      05-02-2022, 01:37 PM   #1
3.0L
3.0L's Avatar
11822
2,013
Drives: 2014 BMW M235i, 2024 GLC300
Oil consumption
I'm getting the impression that the new normal for new and recent cars is an increase in oil consumption.
From what I've been reading, engineers have reduced piston ring tension against the cylinder wall to reduce friction and increase fuel efficiency. The downside is increased oil consumption.
I only checked a few 2021 car brands and sure enough, folks have been complaining about oil consumption. Hyundai cars across most or all of the engine line seem to be using about 1 quart per 1000 miles (there's a class action lawsuit going on regarding the oil consumption). Recent Ford Mustang v-8's have been said to use as much as 1 quart every 600 miles while under "spirited" driving.
High oil consumption is foreign territory to me. My 8 year old M235i uses very little oil between the annual oil changes. Same, same for my 10 year old Mercedes Benz GLK350. I've never had to add oil.
So, is higher oil consumption also the new normal for new BMW's?
2014 BMW M235i
2024 Mercedes Benz GLC300
Expert ultracrepidarian
      05-02-2022, 02:11 PM   #2
heavyD^2
heavyD^2's Avatar
3737
2,991
Drives: X3M Competition
I had no oil consumption in my M2 or X3M. In conjunction with the low tension rings, economy and mid range cars now use 0W-20 and 5W-20 oils which will exacerbate the issue. I imagine this is something that you will have to live with on economy cars as most performance engines use higher viscosity oil.
      05-02-2022, 02:51 PM   #3
dgoldenz
2133
1,905
Drives: Vanquish, FF, 392 Wrangler
I know that both the Macan and Cayenne owners manual states that the oil consumption is normal and you may need to add half to one quart of oil every few thousand miles. My Macan GTS has used up about 1.5 quarts in 10k miles of driving with 69k currently on the clock.
      05-02-2022, 03:03 PM   #4
KennyFSU
KennyFSU's Avatar
1103
736
Drives: Lexus RC F
*laughs in rotary*
Estoril Blue E36M3
Mineral Grey M235ix/12.02 @ 115
Ultra White Lexus RC F
      05-02-2022, 04:45 PM   #5
mikado463
mikado463's Avatar
472
344
Drives: 2017 x5 35i , '67 Corvette BB,
one of the issues with the Ford (Coyote motor) was a PCV issue that was a computer software fix, so I've been told ......
cheers - Dave
      05-02-2022, 09:39 PM   #6
3.0L
3.0L's Avatar
11822
2,013
Originally Posted by KennyFSU View Post
*laughs in rotary*
I once owned a 1985 RX-7 and a 2004 RX-8, so I am pretty well acquainted with the routine.
2014 BMW M235i
      05-03-2022, 06:14 PM   #7
5.M0NSTER
5.M0NSTER's Avatar
3362
1,823
Drives: 2018 Camaro SS 1LE
My M2 ate some oil at track days. I was a full qt low after 4 days.
I had a Mustang V8 in the past, and that one only ate oil during the first track day. Not a drop after.
The Camaro was 1/2 qt low after half a day doing full send around Mid Ohio yesterday. Topped it off and kept improving on my previous personal best lap time.
Oil is cheap. Check and top off as needed. No need to worry.
      05-05-2022, 06:02 AM   #8
zx10guy
5589
3,361
Drives: 2013 135i
Not entirely related to the intent of this thread. But there have been reports of high oil consumption to the point of smoke coming from the exhaust with the M1000RR engines. The theory is due to possibly the 2 ring piston design along with possible improper break in. On the RR forum, there have been reports of two engines being replaced by BMW due to this issue.
