      06-04-2022, 03:47 PM   #1
ibmc
140
140
Drives: 22 M4 Comp G82 RWD
Carbon Fiber Roof Scratches from clay bar
So, my new M4 arrived almost a month ago, and I spend a lot of time slowly cleaning it up (asked dealer to only remove the white protective film) bought all the washing and detailing supplies, watched videos etc...and I guess I should have learned a bit more about the CF roof. Its not like its new to me, I had a 2018 M4, and it remained perfect for 3+ years.
I got clay bars and used clay luber after washing the car, making sure it was perfectly clean, but it left a ton of scratches. My fault, but now I need to fix it. I tried fine polish/polish pads with an orbital polisher, but the scratches remain. So, looking for some expertise (not opinion) on if this can be fixed, and how to best go about it. If its the same clear coat as the paint, do I just go a bit more aggressive on the compound? Last option would be to take it to someone, but there are limited options where I live.
      06-04-2022, 03:59 PM   #2
Soylent
Soylent's Avatar
1249
1,240
Drives: 2025 M4C
Glad I didn't try that yet. Maybe some of the detailing oriented members here?
@luckylingy
      06-04-2022, 05:27 PM   #3
Bumper2Bumper
Bumper2Bumper's Avatar
344
166
Drives: Tesla Model Y (G80 On Order)
We have restored some pretty bad, old carbon fiber. Wet sanding and polishing should bring it back to new condition. But of course, wet sanding is not for the feint of hart and I wouldent try it for the first time on your carbon roof.
      06-04-2022, 05:54 PM   #4
Former-Mopar
262
228
Drives: MBW M4 Comp
What's the best way to keep it clean and scratch free?
      06-04-2022, 06:51 PM   #5
Myangdue
Myangdue's Avatar
54
57
Drives: Porsche 991
I would say get it professionally detailed and put ppf on it so that you dont have to worry about getting the scratches
808F903.00
      06-04-2022, 07:09 PM   #6
Bumper2Bumper
344
166
Yes PPF or ceramic coating, specifically 9H like ceramic Pro.
      06-08-2022, 04:04 PM   #7
ibmc
140
140
anyone else? Bueller?
any other experts out there? Have not seen any helpful comments.
      06-08-2022, 06:51 PM   #8
merlin3008
merlin3008's Avatar
941
905
Drives: 2025 M3 Comp xDrive
So lesson number one of clay is to use plenty of lube. The work isn't done by friction against the paint. That being said, I do not think you need to go to wet sanding yet. treat it just like any other clear-coated surface and use increasingly aggressive measures until you have the right level. When polishing, less is usually more. I would try some more aggressive polishes first if you are conference enough with your rotary. Use a moderate cutting pad and go to a medium polish. If that doesn't help, go to an aggressive cutting pad and a polish like Meguiars 105 or 110. Good luck!
2025 M3 xDrive, Dravit Gray over Kyalami Orange (on the way)
2022 M3 xDrive, Brooklyn Grey over Tartufo (SOLD)
2021 Tesla Model Y
2019 MB AMG C43 (Sold)
2016 M235i xdrive, Alpine White, Terra Leather, Orbit Gray Wheels (Sold)
ibmc140.00
      06-09-2022, 10:22 PM   #9
FISH22
FISH22's Avatar
5538
2,035
Drives: G80 M3 Competition
2021 BMW M3C  [10.00]
2011 BMW M3  [10.00]
I have gone somewhat aggressive on my carbon roof with polishing… orange pad, abrasive polish and orbital. This was to get some water spots out. Worked well, and I didn't have to follow up with a finer polish or less aggressive pad.
I guess what I'm getting at… what pads and polish were you using? How many passes? Setting on orbital? Pressure applied? Your original post is a bit vague.
Pro tip: clay barring is a gentle process, with lots of lube (that's what she said). No need to rub the surface hard or make multiple passes.
      06-10-2022, 08:49 AM   #10
ibmc
140
140
lots of Chemical guys Clay luber + clay bar is what put the scratches on it, a light cleaning with the clay bar, not much pressure. Maybe it picked up some contamination, but I was very thorough in my pre cleaning. I finished with fine pad and fine polish, but that did not remove the scratches. Maybe too fine.
      06-10-2022, 09:40 PM   #11
FISH22
FISH22's Avatar
5538
2,035
2011 BMW M3  [10.00]
Yeah I'd give a go with an orange pad & more aggressive polish. Like I said, I did this on my roof, and it made it look spectacular. No follow-on/finishing polish needed.
Utilized Griots orange pad (3") w/their compound polish (white).
Limegrntaln14419.00
ibmc140.00
      06-11-2022, 08:58 AM   #12
ibmc
140
140
Thanks All.... I talked to my Xpel PPF/Tint installer, they have a guy that does paint correction who will take a look at it, they are not a detailing shop, but at minimum they can advise me on the best path forward. One suggestion over the phone was to PPF the roof, and the bottom sticky side would fill in any fine scratches. Will see what their expert says.
      06-11-2022, 11:04 AM   #13
MassComp
MassComp's Avatar
2148
1,241
Drives: Porsche Macan GTS
Now I'm paranoid about applying PPF to my carbon fiber roof since all the installers in my area do some sort of "paint correction" to the surface first before applying the PPF....
I've clay bared many of my new vehicles myself over the years, usually using a Meguiar’s Smooth Surface Clay kit, and I've never scratched the clearcoat. How exactly could a clay bar scratch the carbon fiber roof?
Did you drop the clay on the ground and re-use it? Is the surface coating on the carbon fiber roof softer than the clearcoat on the painted surfaces?
3/19/22: Deposit placed on MY2023 Skyscraper Grey M3 Comp xDrive / 6/08/22: Dealer order placed - Status 047 / 6/25/22: Added Full Leather / 8/05/22: Received Allocation & Added Personal eSIM 5G / 09/18/22: Asked Dealership to Add M Drive Professional to My Build and They Canceled My Order
      06-11-2022, 10:34 PM   #14
ibmc
140
140
no
no
      06-11-2022, 11:18 PM   #15
barryc365
2009
1,410
Drives: BMWM3
Seems very strange, it's not like a brand new car would even have that much dirt to be clay'd
Seems like the clay got contaminated some how
I'm sure a detailer can buff it out unless you picked up some rocks in the clay or something crazy
Any pics of the scratches?
      06-12-2022, 01:38 PM   #16
chicagofan00
chicagofan00's Avatar
20560
8,393
Drives: 2024 X5 M60i
I've clay bared many of my new vehicles myself over the years, usually using a Meguiar's Smooth Surface Clay kit, and I've never scratched the clearcoat. How exactly could a clay bar scratch the carbon fiber roof?
Got full PPF on my carbon roof and there were zero issues.
New vehicles can have a ton of contamination due being at the rail yard, on the rail cars, then on the ships, and then on the open transport trucks. Especially given how long some of these cars have been sitting at the ports awaiting a ship or parts.
Instagram: @Phxrisingphotography
Current - 2024 G05 X5 ///M60i in Java Green
Past - 2005 E53 X5 3.0i in Titanium Silver; 2008 E92 335i in Montego Blue; 2019 G01 X3 M40i in Glacier Silver; 2022 G80 M3 Competition in Twilight Purple
      06-12-2022, 01:47 PM   #17
BzsBimmer
BzsBimmer's Avatar
3459
6,823
Drives: '23 G80 FO M3 & '23 G05 X5 M50
As others have stated, always start with the least aggressive method and work up.
For me, when I clay, I learned to buy a large block and cut it into smaller pieces and dispose of them after each “section” as to reduce possible contamination marring other sections or panels. Also if you drop it, it’s easier to toss out a smaller piece than the whole bar.
Also work the roof in sections so you can see the progress of each pass. Don’t overcorrect or you can burn off the clear and make it worse. Use a good light to see and remove fine scratches and any holograms.
And yes, new car paint is notoriously dirty with contamination due to its shipping journey and such.
