07-27-2021, 11:46 AM | #1 |
![]() ![]() 1477
Rep 1,191
Torky the torque wrench
Hey Guy's,
A question, when I didn't realize how sensitive, delicate and the correct use of torque wrenches where, I used to use mine and misuse mine. So, what I understand now is and i store them correctly and use them simply for tightening bolts. So a question, is there a simple way for me to test the accuracy of my 2 torque wrenches, a long one and a short one. I was thinking of buying a new one or 2, but again your not sure how accurate they are. Should I calibrate mine, send it away (which might be more expensive than buying a new one) BUY a new one and just hope. If I buy one, I see some fancy digital ones are they any good ? Txs |
07-27-2021, 12:46 PM | #3 |
![]() ![]() ![]() ![]() 20057
Rep 20,162
There are numerous sources on the internet for home calibration of torque wrenches to look to for guidance. But honestly, it's a car you're working on, not spacecraft. Outside of torquing engine internals and cylinderheads, the precision of your torque wrench is pretty much immaterial.
If you are torquing down wheel bolts to 88 pound-foot using a click type wrench, if it is off by a few percent it is not critical. Common use of TQ wrench for yard-monkey DIY'ers is for spark plugs. There you should only use a 3/8ths-drive beam-style torque wrench. |
DETRoadster11471.00 nazali1476.50 |
07-27-2021, 12:55 PM | #4 | |
![]() 1940
Rep 2,438
It's not a Mars lander you are putting together and the wrench is to make sure you are in the ballpark and don't go He-Man on the little bolts that don't need to know you just benched a personal record. ![]() |
nazali1476.50 |
07-27-2021, 12:58 PM | #5 | |
Space Force - 4 Star General
11471
Rep 3,265
OP, just the fact that you own and use a torque wrench puts you ahead of 90% of the pack. Unless you've literally attempted to destroy yours by throwing it off a building, I doubt your "misuse" is enough to make much of a difference in its accuracy. Dont sweat all the dudes that get all worked up becuase you used yours to loosen some bolts or ddint back the torque settign down tozero befoe you stored it. Like Efthreeoh said, you arent working on a spaceship. |
nazali1476.50 |
07-27-2021, 01:04 PM | #6 |
![]() ![]() ![]() 345
Rep 420
I did multiple headgaskets and a couple of engine rebuild with a click type wrench.
I have done hundreds of suspension replacement also. Except if your wrench is really off, you will be fine. Basically torquing with a couple of % off is better than not torquing at all and losing a plug or a wheel.
'16 M4 bone stock
'13 335ix Msport BM3 stage1 - MAD FMI - FTP CP - Bilstein B4 (SOLD) '85 635csi M30 turbo race car (SOLD) |
07-27-2021, 01:22 PM | #7 |
![]() ![]() 1477
Rep 1,191
hey !!!
txs all for the replies.... The only misues has been either using it as a breaker bar on lug nuts, throwing it in the tool box or it falling on the concrete garage floor. Yes, mainly for lug's but I have done other work, nothing too major and few and far between. I'll mebe hold of the calibration. I might treat myself though to a husky 50-250 ft. lbs 1/2" $137 and/or 3/8 $118 just because buying tools makes me feel good ! txs all again, some great answers |
07-27-2021, 01:24 PM | #8 | |
![]() ![]() 1477
Rep 1,191
LOL txs made me feel a "LOT" better thank you
DETRoadster11471.00 |
07-27-2021, 01:27 PM | #9 |
Slow.
3811
Rep 7,162
Drives: N54 6466 100% E85 + Meth
They make tq testers. But those also have to be calibrated as well from time to time IIRC. They are also not cheap. We use this style at work: https://www.toolup.com/Proto-J6476-E...4aAogfEALw_wcB
Honestly as long as you set them back to zero, are gentle with them, only use them for tightening, and it's not used all that often they last a decent while in calibration from my experience. Then again I have always used high quality tq wrenches from the beginning, I imagine cheaper ones will get out of spec much quicker. If you use them daily in a shop or in manufacturing it makes sense to at least check them for accuracy on a normal schedule. It is part of our PM schedule for all tools/machiones/ etc. Yes the fancy digital ones like the ones from snap on or CDI are nice. But do you really need a $700 torque wrench? https://shop.snapon.com/product/Tech...)/ATECH3FR300B My buddies race lemons, the only things they tq is their lug nuts. I usually only use my tq wrench for a few specific fasteners that I am anal/concerned about. 90% of the fasteners on personal cars I have worked on have been hand tightened and never had any issues or anything come loose or stripped because of over tightening. It is your money. If you sleep better at night go for it.
nazali1476.50 |
07-27-2021, 01:43 PM | #10 |
![]() ![]() 38
Rep 98
If the question really is ' how can I check the accuracy' and NOT 'can I use wrenches out of calibration' then It's just physics. Tighten any nut to a measurable value (5Nm for example, can do same theory in other units of course) then measure your torque wrench length (e.g. 0.5m) then hang a bottle of water of known volume off the end (e.g. 1L = 1kg = ~10N) and the product is the answer. 10x 0.5 = 5Nm. Adjust the water fill lower or higher until the nut moves or doesn't move. There is your answer.
nazali1476.50 |
07-27-2021, 02:13 PM | #11 |
![]() ![]() ![]() ![]() 4709
Rep 694
I had to do this for my techs to become Subaru certified. Its actually pretty cool, had no idea it was even a thing. Here is some quick online pricing I found
07-27-2021, 03:04 PM | #12 |
![]() ![]() 4524
Rep 3,027
Using one to loosen lug nuts (or other 'breaker-bar' type use) is not good; if you did much of that I'd check it at least. If you call around, either a Snap On dealer or perhaps even a tool/auto parts store may have a tester you can come in and use to check yours. Or do a home test (like in the video, but use a known weight). If it isn't close to spec, probably simpler to replace unless yours has an easy adjuster. I found a basic Craftsman 1/2" that is fine for lug nuts for about $50. And get the real lug specs for your car - M2C uses 106ft/lb, not the 88# noted above.
nazali1476.50 |
07-27-2021, 03:42 PM | #13 |
![]() ![]() 1477
Rep 1,191
txs Maynard,
yes I had heard that, back home used it to loosen, never heard of a breaker bar LOL mines a 2 series C with msport package (no blue calipers) does that matter ? without looking it up, not sure of the torque Had my torque for ohhh, about 10 years, at least |
Maynard4524.00 |
07-27-2021, 05:46 PM | #14 | |
![]() ![]() 4524
Rep 3,027
nazali1476.50 |
07-27-2021, 07:55 PM | #15 | |
![]() ![]() 1477
Rep 1,191
ok let me try again,, 2 series vert, 230xdrive, 18" rims, square setup
![]() ![]() Quote:
07-28-2021, 06:11 AM | #16 |
![]() 3467
Rep 2,044
07-28-2021, 11:15 AM | #18 |
![]() ![]() 1477
Rep 1,191
I found a $100 HD gift card, and took a stroll to see there husky one, $137, but God, it's a big old thing. Much bigger than my existing long one.
Then I thought do I really need 250ft/lbs of torque on a wrench LOL So looked at other smaller ones, but they only had like 3/8" I wanted a 1/2" Then I had a long think and thought do I wanna blow $130 on a wrench, so I gave up and went home LOL |
08-03-2021, 05:46 PM | #19 |
No one sleep in Tokyo
![]() 962
Rep 1,506
Drives: 2011 E90 328i//1995 E34 530i
*ahem* - BMW Service Procedure requires, at minimum, 120Nm of torque on the lug bolts. This translates to 88.507lb-ft in Imperial. Torqueing the lug bolts to only 88lb-ft is simply dangerous, the wheels may even fall off the car when parked at such low torque specifications....
2011 E90 328i, 1995 E34 530i, 1992 E32 740i, 1991 E34 525i
Efthreeoh20056.50 |
