09-17-2022, 07:59 PM | #1 |
336
Rep 591
G80 vs F80 track simplicity
Asked this in another thread, but want to get better visibility
Also would love to know: DSC settings Stock or modded set up Currently in an F80 that can get around COTA ~2:35ish (bone stock, no mods) Have a G80 at 112 status and super curious whether there'll be an improvement My background: Current advanced/checkout instructor for Chin and AI for BMW CCA including ITS instruction Super curious about your level of experience and thoughts of the G80 given I'm about to trade the F80 which has been a hell of a lot of fun for a car I've never driven, Thanks in advance! Data I'm trying to get, is it even worthwhile to drop the F80 for a G80 when it comes to track days? |
09-17-2022, 09:42 PM | #2 |
180
Rep 192
I had my 2015 F80 for 7 years and took it to COTA a few times over the years. I recently picked up a 2022 G80 M3 but don't plan on tracking it as I have a GT4 I use for the track.
That said, the G80 is significantly faster in a straight line and the handling limits and composure are both much better as well. I turned a 2:32 at COTA in my stock F80, I would expect the G80 to be several seconds faster while offering better refinement and more luxury at the same time. A very fun car in my opinion. |
09-18-2022, 12:31 AM | #3 | |
856
Rep 144
First off this car is my daily but I have a ton of mods that allow me to quickly swap for track weekends and have a solid track car. First outing was fantastic. Car was basically stock with an alignment around -2 up front and stock Pirellis. Getting use the car in the first couple sessions you could really feel the potential. Straight line speed is great 155ish on the back straight braking at the around the 200 markers. That event I wasn't focus on time but more understanding the car and track lines etc. Ran a best 2:45. -I had the itch Second outing was even better. This time I had some more mods. SPL front lower control arms -3 up front - AST springs - Speed Engineering Brake cooling kit. Still on stock Pirellis. Much better speed through 2 and into the s's and around the carousel. Braking later on the back straight around the 150 and this car will stop on stock rotors and pads. Ran a best 2:39. Third was by far the best and could have been better. I was on R888Rs and went with the KW HAS kit to give the tires more clearance as the AST sat too low. 2 big take aways. Tires made a worlds difference. Combination of that and more confidence on my end I was able to take most of higher speed corners about 10ish mph faster. I ran a best of 2:36. The big neg was the Kw HAS kit. Spring rate is so soft the car just felt soooo heavy. I have some photos going around 10 and the car is leaning so much more than when I was on the AST springs. I am now on KW V3 coilovers and some Pagid yellows so my next outing should be even better. I am by no means an advanced driver so low 2:30 if not sub I think is definitely possible even stock. I've left DSC on. Don't see the need for me yet to change that. All in all the car is a blast and is super fun on COTA. Xdrive would make all of it even better. |
09-19-2022, 08:10 AM | #4 |
1485
Rep 1,291
The G80 will be way faster. It won't even be close.
Here's my experience at Pacific Raceways: Stock G82 Competition RWD - 1.36.4 Modded F87 M2C - 1.35.7 (camber plates, Coilovers, Stage 2 tune, 275/295 wide tires, LCA mono balls) Stock G82 Competition XDrive - 1.34.6
2024 BMW M4 Competition XDrive - Tanzanite Blue/Kyalami Orange - AST HAS - RaceChip
09-20-2022, 12:22 PM | #5 |
18868
Rep 14,141
Drives: G82 M4C X-Drive
I posted my track experience in this thread:
Tracking my F80 M3 CS vs my G82 M4 Comp X I'm faster overall in my G8X on street tires than my F80 M3 CS on 200tw.
2022 G82///M4 Competition X-Drive - KW-HAS, EBC Bluestuff, Millway Race Camber Plates, Cup2 Connect*, PSI High Flow Midpipe, Lightweight Front Lip, M Perf Flow Through Wing Previous • 2018 F80 ///M3 CS • 2016 F80 ///M3 IG: Raging_G82 |
09-23-2022, 08:29 AM | #6 |
186
Rep 242
I've been tracking a F80 for six years (best lap 2:30.6 with pads, fluid, and camber plates as "mods") and am taking the G80 out to COTA this weekend for the first time…
Will report back but I believe this car will be much quicker than F8x - likely not on my first weekend but the car feels a whole lot more capable. |
09-24-2022, 07:33 PM | #7 |
2522
Rep 1,773
On a track like COTA, G80 will be quite a bit quicker. Interested to see thoughts from ATX_M3 Been a while since I drove COTA. Raced there back in 2013 with BMW Club Racing.
09-26-2022, 09:32 AM | #8 |
186
Rep 242
Took the G80 out to COTA for the first time this weekend - in short, the car is super capable. My lap times were about 1.5 seconds slower than my best F80 CS time but that's not a fair comparison - I set the 2:30.x in the F80 in February on a cool morning session and set a 2:32.3 in the G80 on a 98 degree 3 PM session. Here are the initial thoughts:
- Side by side video of the G80 vs. F80 - G80 lap without side-by-side - We all knew the G80 would be high on consumables. I wasn't expecting to 80% wear through a set of front Carbotech XP10 pads over two days. It's a big car with a lot of power...no doubt about it. - The braking capability is incredible - zero fade. This was my first session out in the G80 so I know there is SIGNIFICANT time to be gained in the braking zones with some more seat time. - ZF8 felt much better at the beginning of sessions than at the end - again, it was super hot out but the upshifts did slow down in the heat. I will say the smoother shifting of the ZF8 made the car more stable in the exit of turn 1 and going through turn 2 - seamless power delivery and the car didn't get "upset" like the F80 did while accelerating down the hill going into turn 2 - F80 vs. G80? I don't know that one is better than the other - they were both great. No doubt they are very different - given the fact that I DD my cars 359 days a year and take them on track for 6 days (give or take), I prefer the G80 hands down. - I didn't have any weird issues with the safety systems on track - when I put it in track mode, the car didn't intervene once even under threshold braking, driving in traffic, etc. - Downsides: I kept getting "High braking load - adjust driving style...to avoid overheating the brakes" messages in iDrive that would eventually clear after some cool-down driving. It didn't impact anything but it would be cool if they car didn't bitch about driving on track.... I'm sure there are more thoughts - I'll add more as they come to mind. |
BMWRacer5232522.00 T0RM3NT3764.00 |
09-28-2022, 05:27 PM | #9 | |
336
Rep 591
And sorry everyone for the delayed reply, 2 teenagers + work + life gives me little time for forums Alternately, instructing at COTA the week after F1, and have a garage, feel free to come out so we can chat! https://chintrackdays.com/roster.asp...BsvqV%2f1Ak%3d |
09-28-2022, 05:41 PM | #10 | |
336
Rep 591
I could maybe see 2:30 flat in a G80 given the stock -2.0 camber vs. -1 in an F80 (my NT-01's hate COTA) 2+ seconds is a ton, but again, no expert...just a check-rider. And driver skill is the real thing And yes, my comp license is expired so ymmy |
09-28-2022, 07:04 PM | #11 | |
18868
Rep 14,141
09-28-2022, 07:07 PM | #12 | ||
186
Rep 242
jmg18867.50 |
