03-22-2022, 07:54 PM | #1 |
614
Rep 426
OEM+ Strut bar Retrofit (parts for G22)
Installed pics Below https://g42.bimmerpost.com/forums/sh...66&postcount=4
Saw this post buried in the g20 forum. Thought I'd bring it over here. Thanks soi3847 https://g20.bimmerpost.com/forums/sh....php?t=1863814 Pretty much all the parts from the G22 he listed below. New G22 front brace that's pre tapped, he taps the rear strut and buys the braces. You could go even cheaper and just add (assuming based on other kits out there on bolt size) the strut bars with out the front brace it's just untapped so you need a nylon nut. Two M8 x 60mm bolts Two M8 x 25mm bolts Four M8 Nylon Nuts Four-Eight M8 washers If you don't want to jack up the car you could probably do the Two 8 x 25mm bolts with nylon nuts on the front brace and then Tap the rear strut with the m10 x 1.5" making it easier to access the air box without jacking. "All G20 has not Strut Brace Bar.
'22 M240i BSM, Shadowline, Black 791M wheels, Red Calipers, ///M Carbon Front Lip, ///M Carbon Spoiler, ///MCarbon Door Sills, Milltek Catback w/Black Tips, Dinan Carbon Intake/Engine Cover, AA Catted DP, Dalher Valve Controller, OEM+ Strut Bar, Red Start/Stop, Floating center caps, TLG Mud Flaps, Black Badges, Led Projectors, 50th Emblems, Carbon Diffuser/Mirrors w/smoke signals/Side Wings/Cooling Shroud/KIES fire extinguisher, Yellow DRL
03-31-2022, 11:22 PM | #2 |
102
Rep 59
I have the Dinan braces, and I'm not a fan of the back side not being tapped. The components listed are exactly what comes with the Dinan set. The M8 60MM bolt that came with it were so much smaller than the hole in the backside. It just seems like it would shift back and forth and generally just fuck everything up. The bolt needs to be wider imo. I like the idea of tapping the backside. That would be hot. Thanks.
04-01-2022, 04:02 AM | #3 |
614
Rep 426
Also easier to remove to access the airbox with out jacking the car up
51716966566 is the bolt bmw uses which is a m10x1.5 Bmw charges $10 per bolt or I'm sure you can hit up the local hardware store and grab a nice stainless steel. Bmw is threaded the entire length, and has a little flange. If you google the part number you can see what it looks like
xcelir8bmw405.50 |
09-17-2022, 08:23 PM | #4 |
614
Rep 426
Got around to doing it. Used the OEM strut braces and powder coated them red
Used OEM rear Bolts and Tapped the holes. Used the m8 x 25mm flanged bolt with washer and nylon in the front. I also used the Dinan riser since I have the Dinan intake. Super easy. Just want to touch up the rear bolts black
06-05-2023, 04:56 PM | #5 |
191
Rep 127
Which BMW OEM braces fit the G42 M240i?
What are you guys using for the OEM solution and where are you getting them? Looks like the M440i has them included as stock and *guessing* those are the closest fit for a M240i too?
Some of the M340i guys on the G20 forum doing it: https://g20.bimmerpost.com/forums/sh....php?t=1810482 |
06-05-2023, 05:09 PM | #6 | |
614
Rep 426
I ordered the parts above in my post. I didn't do the front piece with the welded nuts and did the nylon nuts like the aftermarket struts braces install I had mine powdered Coated red for a little extra flair
10-06-2023, 10:17 AM | #7 |
386
Rep 381
I did this mod, swapped the G22 Strut Brace Bar, simple and straight forward. I had bought nice stainless M10 Flange nuts, but I hate things half done.
Used duplicolor engine ceramic paint and primer on the strut bars, came out great. |
aguycalleddb450.00 |
10-06-2023, 12:35 PM | #8 |
450
Rep 469
Drives: BMW G42 M240i XDrive
They look good painted, I did the mod a few weeks back but haven’t decided on a colour for the engine bay, I was thinking of keeping the purple theme going
Dan
G42 /// M240i Thundernight |
10-06-2023, 04:36 PM | #9 |
386
Rep 381
I also would have gone with purple, if I spent the $ on getting a spray on color matched paint and then clear coating. Obviously decided black was easier. It would look great if you decided to go that way.
