering wheel, the non-sport steering wheel has the same principle but very a different style and approach...
1. As stated for previous DIY, remove you battery connection. 2. There is also a small hole on the back side of the steering wheel, you can see and feel it. (like the sport steering wheel) 3. Position your flat screw driver pointing at 11-12:00 and push it towards the inside (pic 1) the aribag will be released from one side. Do the other side exactly the same pushing the screw driver inward. 4. The Airbag will pop out and you can release the clips carefully. * Don't worry about the multifunction buttons, no need to remove it. ** If you are changing your non-sport steering wheel to a Sport steering wheel or an M sport, you need to have: 1. Sport round Airbag and airbag bracket (which you cannot buy separately from the dealer). 2. Multifunction buttons 3. Connecting line for the airbag 4. Steering wheel cover or an M sport steering wheel cover You can refer to this site for part number: http://www.realoem.com/bmw/partgrp.d...23&hg=32&fg=35 then follow Bavarian19's DIY on how to install a Sport steering wheel or an M sport wheel. Good luck! Last edited by markE90; 05-11-2006 at 08:56 PM.. |
05-11-2006, 08:46 PM | #2 |
Administrator
41263
Rep 21,247
Thanks for sharing Marcus. Added to Master DIY List
06-28-2006, 03:07 PM | #3 | |
134
Rep 463
06-09-2007, 11:22 AM | #5 |
74
Rep 249
I just did the swap and the pictures really helped. I still had trouble getting the airbag out, however. Here a few further tips:
1) My 'holes' were covered with a thin film of vinyl that had to be poked through. 2) You need a fairly thin screwdriver. I had trouble getting mine to go all the way through to the airbag clips. It helps to jiggle the screwdriver fore-aft to stop it from 'catching'. 3) You don't need to release both sides simultaneously. Each side will just 'pop' out. 4) I wound up with an 'X-Drive' warning light when I re-connected the battery. I wasn't too worried about this -- as the car is going in on Friday for its annual service -- but the lights went away (and so far haven't returned) once I started driving. 5) I was hoping to use the screws that secure the radio switches from the old wheel to perform a similar function on the M-Tech wheel. I didn't wind up doing this, however, as the screws appear to be buried under the leather wrapping of the old wheel. The new M-Tech wheel feels great! |
02-24-2009, 03:45 PM | #12 |
233
Rep 3,030
just out of curiosity, if you swap from a non-zsp steering wheel to a zsp or m steering wheel, can you use the multifunction switches over? I know you need to replace the trim and everything... but not sure if the switches are transferable.
02-24-2009, 11:57 PM | #13 |
29
Rep 367
the multifunction buttons from non-zsp is not transferable to the zsp wheel. you would have to get zsp multifunction buttons. 2 different kinds, one for non idrive and one for idrive.
06-06-2009, 01:19 PM | #15 |
Quiet till poked
99
Rep 1,176
Hey, I tryed to do this, but no matter how much I tryed, I couldn't do it. Anyone near the MD/DC area that can do this? Or should I just go to the dealer or something?
06-12-2009, 01:25 PM | #16 |
→сяuisiиg iи му вмш←
66
Rep 1,642
Drives: 2010 Space Gray 328i
thanks, THIS HELPED ME TODAY
SuPerMoD @ MassMonsterz.com
A "Happy" Owner of a Metallic Space Gray 2010 BMW 328i ProGaMeR on the XboX 360 |
07-01-2009, 06:40 PM | #17 |
Rep 5
thanks for the great pics
Thanks for the great pictures! Was working on getting the airbag removed and had a heck of a time until I came across your pics. After seeing your pics I had the airbag off in about 4 seconds! Thanks!
10-24-2009, 02:29 AM | #18 |
219
Rep 3,012
Awesome. Worked great for me. My screw driver was too small, needed a bigger one. Too bad it leaves permanent marks in your non-sport wheel.
10-28-2009, 05:21 AM | #19 |
112
Rep 945
Drives: BMW 520D F11 2015
It costs alot; even though i got my parts at a good VERY good price.
M3 stitched wheel- £140 Airbag - £185 Connecting line / m trim / multi function buttons / multi func screws - £165 Grand Total: £490 I've yet to receive my 'new' airbag- so i'm waiting to see if i have to scout out an airbag mounting bracket Edit: Its arrived- it hasnt got the bracket- i've rang BMW and they told me that the part i need comes as part of the wheel. So i'm now in argument with the seller of the wheel, as to where this part is. Last edited by iBeech; 10-28-2009 at 07:48 AM.. |
11-29-2009, 04:43 PM | #20 | |
198
Rep 2,100
why would the multifunctional buttons be different fitment to those that go on a sport wheel? they look exactly the same in size and appearance!!? |
03-26-2010, 12:19 PM | #22 |
31
Rep 402
Anyone clarify any further on using non-sport multi-function buttons when upgrading from non-sport to sport? And if I have to get new sport multi-function buttons (and I don't have i-drive) I have to get the non i-drive version of the buttons? Would the i-drive version of the buttons work (meaning would the idrive button just be a "dead" button for me but the other buttons would work)? TIA!
