      09-10-2022, 09:02 PM   #1
G20.So
Drives: Bmw 330i G20
Bmw G20 M-Sport Conversion
I just wanted to ask if my warranty at BMW would be voided if I were to convert my base exterior 330i to the M-Sport rear and front bumper. So far I have not found a answer.
      09-11-2022, 05:06 AM   #2
aguycalleddb
aguycalleddb's Avatar
United Kingdom
534
508
Drives: BMW G42 M240i XDrive
Unfortunately warranty is a big grey area, if you had a problem with the engine they couldn't blame the bumper swap and would repair it, however if you got an electrical fault they could blame the swap as you've touched the lights / pdc / active grill etc.
The general consensus is that all mods void warranty and you do them at your own risk.
I would say If you want to do it then go for it but use good quality parts.
Dan
G42 /// M240i Thundernight
G20.So1.00
      09-11-2022, 07:35 AM   #3
Bc2005
408
469
Drives: 2021 M340i
As already explained , losing warranty coverage is only when it’s related to the specific modification. However, the newer cars have systems that are very integrated. You just need to ensure top you get all the required parts, and don’t crimp or break any wiring looms.
For example, I hit a small animal that took out a fog light housing, so I just unplugged it until I could get a new one. This caused a constant error to show on the dash display because the car has a system to check the fog lights. I also had neighbor back out and put a small dent in my front fender near the marker light. For some reason this caused a fault that knocked out the angel eye lighting around the nearby headlight. Absolutely no damage to the headlight or marker, but the undamaged angel eye did not come on. I don’t know exactly what they fixed when they repaired the fender and got the light working again.
G20.So1.00
