      06-02-2022, 05:54 AM   #1
BIGBAAAM
Drives: BMW E82 120D
BMW e82 120d error code [Engine light]
I own a gray e82 120d manufactured 2009.
the other day while I was driving my car, this engine light appeared.
I could feel a low performance of the engine when accelerating while the light is on.
I had my car checked by just near home engineer.
error code was like
480A DPF being excessively clogged - History
- 4A6E DDE: GLOW PLUG, CYLINDER 1 , ACTIVATION - Current
- 4933 air to EGR mass flow, plausibility - Current
4DFF swirl valve controller position control - History
4E09 Swirl flap, plausibility: - History
3F25 boost air hose monitoring - History
I had whole DPF took out cleaned and flushed by a mechanic.
Now I'm not sure the engine light appeared because the pipe and manifold including egr is clogged or simply the valve is fault.
Please help me with a low budget.
Thank you in advance
