07-28-2022, 09:49 AM | #1 |
![]() 164
Rep 279
PPF Question
My car has full PPF on it, there are some areas that aren't super visible - like under side skirts for example - that the PPF has peeled up a little bit. I've heard there is a certain primer that can be used to help hold those areas down? Can anyone point me in the right direction what this primer is (whom to purchase from), and how to properly use it?
And, when removing or replacing the PPF in the future - can this primer be removed without ruining the paint? |
08-01-2022, 01:23 PM | #4 |
![]() ![]() ![]() ![]() 327
Rep 717
This^
I’ve had 10 plus cars PPF’d and never had this issue. They can trim the lift part it’s not seen really easily.
Wo-Wo Detailing Accessories
www.wo-wo.co.uk |
08-01-2022, 01:48 PM | #5 |
![]() 2072
Rep 2,259
Try Pro Bond Adhesive Promoter.
I've used it on peeling edges with great success. Make sure you don't use too much. I've used a sharp-edged nylon q-tip to apply just a tiny bit. Took care of the peeling edges around the front bumper above the grill/under the hood. I'd be careful applying to bodies that are visible. Areas I used are under the panels and wrap arounds like under the wheel well, etc. |
